Question about Vizio P2 42 in. HD-Ready Plasma Television
I have a vizio model p42hd type sp42a tv year 2004 or 2005 with blue line on one side that goes from top to bottum can some one help me
  • lmbart Mar 10, 2009
    I have the same model and type of vizio and the blue band comes and goes. I called vizio technical support and got no help. Is yours on the screen all the time.
prasumalladi
  • 12 Answers
SOURCE: Vizio sp42a
your tv is having a problem of more than one component .to get rid of the problem u should rectify your vif horizontal and vertical sections
Posted on Sep 24, 2008
SOURCE: Blue streak
trying to find problem tv is out of warranty
Posted on Oct 09, 2008
  • 289 Answers
SOURCE: ORANGE OR RED VERTICLE LINE DOWN RIGHT SIDE OF SCREEN?
hi..the probelm is due to the video circuit board.
only when you have a problem with the video
circuit board you will get such type of faults.so
you have to check the video board immediately.
check it out..
thank u..
rate me..
Posted on Feb 28, 2009
  • 147 Answers
SOURCE: VIZIO P42hd PS42a plasma
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Posted on Mar 30, 2009
  • 187 Answers
SOURCE: Vizio P42hd approx. 1" red line on screen, picture shifted
You will need to replace the control board and your TV will be better that a new one.
Posted on May 27, 2009
When I turn on my Vizio P42hd I get lines of different colors down the left side of the unit from top to bottom. Is this something that can be fixed? My email is mdrye@holtville.k12.ca.us
This problems is not causes by a person or some objects by hitting ur LCD tv picture screen panel?If,yes,by a person or an objects by hitting the picture screen panel.This tv is not repairable only can be by replaced the whole entire LCD picture screen panel only,sorry than this tv is not worth repairing.Because by replacing the tv LCD picture screen panel itself,will cost the same as a new tv.If these colors strips show up by itself,yes,tv it is repairable.The board call the T-Con decoders board is dead.This board sit right at the bottom right in the middle of the LCD picture screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Nov 22, 2010 | Vizio P42HD Television
Vizio P42hdtv10a has distorted blue and white
Very likely the power supply is failing.
Dec 01, 2009 | Vizio P42HD Television
Orange 2 inch line appeared on left side of screen ,then no pictu
it could be jusr a bad connection on th LVDS cable or your panel has died
have a tech check it out or send it to Tops Electronics in Haverhill ma
Nov 18, 2009 | Vizio P42HD Television
I have a hitachi tv model 42edt41 year 2004,2005
I have the same tv and had the same problem. I found a posting that stated to re-solder a connection on the cable for the "y" boards. I used this and my tv is perfect now. The part that needs to be re-soldered is the ribbon cables at the bottom of the tv that go from the boards straight to the screen. On the inside of this ribbon cables there are 4 small components that have "100" on them. On each end of each of these pieces, re-solder them. Since I had my tv completely apart I re-soldered all of them across the bottom. No problems now!
Oct 05, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
May 13, 2009 | LG 50PX4DR 50 in. Plasma TV
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
Mar 30, 2009 | Televison & Video
check it out..
thank u..
rate me..
Feb 28, 2009 | Vizio P42HD Television
Blue streak
Take it back to the store where you bought it you have a defective panel.
Sep 21, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio p42 type sp42a nov 2004 hd tv
POWER SUPPLY OR LCD PANEL INVERTER BOARDS . AVAILABLE THROUGH VIZIO , PARTSTORE.COM OR EBAY
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
Oct 23, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
204 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
