Question about Acer Aspire 4315-2963 Notebook
Noisy laptop my laptop is making a noise like the motor is noisy if that makes sense
  • 679 Answers
Either the casing is loose and vibrating, or a fan is starting to go, check it by just using the weight of your hand accross the base. If it still makes noise, you need to have a tech take a look at it, as you don't want it to overheat and burnout.If the cooling is impaired, the machine will get too hot and heat is the enemy of computers. good luck
Posted on Mar 05, 2009
  • 479 Answers
If the noise is always coming (when no application is running) then there might be the issue with the processor fan cleaning.
Turning the heat on makes lot of noise
If the blower motor is noisy, the bearing may be getting bad inside the blower. This will require replacement of the blower motor unit. In some cases, foreign objects can fall into the motor casing assembly also making a noise. The motor will need to be removed for inspection
Jan 14, 2016 | 2007 Nissan Sentra 2.0 SL Sedan
It make a whirling sound on the spin cycle
see the causes, and proceed with common sense, God bless you
Level
If it is shaking and not sitting flat ( should have no rock corner to corner) check the leveling legs. Make sure to tighten up the locknut after adjusting.
Timer
Sometimes a Timer will start making noises before they fail. I would highly suggest replacing the timer as soon as the noise develops. This can cause problems with your motor and other components if left alone. This is easy to identify just listen up near the console when running.
Transmission
The transmission does not usually fail but to check this on a direct drive remove the motor and rotate the inner tub and listen for noises it should be quiet. If not the transmission is expensive and you will need to evaluate wether it is worth repairing.
Motor Coupler
On direct drive machines this is a common failure and can be very noisy. To check and replace the motor coupler watch the video.
Motor
You will need to disassemble the washer to listen to the motor running. If the motor is noisy it will need replacing. On direct drive models check the motor coupler first.
Suspension Rods
The Suspension Rods support the tub under the cabinet on some models. The washer must be disassembled to access. These usually do not fail. On direct drive types there will be springs instead of suspension rods. Either usually fails but can from being overloaded.
Drain Pump
The drain pump can be the cause of noise. On belt drive types remove the belt and rotate the pump pulley it should spin freely and make no noise. If it is noisy replace. If it does not spin freely remove and inspect for obstructions if none found replace the pump. Check the impeller on the pump it should be tight and spin freely. On direct drive types remove the pump and inspect or replace.
Sep 22, 2012 | LG Washing Machines
Loud when spinning
see the causes:use the common sense . God bless you
Level
Timer
Transmission
Motor Coupler
Motor
Suspension Rods
Drain Pump
Sep 19, 2012 | Kenmore Oasis HE 27087
Banging noise when spinning
see the next steps and use the common sense: God bless you
Level
Timer
Transmission
Motor Coupler
Motor
Suspension Rods
Drain Pump
Aug 01, 2012 | Washing Machines
I've recently bought a new tga sonet scooter, it's very noisy, they tell me that they are a noisy scooter can anybody tell me if this is true.
Block the rear wheels up off the floor. Now put the sccoter in gear and let her rip! Is it real noisy? Did they replace the motor or the trans-axle on which th motor is appart of. If they replaced the entire assembly and its still making noise, thats what they sound like. Ive heard some of the scooters make a winning sound. Go to a place that sells this model and compare. My scooter is a Rascal 600t it makes some noise. It shouldn't be too noisy though. Its hard to tell from here.
Jul 12, 2012 | Electric Mobility Health & Beauty
Noisy dishwasher
It is the wah motor. contact Frigidaire for a replacement motor that has been redesigned to eliminate that noise
Feb 26, 2010 | Frigidaire Dishwashers
Maytag admiral refrigerator, the fan inside the refrigerator is making a loud sound when on and the cooling in the refrigerator is freezing
Makes sense, you are not moving enough air. Do not over fill the refrigerator. Fix the problem with the fan, if it is noisy I am 99% sure it is not moving enough air. To make noise something mechanical is hitting, it could be either the fan blade (cheaper to fix) or the motor.
Good Luck,
Gilshultz
Dec 01, 2009 | Maytag Admiral Top-Freezer Refrigerator
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Brand new pump that i bought it from store and i installed myself but it makes a distinctiv noise. emerson 230 v 1 hp.
is it the water going through the wet end or is the motor making the funny sound?
If the motor is sounding funny then you may have a bad motor. if the wet end is sounding really noisy then the motor may not be matching the size of the wet end as far as the HP. make sense? if your motor is bigger than the rating on the wet end it is pushing way too much water it is will be very noisy.
Jan 02, 2009 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Noisy manual gearbox
have you made sure it has oil in it
Sep 22, 2008 | 1992 Mitsubishi Galant
Acer Aspire 4315-2963 Notebook Logo
121 people viewed this question
Brian Sullivan
Brian Sullivan
