Hi my heating is mot firing up.Boiler IMMERGAS ZEUS MINI is not firing up, spark is working but is not firing gas, gas is turned on, pressure is 1.2 as should be. After reset yellow light is flashing then u can hear the spark and after 5 seconds of sparking u can hear flick ( sounds exactly as main trip switch) and red light is coming on ( is on constantly).
SOURCE: gas central heating boiler. insuffient water pressure.
u need to have a key (its like a T shape key) and u put that under the boiler its a hole in there, than u open the tap which is near this hole.
Manual here
http://www.worcester-bosch.co.uk/homeowner/literature/discontinued-boiler-literature/discontinued-gas-boiler-literature/24i-junior-rsf-discontinued-aug-2007-literature
All these machines need 0,8 bar minimum pressure for one.
When significant drop of pressure call qualified repair man.
If this is not your regular work you are at mortal risk.
SOURCE: flashing red light under ! on my worcester 24i junior combi boiler and pressure under 1
you don't have enough pressure in the tank you are using, needs to be a 2lb system to work properly it is starving the gas valve for gas
SOURCE: Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
SOURCE: hi, my ideal combi boiler mini HE C24 has lights
could be your microswitch check overheat stat and fan are o.k. best of luck
