Question about HP LaserJet 4 plus Printer
I cannot get the printer to form feed, it only manual feeds, how
All of a sudden the printer will only manually feed not form feed, and I cannot get any of the buttons on the top of the printer to work
  • hpt77 Mar 29, 2009
    sam e problem but my screen works,,want feed from tray..what menu setting do i go to so i dont have to continue pulling the tray out,,will manually feed paper from tray in test mode
  • 463 Answers
I take it what you're saying is that you have to feed paper via flipping out the front tray and then pressing "online" or "continue", and that it will not feed paper from the actual paper tray?
You can try to take the beast apart and see why the control panel is not functioning, but I'd sit it on the curb, as it was probably manufactured sometime between 1993 and 1997. time to let the old girl die.
Posted on Mar 05, 2009
Why has it stopped printing manual feed?
Does the printer try to feed the page and does not?, or does the mechanism not engage at all. If it tries to feed and is unsuccessful then based on the age of the printer likley the manual tray pickup roller is worn out and the separation pad is likley bald as well. You can use the paper path test to confirm if the tray is working at all. That would really be the first place to start.
Aug 19, 2014 | HP LaserJet 4050 Printer
When printing back side of paper, paper turns sideways and tears in half.
see that u r feeding the oaper straight. Try to feed the paper manually instead from automatic feed. Also remove the curl of the paper form the top end by hand before feeding
Aug 11, 2009 | Canon imageCLASS D680 Laser Printer
Top of form fault
Top of form fault - I assume you hit "Feed" button and still got the form fault... if so:
1. check paper sensor position, sometimes just 1/8" one way or the other will make a difference.
2. calibrate the printer to the stock you have loaded - calibration is EASY, just press and hold the feed button until the printer cycles 8-10 times. Let go, should say "Calibration Complete". Hit "Feed" again to see if your top of form fault is fixed.
Jun 10, 2009 | Datamax M-4208 Thermal Label Printer
Brother mfc-7420 printer - manual feed instead of automatic
ok, thank you
you probably had a document that was not using 8.5 x 11 paper or the print settings were the printer to use the manual tray.
thanks adi
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-8440 shows "manual feed" and will not feed from tray
go to your cpu in the printer set up and tell the printer what you want it to do
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Paper jamming
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 13, 2008 | HP Photosmart 2575 All-In-One InkJet...
Paper feed problem
Good luck...
Sep 11, 2008 | HP DeskJet 6540 InkJet Printer
PRINTER FEED ISSUE
Jun 19, 2008 | Dell 924 All-in-One InkJet Printer
Paper won't feed
Dell.com will chat with you on-line to help you toubleshoot that printer.
Mar 31, 2008 | Dell 924 All-in-One InkJet Printer
HP LaserJet 4 plus Printer Logo
292 people viewed this question
Seeker5211
Seeker5211
