Question about Plumbing
Freezeless yard hydrant constantly drains is there any adjustment
Thought I had a leak ground was wet around hydrant, dug a hole to see if line was cracked or hydrant busted and found nothing, turned well pump on and found that the weep hole at the bottom of hydrant keeps draining, is there an adjustment that I can make without changing entire hydrant?
  • 58 Answers
Bear with me. The hole is not a weep hole, but a drain. When you shut the valve off, the water in the pipe should drain out this hole so the pipe doesn't freeze. When you lift the handle the rod in the center of the pipe raises a hard rubber bulb that lets the water flow and covers the drain hole so it doesn't run water all the time. To service the valve shut the water off, take the handle pivot bolt out. Loosen the packing nut in the center over the pipe, screw it out, lift the guts, - handle, rod and nut, out of the pipe, now you can see the rubber bulb. Screw it off and go to a good plumbing shop or plumbing supply. Replace the bulb and put it back together. The nut in the center tightens a packing to keep water from leaking around the rod. Too tight and it is too stiff. Too loose and it will leak. Also, where the center rod meets the handle there is an adjustment that allows you to lengthen the rod a little so the bulb is pushed down a little more. Maybe this is all you need. Anyway, you just got the whole load of hay. You can also screw the top part off the pipe and you don't have to disassemble the head. Put gravel around the bottom so when the pipe drains the water can get out. Don't leave a hose connected when it needs to drain.
Posted on Jun 09, 2009
Handle won't lift up on my Woodford Yard hydrant model Y34
The flow adjustment on the hydrant could be turned to off, or the nut on the rod could be tightened up too much. This site has some good information on the woodford hydrants
May 05, 2014 | Woodford Frost Proof Yard Hydrant - Model...
Can i cut my yucca trees down and plant them elswhere in the back yard
Yes you can, just don't pull them out of the ground, dig around them and deep enough to keep most of the roots intact. Dig the holes where you want to replant them first before digging the yuccas out!!! Once you have your plant dug out replant it in the new hole as soon as possible, use some good potting soil to fill around it and water it.. Yuccas are very tough plants so you should be OK.
Nov 13, 2013 | Color Guard Yucca - Yucca filamentosa...
Rod stuck hydrant
Loosen the packing nut at the bottom of that rod that goes into the pipe/handle. Go to an autoparts store and buy a slide hammer. Unhook the handle from the rod and connect the slide hammer using any bolts etc that you have. Use the slide hammer straight up to free the rod. Tighten the packing nut back down to stop leaks, or DIG the whole thing up.
Feb 24, 2013 | Water Source YH-4 - 4 Yard Hydrant Is...
My frost free yard hydrant has stopped working. It's not leaking, it just doesn't work
Internally there is a long stem that operates a lever valve which is under ground. Which opens & closes as you pull open the handle, and push to close the handle.
The connection at that Rodney some sort, either at the valve or the handle has broke.
it might be able to be located? For repair, if not, it might be time to spend another $50 - $125 or so for another one. There are so many varieties and qualities. I personally would try for the repair, as the repair kits are FAR less expensive. You just have to dig it up and remove it. Then once repaired, reinstall. Just remember: Turn the Main Off.
here is an example of what a repair kit looks like...
Simmons Mfg 850SB Yard Hydrant Parts Kit
Jan 01, 2011 | Halex Liquid Tight 90 Degree Elbow, 3/4"
In the trunk of my vw polo, where the reserve wheel (tyre) is, I noticed a huge amount of water, about 5 lit. !!! (My back seat is constantly wet. First I thought it was because of an open-left window, but...
check the rubber seal that line around the trunk. and check to see if you have a drain hole on the outer side of rubber seal if so check for blockage, also the rubber is removable look to see if there is any rust preventing the rubber seal from sitting on lip snug.
Dec 06, 2010 | Volkswagen Polo Cars & Trucks
Clayton mark freeze proof hydrant
You are going to have to dig and replace the entire freezeless faucet. sounds like it either froze or rusted off.
Jan 22, 2009 | Halex Liquid Tight 90 Degree Elbow, 3/4"
Headlight adjustment
Make sure the bulb is correctly seated in the housing. I had the same problem with mine and it turns out the previous owner didn't seat the H3 bulb correctly so it wasn't lined up 100% so it wasn't getting aimed correctly within the projector.,,
Nov 10, 2008 | 2001 Ducati 748 S
Plumbing Logo
3,275 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
