We own a Brother EM 701 that will no longer type the right format characters. Changing daisywheel did not work.
  • Andrew Houle May 11, 2010
    Hi:
    Make sure that the pitch selector on the typewriter matches the pitch of the printwheel you are using.
    Andrew
I have a Brother EM 701 that hasn't been used very much. I will sell it to you.
Posted on Aug 17, 2009
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
Make a mark on the printwheel at home turn it off and on a few times and see if it stops in the same place each time if it dosen't the homing pawl spring needs to be replaced. you need a tech.
DickyO
Posted on Mar 16, 2009
Brother CM1000 is not working when typing a caracters return wrong one for example when "a" return "fr"?
for em-530
"Make sure your keyboard setting is correct. If using standard 411 daisywheel, the keyboard setting should be at KB I. It is also possibleyour daisywheel needs resetting. Turn the machine off for 10 seconds and turn back on. If the wrong characters continue printing, change to a new daisywheel. If problem persists contact your Authorized Brother Service Center.
Dec 04, 2013 | Brother EM-530 Typewriter
How can I get my typewriter back to its intial settings
There is no keystroke pattern to reset the EM series typewriter. There are two methods to reset this typewriter.
1.You can reset the daisywheel and remain on the same line of type, simply lift the top cover and then close it back down. The carrier will move to the left, reset the daisywheel and return to the last space typed.
NOTE: This will not affect the format settings (bold, underline, etc)
2.If you want to abandon the current typing position; turn off the typewriter, wait 10 seconds for the power supply to reset and then turn the typewriter back on. The typewriter will reset and the carrier will return to the beginning of the current line.
NOTE: Turning off the power will restore the format settings to standard default settings (bold, underline, etc).
Mar 15, 2013 | Brother EM-630 Typewriter
Cannot get symbols to display
" Make sure your keyboard setting is correct. If using standard 411 daisywheel, the keyboard setting should be at KB I. It is also possibleyour daisywheel needs resetting. Turn the machine off, wait ten seconds and turn back on. If the wrong characters continue printing, change to a new daisywheel. If problem persists contact your Authorized Brother Service Center. You may locate your authorized Brother service center bycontacting us as 1-800-284-4357 or visiting our website.
http://www.brother-usa.com/service/default.aspx"
WE CHANGED THE DAISY WHEEL IN OUR MACHINE & WHEN YOU TYPE IT JUMPS SPACES & TYPES THE WRONG LETTERS
First, be sure you are using a Brother compatible daisywheel. Some other manufactures' daisywheels "look" the same but the charters are in different order, so they will not function properly.
After changing the daisywheel you need to d a reset. Hold down CODE and press "Q" the carriage will do a little dance and your machine should be good to go!
Dec 23, 2010 | Brother SX-4000 Typewriter
When i install the new daisy wheel i cant get it set to type the correct letters
Dec 22, 2010 | Brother GX-6750 Typewriter
EM-530 - suddenly the "j"
If you have not changed the daisywheel, the next thing to check is that the wheel is correctly installed. The easiest way to check it is to remove and reinstall it. To do that;
1. Open the top cover.
2. On the right side of the hammer (the metal piece that strikes the daisywheel) there is a small lever (see attached figure). Pull that locking lever towards you to release it.
3. Remove the cassette that holds the daisywheel.
4. Reinstall it, making sure that you lock the lever towards the paper roller.
5. When you close the top cover the carriage (otherwise known as the print head) will move to one side and do a procedure known as "Homing."
6. Test the machine. If it is still mistyping, continue with the next part. Continued in part 2
Dec 19, 2010 | Brother EM-530 Typewriter
When I type it uses different letters
You will need to replace the daisywheel.
May 24, 2010 | Brother ML-300 Typewriter
Types funny symbols instead of the number I
The typewriter will print the incorrect letter, or the face of the hammer if it does not spin properly to the correct position. 1. Turn the machine offf for 15 seconds and turn ON, or Depress MODE RESET(the Q key). This will rehome the Daisywheel.I If it prints correctly for awhile then looses its' position, check for ribbon or correction tape interference with Daisywheel movement. If it does not print correctly as soon as you start typing, remove the Daisywheel and inspect the spokes to see if any are bent. Reinstall the Daisywheel and power ON. If the Daisywheel has a bent spoke or two, you can try to straighten them, howvever the cause of bent spokes is a concern. While typing, carefully watch the print hammer movement. It should always return to the same position and not move towards the paper until a letter is pressed. If it does not come to rest properly, the hammer is not in proper timing and may enter the Daisywheel while it is spinning to the character, thus causing damage to the Daisywheel or causing it to lose homing. .The hammer cams would require adjustment ore replacement. If bent spokes is a persistent problem, make sure to get the hammer problem repaired before buying a new daisywhel.
Dec 29, 2009 | Brother SX-4000 Typewriter
How do i type a percent sign O/O
The keyboard of the typewriter differs from country to country to adjust to special characters used in its language.
In the standard US keyboard the percent sign is in number 5 key. To insert the percent symbol you would use right or left [SHIFT] + number 5 key , provided you are using the standard daisywheel,
Download the Brother ML-300 Typewritter User's Manual to learn more
Nov 24, 2009 | Brother ML-300 Typewriter
Brother GX-6750 wrong characters problem.
Hi!
You are right. It seems that your daisywheel needs resetting. To reset it hold down the "CODE" key, while holding press the Reset key "Q" and then release.
If you are still facing the same issue or problem persists contact your Authorized Brother Service Center. You may locate your authorized Brother service center by contacting them at 1-800-284-4357 or visiting them on their website or even e-mail Brother Customer Service on the following link--
Brother Customer Service Centre
Phone Brother Customer Service:
1-877-Brother (877-276-8437)
9:00am to 6:45pm Eastern Time
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 28, 2009 | Brother GX-6750 Typewriter
89 people viewed this question
k24674
jasbo
jasbo
