Who is your Internet Service Provider?
And What is name of the modem that you were using?
Try this:
- Connect your computer to any LAN port of the DI-604 router
Note:
Do not plug yet your modem to the router
- Open a browser to your computer and type in 192.168.0.1
- It will prompted you username and password box.
- Use admin for username and hit Ok without password
- Go to Home tab and select LAN at your left side
- You could see there the router's IP Address of 192.168.0.1
- Change the 0 to 2 and that would be 192.168.2.1 and click on Apply at the bottom
- Wait for about a minute to take effect the setting
- After a minute more you may connect the modem to the WAN port of the router,
- And after try to see if could get online
- Good luck!!!
yes i moved to different room, but i was setting up to play wow and they had me change some settings and now it don't go past the dlink.
quest dsl highspeed, modem- actiontec M1000
Contact your ISP. Depending on what you have, cable or DSL, there are sometimes issues with moving from one location to another. My brother attempted to move our DSL modem from one room to another and thought it would work but for whatever reason, it didn't and Verizon had to come move it back to get it to work correctly again.
Your ISP might simply have to update something on their end to recognize the new location. When you say "they had me change some settings", who are you referring to and what did they have you change?
When you say you "moved everything", do you mean you moved your setup to a different location in your residence or you moved residence?
