Question about Canon Office Equipment & Supplies
When I turn on the copier it gives me an E1 error code then it turns off. Is there any way to fix this.
Only by calling a technician
Posted on Mar 11, 2009
What does error code #e1 mean on Canon CLBP 460 PS mean?
Meaning of error code E1
The motor sensor or sensors, the DC controller on the main board DC controller.
I can not give solution to your problem, because possibility of damage main board.
I suggest you contact Canon Customer Support (e-mail, telephone, or repair contacts).
Nov 16, 2011 | Canon CLBP 460 PS Laser Printer
How to fix E1 error on samsung ER 5140
E1 is just operator error, it normally occurs when the wrong keys are pressed or the machine has got itself into a bit of a loop. At exactly which point does the message appear? is it when you press a certain key?
The first thing to try is an initial clear:
Turn the key to P
Press and hold SUBTOTAL
Whilst continuing to hold SUBTOTAL turn the power off... then back on
Continue to hold SUBTOTAL until the receipt stops printing
Turn the key to R and give it a test.
Nov 13, 2010 | Samsung Office Equipment & Supplies
E1 F5 Error Code RPD-305-PDS14 Whirlpool Double Oven. Woke up to code. Turn Off/On/Breaker and Appears to re-boot, until you turn the oven on, then 30 seconds later back to E1 F5. I replaced the whole...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$RTYH
Feb 12, 2010 | Whirlpool GBS307PR Electric Single Oven
I have gestetner 2722ztd copier when i replace the explosure lap the copier dispalys error code e1 on the screen .how i clean/remove the error massege ? please help me
Please check after replace the continuity the expo lamp,expo thermofuse.The E codes are displayed in the copy counter.To display both digits of the E codes press the enter key.
E 11 - Exposure lamp error.Possible cause: expo lamp open,expo thermofuse open,power supply defective,main board defective.
E 12 - Exposure lamp error.Posible cause:AC drive board defective,main board defective.
E 13 =Zero cross signal error.Possible cause:main board,power supply defective,zero cross line open or the conector on the main board is not conected correctly.
For reset turn ON/OFF the main switch unplugged wait 10sec and turn ON or:turn ON the main switch,turn DIP switch 101-1 ON/OFF and turn the main switch OFF/ON.The DIP switch is located in the rear parts into the main board.
Sep 20, 2009 | Gestetner Office Equipment & Supplies
Error mesege Showing E1
The E codes E1-E7 are displayed in the copy counter.To display both digits of the E code press the ENTER key.When the machine detect E13 condition E1 is displayed in the copy counter.Hold down the enter key and 13 is displayed.
E 11 - Exposure lamp error.In this case check the exposure lamp continuity,the thermofuse is open or power suplly board defective.
E 12 -Exposure lamp error .AC drive defective,main board defective
E 13 - Zero cross signal error.Main control or DC power board defective.
To clear the service code turn OFF/ON the machine.
Sep 09, 2009 | Ricoh Office Equipment & Supplies
Error Code E1-15 - can I fix this myself?
Most messages that state "call for service" are for instances where the unit is not running to prevent damage to the unit.
You should call an autherized or certified technician to work on the unit.
Apr 24, 2009 | Sharp AR-M237 Digital Copier
Lites on control board read ( L 5 ) when machine is turned on.
the e1 symbol is an engineering error code for an electronics malfunction (actually is senses the motor not turning and giving an error. The most likely cause is the motor control board
www.twincityrepair.com
Mar 02, 2009 | Landice L7 LTd Pro Sports Trainer...
ERROR E1-22
uve a problem with ur laser unit im affraid needs to be replaced
Jan 16, 2009 | Panasonic Workio DP-3530 Copier
Call service
Shows ASIC error. Unplugg the copier, wait 30 seconds and turn it back on again. See if the error appears. Does this error code happen when you turn it on or when you print something to it?
Aug 02, 2008 | Sharp AR-275 Copier
old marine
old marine
