Question about Mtd Garden
Need to know how to remove the electric pulley from a briggs and stratton engine on my riding mower
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
Posted on Jul 29, 2010
micromatikal
  • 2777 Answers
SOURCE: i need an owners manual for a brute riding lawn
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
http://www.doitbestparts.com/MANUALS/BRUTE/7800583.PDF
Posted on Oct 12, 2010
  • 130 Answers
SOURCE: 24 hp Briggs Stratton sears
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Posted on Feb 12, 2011
Testimonial: "thanks for the help the choke was open just a little"
Briggs and Stratton 17 HP Riding Mower
Hi Lawrence.
There should be a few more numbers/ letters to your model number. I added a link to a website for you to check out. Click the link or copy and paste it. Hope this helps.
https://www.repairclinic.com/Shop-For-Parts/a22b303d782009/Model-42A7072653E1-Briggs-Stratton-Small-Engine-Parts
May 30, 2017 | Briggs & Stratton Garden
Briggs
the pulley just bolts on
9/16 i think
may have to use pipe wrench to hold shaft of pulley
spray top of pulley with PB blaster should slide off might have to tap it some
May 01, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to know the weight of the motor oil
sae 30 in winter sae 40 in summer i preffer rotela
Aug 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How do I remove the pulley from the bottom of the crankshaft?
Crankshaft of what? I see a picture of a riding mower, is that what your working on? If so, you need a pulley puller. You can get one from your local autoparts store like autozone usually for a refundable deposit.
Sep 15, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I need to know how to remove the shaft with pulleys on it that comes out the bottom of the engine
the shaft you are talking about is the crank shaft. in order to remove it you must first remove all pulleys, drain oil, then remove the case bolts. slide case off of shaft then remove the connecting rod bolts. crankshaft should come out hope this helps
Jul 09, 2009 | Briggs & Stratton Garden
Garden Logo
257 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
