Question about KitchenAid Kitchen Ranges
Kitchenaid gas stove left back burner won't light. hear clicking
I have a gas kitchenaid stove.
The back left burner won't ignite.
It clicks but has no flame.
what do i do?
It's the 30 inch pro range model.
MOdel KDRP407
Actually my husband just switched burner with the one next to it and then it worked.
don't know what was different to make it work again.
Posted on May 16, 2009
I have a Kitchen Aid gas stove. All the burners will not light. No clicking, NOTHING. Is there a lighting switch or something that needs to be replaced ?? Or do I replace all 4 lighters ??
Posted on Jun 26, 2009
  • 638 Answers
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Posted on May 15, 2009
The igniters for the 6 burner are not sparking. The igniter for the griddle does spark. i do small gas when trying to light-how do I get to the spark modules
Gas Stove Top Burners Not Lighting / Not Working - YouTube
? 5:20
https://www.youtube.com/watch?v=dP3l5AW3YrI
Jul 19, 2012 - Uploaded by Bill Newberry
... not lighting. These are the 3 main reasons for gas range burners to not light. ... I see the igniter sparking but not lights up the gas. One thing I ...
Gas Stove Ignitor and Burner Not Lighting - YouTube
? 1:10
https://www.youtube.com/watch?v=1ZXz8_Md8hI
Nov 20, 2011 - Uploaded by Mike Klimek
Here is an easy fix if you hear the ignitor "clicking" but not lighting the burner. For more information, go to ...
How to Troubleshoot Gas Stove Burner Ignition Problems ...
homeguides.sfgate.com > Landlords & Tenants > Landlord Problems
Dec 19, 2015 | Kitchen Ranges
Burners won't light
That clicking is the igniter trying to spark. Turn on the burner and attempt to light it with a match. If you know gas is comming out, you will most likely have to replace igniter.
Sep 26, 2012 | GE WB13T10045 Gas RanOven Igniter Glowbar...
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
Frigidaire professional series gas stove does not light. When handle is turned the "clicking" sound happens, with the smell of gas but no flame. what could be problem? 3 other burners work...
A few months ago I lost one igniter on the left front burner. It clicks and gas flows but wont ignite.Now when I turn on the left back burner, the gas still flows but I hear clicking on the right side, not from that burner. It wont light either.
Dec 17, 2010 | Frigidaire FEF336BC Electric Kitchen Range
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
Gas was turned off and igniters keep clicking?
As I did not see what occurred, I suspect that the tea kettle boiled over and sent water into the burners. The igniters kept clicking and I eventually turned the gas back on. Will have to replace one igniter which apparently went out and have to light it manually at this point.
Dec 11, 2009 | KitchenAid Cooktops
Stove burners won't ignoite
remove a burner cover and while observing the burner turn on the ignitor listen to it click for that burner ; you should see a tiny lightning bolt like flash if you do not tun off the burner clean the area and, try again oil and grease coat the burner gas plate and isolates the ground that the spark needs to be able to "jump" to
Apr 26, 2009 | KitchenAid KGRT607 Gas Kitchen Range
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top burner Spectra XL4
rear left back burner clicks to ignite but doesnt
Feb 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
1,574 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
