Question about E-Machines eMachines T3830 PC Desktop
NEED POWER SWITCH WIRING FOR A EMACHINE T-3095
HI
I DID NOT CHECK FOR MOTHER BOARD FOR THE POWER LED,HDD LED AND POWER SWITCH MARKINGS BE FOR I TOOK IT APART.
JEFF
  • Matt H
    Matt H May 11, 2010
    We need to know what motherboard brand/model your E-Machines has installed. If the motherboard is still the default one from E-Machines, you may need to contact them to determin the board brand/model and get detailed specs for this board.
  • 320 Answers
Check on the motherboard there should be a small prints on it near control panel.
Posted on Mar 07, 2009
Look for orange 10 pins. pin1=Red (HDD LED) Pin2=White (HDD LED). pin3=NC, pin4=NC, pin5=NC. Next column pin6=NC, pin7=NC, pin8=Black (Power SW) pin9=White (Power SW) pin10=NC. Right next to 3 black pins are pin1=Green (Power LED), pin2=White (Power LED).
Posted on Apr 29, 2009
I need the wiring diagram for emachine model D6405
Usually it is in very small print right on the motherboard next to the pins, use a flashlight and/or a magnifier to see what order the pins go in. The hard drive light will say HDD, power will say PWR, etc.
Nov 26, 2011 | E-Machines eMachines Desktop PC
Just had to reatach my fan back over the processor but i took the mother board out and my wires came off the mother board which where for the power switch and the reset button, can anyone tell me which...
Hello Sir, hi, the wires on your casing are usually labeled, like in the picture below: cyberdyers_0.jpg
the power led green wire goes to the power led + and the white goes to the - . Now the HDD + goes to the HDD + the red wire, power switch can be interchange, same as the reset switch.
Dec 01, 2010 | Computers & Internet
I have a eMachine model c2685.i just need a pic for switch locations in the mother board.where the plugs from the hdd light, power sw, and thepower light plug into the mother.boardplease help
ok i might be able to help there is a motherboard swaping guide on youtube but there should be somthing like this on the motherboard ::::. the one closist to the single should be power ie ::: power: then . then its ::then reset then ::. then it should be hdd led so :then hdd led then:::. and the last is pwr light :<pwr led:<hdd led:<rst:<pwr.< blank hope this helps if it does then please give 5 thumbs up just remeber your looking for the : : : : . then follow my plan
May 15, 2010 | Computers & Internet
A power diagram for restoring power for a emachine
Hi there if you look real closley at the wires they are labled such as (pwr)led (reset) (hdd led )
(remote switch this the power for the computer) ect ect now look real closley and you will see the same markings on the edge of the board by each pin that they go to.. or you can also contact e-machines tech support and they will be able to help you out more if needed
best regards mike
Mar 17, 2009 | E-Machines eMachines Desktop PC
NO POWER TO THE MOTHER BOARD OF MY EMACHINE
The Wires goes on the motherboard, check your motherboard manual for reference
Mar 17, 2009 | E-Machines eMachines T3830 PC Desktop
Emachine model W2888, wiring
this is someone more suited for a trained technician, but you can look at the motherboard, where the pins were, and you should see markings like pwr +, pwr -, led +, led -, hdd_led, etc, you will also see markings on the cords that connect to the motherboard, with the same words, pwr+, pwr-, etc, you can try matching those up..
Jan 20, 2009 | Gigabyte GA-8IE533 Motherboard
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
GA-M57SLI-S4 wont power up !!! what to do !
Hi check the cables from the case to the mother board. They should be marked and the manual that came with the board ,this show you where to connect them on board The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] in most cases check to see if this is correctly connected
To test if there is no fault in the board or power pack. first visualy check the board to see if it shows a red led light when the power is turned on, if not the problem is in the power pack or the wall outlet.
second if the light is on, bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, check the processor and ram if not you have a faulty board.
Sep 17, 2008 | Gigabyte GA-M57SLI-S4 (4719331821180)...
New installation of mother board
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
Oct 05, 2007 | Select Brands System on board CPU / VIDEO/...
E-Machines eMachines T3830 PC Desktop Logo
993 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
