Question about Acer Computers & Internet
My laptops making a noise as if the motors damaged
The laptop sounds as if the motors about to go.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    Describe the noise the best you can please.
  • 479 Answers
If u are getting too much sounds when ur laptop is idle then this might be the issue with the processor fan cleaning
Posted on Mar 05, 2009
Dvd player in my laptop makes a loud clicking noise but no picture or audio
Clicking sound? Hmm, sounds like the lens motor itself is going bad OR the lense itself is just SHOT. Depending on the model of your laptop, you can get a replacement off either E-bay or Amazon. Type in the model number of the laptop and just go like this: "DVD drive for (Insert laptop name and model here)."
Apr 03, 2014 | Dell Computers & Internet
I droped my labtop and has shaddered aperance and will not boot up
Take out battery, then remove the hard drives and get a new laptop
Dec 08, 2012 | Samsung 300E5A-A03 laptop
My Toshiba laptop P205D-S7802 is starting to make a sound like the fan motor is starting to go out. Can this motor be replaced?
Yes, it sounds like your CPU Fan is about to blow. Once it goes completely out and not turn on, your laptop will run hot and shut down. The fan is replaceable and they don't cost a lot. However your laptop will have to be completely disassembled to get to it and therein lies the cost. Get a quote from your local repair shop, then try these guys at: http://www.generalsystemsconsulting.com
They will repair it and ship it back via Fedex or UPS and their price will beat most quotes including the shipping.
Mar 21, 2012 | Toshiba Satellite P205D-S7802 Notebook
Laptop makes a clicking noise when it shuts down or sleeps
probably, the clicking sound came from your laptop HDD.
Its happen normally but sometime it means you hdd is has a little damage on it.
try to change it first.
Dec 03, 2011 | Computers & Internet
Loud shrill noise coming from my laptop, sounds like a smoke detector going off.
This sounds like a capacitor going bad on the motherboard.
Or could also be the max temperature setting in the bios has been reached.
Heat:
Make sure the laptop has good air flow and NOT sitting on your comforter.
Too many laptops die of heat stroke while in bed with it's user. :)
Check the bios temperature settings and google for the default.
Setting them a little higher can stop the shrill sound but too high and heat damage can occur.
It is a safe guard built into most PC's today.
Capacitor:
This must be serviced as soon as possible.
Motherboard if still under warranty will be replaced.
Good luck
Hope this helps
Sep 04, 2011 | ASUS Computers & Internet
My laptop charger, after about 1 and a half years of use, has begun to make a strange, high pitched noise and refuses to charge my laptop.
In most modern laptop chargers, this high pitched sound it emitted when a "safety switch" has been activated in the charger. It is possible that there may have been damage to one of the components in the charger. The only solution is to replace the charger.
Mar 30, 2011 | Sony Vaio PCG FR415S Laptop AC Adapter...
My notebook every once in a while makes a BEEPING noise, what does it mean?
This usually happens if you press the hot keys like 'shift' for more than a period of time.
Else if the sound is from the base of the laptop, it could be due to overheating, so keep the laptop in a flat surface when you are working on it. Else it cousl damage your motherboard.
I'm not aware of other beep sounds.
Mar 28, 2010 | Dell Inspiron Mini 10 Notebook
Strange noises coming from fan/hard drive area
no its not exactly a HD failure u need to remove the keyboard and look if something is stucking in ur fan...there might be the possibility of dust in it and even a minute thing can damage a lot..
cheerrss...pls rate..
Jan 04, 2010 | Sony VAIO CS Series White Notebook...
E6500 making a beeping noise
Does beeping noise happened before turning on laptop? If yes unplug the laptop from the AC Adapter. Just leave AC Adapter ON and connected to the power outlet. Check if AC Adapter is the one making beeping noise. Note: This is an issue with dell AC Adapter laptops
If no beeping noise in AC Adapter then proceed checking it from the laptop. Does beeping noise happened immediately when laptop is turned on? If yes then it might be laptop's hard drive creating the sound. Try to check the BIOS in your laptop under the category performance if the HDD Acoustic is ON either in Normal or Performance. Note: When laptop is in performance the hard drive makes noise due to its speed, this is normal if BIOS HDD Acoustic mode is ON to performance.
If the noise only happens when sometime while working on the laptop, this might be cause by the laptop fan. This also happens after turning on the laptop fan my have dirt and dust, please do check.
If fan was cleaned, HDD performance was checked and AC adapter was checked then, carefully sense if noise is coming from the internal speakers.
Download the latest BIOS update for your laptop then flash the BIOS. Make sure battery and AC adapter are connected when doing these.
Dec 11, 2009 | Dell Latitude E6500 Laptop
Motor bussing sound system slow
have a look at the fan on the processor if its running slow it will be making that noise so your processor is over heating and in turn making your pc run slow. replace this fan now. if your processor overheats too much it will burn out.
Apr 25, 2008 | Toshiba Satellite A15-S129 Notebook
Computers & Internet Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
