Question about OKI MICROLINE 320 Turbo Matrix Printer
Windows XP, pre-printed P.O. forms. Iif I line it up in the same spot to print it never starts on the same line, always to high or to low. The info is being entered into an EXCEL page.
    New Friend:
  • 52 Answers
Your Okidat print emulates othe printers. Print out configuration and see what your printer is emulating and load the driver for that printer and all should work ok. Fought same problem for weeks, until I Loaded driver for printer it is emulating.
Posted on Mar 06, 2009
Print Error need more printing options since converting to Windows 8
See if you can get a new driver for Win 8 from Epson. Better yet, dump 8 and go back to XP or Win 7.
Feb 11, 2014 | EPSON Stylus Office T30 Series
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
Jan 28, 2011 | Dymo LabelWriter 400 Thermal Printer
I am trying to print onto pre-printed forms which have a dark blue band at the top. My printer isn't recognising that the band is there so is starting to print too far down the page. Help please!
This type of problem can usually be resolved simply by adjusting the margins from within your word processing program. Depending on which word processor you are using you can go into the page setup and make these changes. For Microsoft Word go to the "File" tab at the top then to page setup. The first tab that comes up will allow you to change the margins on the page. If the print is too far down try reducing the top margin from one inch to 0.5. If that is not enough reduce it some more. Print test pages on regular paper, then hold them up to the light against the paper with the pre-printed band to see how the print lines up. That way you don't waste the expensive paper!
May 20, 2010 | HP Photosmart C5280 Printer
Prints on two cards
You can modify the position in the menu.
The start position can be prgrammed in the personal settings.
Moving the paperwon't change anything because the printer will always check the top of feed
Sep 03, 2009 | Datamax I-4208 Thermal Label Printer
TallyGenicom 2265+ not printing with custom paper size
There may be a number of causes for the problem you are seeing. There are a number of places which may hold the origin to the page length problem you are seeing, in order of precedence these are;
  1. The page size set in the software package printing the 6 x 4.25 cards
  2. The page size set the printer driver printing to the printer
  3. The page size set on the printer
I would recommend the follwoing;
  1. Set the form length on the printer to 6 inches (i am assuming this is the length of the card)
    The form length can be set through the menu and is normally set in lines (normaly the print size is set to 6 LPI) so the form length should be set to 33 lines
  2. Create a custom form size in SERVER PROPERTIES on the Windows XP machine to match the form size you are using.
    Ensure you select this form size in both PRINTER PROPERTIES and PRINTING PREFERENCES
  3. Try printing some Windows Test pages to see if these respect the page size selected withing the printer driver properties.
If the Windows Test Pages do not print correctly I would recommend checking how you are creating the CUSTOM SIZE form, perhaps create a new form and double check the form properties one it has been saved to confirm these are correct.
Check you are using the correct printer driver for the printer, you should be using the 2265+ printer driver. As a test you may wish to install the GENERIC TEXT printer driver or the EPSON LQ2250 driver, these will be included in the Windows Add Printers Wizard and should print OK to the 2265+.
If the Windows Test Page prints OK I think you would need to look at the software package printing to the printer. Ensure the correct page size is selected here also, perhaps try printing from another software package selecting your custom size form to see if these print correctly.
It is passable your software package is sending escape commands to the printer to call up the page size, I note you say Genicom printers printed ok from Win 98. The 2265+ may not have the same emulations as the Genicom printers.
You can print a menu print on both Genicom (if these are available) and 2265+ and compare the settings on these.
I do not believe the 2265+ has a Genicom emulation as standard, but you may be able to load an alternative version of firmware into the 2265+ which provides the Genicom emulation. If the data going to the printer contains Genicom Escape command to set form length this may resolve the issue.
You may need to contact your TallyGenicom support department for the firmware (I think it may be called 7265+ firmware)
If you are able to provide Hex Dumps of the data to the TallyGenicom support people they should be able to say what is going wrong with the form length setting.
May 07, 2009 | TallyGenicom 2265+ Matrix Printer
Canon printing in streaks
first check the nozzle (bottom of cartridge). if u dont see black spots around the nozzle line (many nozzle that form straight line, black long straight line, color, 3 short line), or a view of burnt, u can continue below.
blow the air hole till it drop the ink. then clean it with water. but note, dont wipe the nozzle, let them wet. u must wipe the contact with dry tissue before inserting it back.
otherwise, u must replace ur cartridge :D
Apr 11, 2009 | Canon Office Equipment & Supplies
Printing problem in xp
You probably need an Epson driver for Widows XP. Win 98 just isn't going to cut it for continuous forms printing.
Aug 12, 2017 | Epson DFX-9000 Dot Matrix Printer
Printing Problem in Windows XP
Does it seem to print the Windows test page faster than the self test print? If so it is probably printing the self test in a higher resolution than the Win test print (Win test prints are usually printed in low res)
Try printing a simple graphic or document from a piece of software. First in DRAFT mode and then in the HIGHEST Quality setting. See if you notice the "jerky" sensation in the DRAFT mode.
It could be normal for you printer.
Oct 14, 2008 | Epson TM T88 Thermal Printer
Prints gibberish
print a selftest:
turn printer off then hold down the feed button, turn printer on and release feed button whenever it prints something.
pls reply back with info on printout, such as baud rate, parity and other info specially interface, thanks
May 13, 2008 | Epson TM-T88III Thermal Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
103 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
