Question about Sony Handycam CCD-TRV67 Camcorder
Sony camcorder trv67 wont play tape or record
Sony camcorder trv67 will not record or play showing error code c31.41Sony Camcorder TRV67 showing same error code and it won't play. When a tape is inserted and the tape door is closed, the tape compartment won't go down into place without applying pressure. Eventually when I can get the compartment down in place, when I press "play" the error code C31:41 comes up blinking.
  • 24 more comments
  • slhalvey Mar 05, 2009
    Checking the latch door does makes sense, but how and what can I do to "tighten" the door if needed?
    I am VERY comfortable with taking apart a couple of things, but need to know what I'm looking for in the latch mechanism.
    Would this "bushing" also prevent the tape from "seating" all the way down as to where it should? I ask this because one time I was able to put pressure on the top of the compartment, then press play, and it worked.
    Still looking for additional advise before I pay to get it fixed
    I don't believe that it is moisture. The camera is always kept in a bag in a dry place and has never been used in the damp weather. The manual stated that moisture would have a different error code flashing
    Already tried that. Ejecting tape and removing power source several times did not resolve the issue
    Once again, I already tried the removing battery/power source several times Didn't work
    Yes I did hear shaking and "slapping". Was so aggravated last night already tried that.
    Will use that as Plan "B".
    would that be the same as the bushing?
    yes mechanism loads properly without the tape. Only once the tapes gets put in that it won't go down automatically without pressure. Once the pressure is applied I can get it to load tape and go down into place, but then it will not play, receiving the error code
    Tape is NOT jammed. Tried several different tapes in and out.
    I know that the error code does not exist...but the first part of code"31" indicates that it was a resetting the power issue that could be done yourself. Nope.....not it
    As I previously said, tried several tapes, so that isn't the problem; also yes it does go down without a tape.
    I thought that the "Sony" expert was going to send me some tech pics to fix the mechanism. I would appreciate that VERY much.
    once the cassette is in there and down in place is when the error code comes
    I'll check into the cost. It may be over five years old, but used very, very seldom. Kids aren't little anymore so might be worth it rather than another investment
    yet again, another opinion; thanks for checking code book, I'm hoping it's mechanical with the door latch/bearings.
    Sorry, new to this. I thought the only way you could help was by me reposting.
    I do still have the manual at home. (I'm at work).
    I appreciate any help you can give. Yes the camera is on the older side, but RARELY used. I'm now trying to copy all my tapes onto DVD of family movies.
    Thanks again
    still going to try other options before taking in.
    Dear welcomej.....please forward the additional info that you were willing to. thank you
    I am reposting since I was promised additional mechanical advise. Thank you
    tried battery removal...will try additional smacking
    don't know if drum is rotating. will I see it when tape is in and door closed?
    Also, the only way for me to get additional comments is to "repost". If I just "add comment" no NEW replies appear. Thanks
    whats the estimate cost of motor replacement?
    would the silver drum be rotating if it was the motor? Thanks for your input
  • 1,000 Answers
First, get a couple of cans of pressurized air. While you have the tape removed and the door open, spray the mechanism thoroughly trying to remove any dirt or dust. Disconnect the power supply or battery for 10 seconds. Reconnect power supply or fully charged battery and insert tape. Hopefully will work
If that doesn't seem to work, I have read in other articles for this model you can" shake " the camera vigorously and reload the tape and attempt to run the camera. Apparently the shaking has worked, probably dislodging foreign material from the drive mechanism.
Let me know if any of this works, good for future reference.
Good luck, let me know/
Best regards,
Posted on Mar 06, 2009
  • 54 Answers
Hi, thanks for using FixYa.
I have two solutions for that problem, I found out the first one long time ago in the Sony's website:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
The second solution might sound silly, but it worked great for me and apparentely for a lot of people too, as far as my research in the web:
Try smacking the side of the camera relatively hard with the palm of your hand (Not that hard to break it). Eject the tape and reinsert. You may need to do this a couple of times.
In my case seems like a gear was misaligned, making appear this error.
Good Luck!!!
Posted on Mar 05, 2009
  • 583 Answers
Instead of going foir new camera .get this repaired as its the error for faulty part in the camera .any how the parts has to be replaced and the camera needs servicing so get it repaired.this error is for mismanagement in internal assebly.take it to the local repair center and get the estimated cost as it will be negligible .instead of going for new.
  • 6,784 Answers
HI, i have check the code book and it has lead me to believe that this is a motor failure. you will have to replace the entire electrical motor in this device. again, this is electric motor failure.(c31.41)
  • 3 more comments
  • Michael Masters
    Michael Masters Mar 05, 2009
    its not mechanical unfortunately, its the electric motor. i just replaced my motor last year. i have the same model. its a factory flaw in the motor design.
  • Michael Masters
    $120. that what i paid. labor and all. your area may be different.
  • Michael Masters
    like i previously stated, i had my motor replaced and it works great. i thought it was mechanical as well but, it turned out to be the motor.
  • Michael Masters
    the motor is connected to the entire gear assembly and if it fails, nothing will work.
  • Michael Masters
    The motor in this model has two speeds. one for ejection/loading, and one for play and ff/rw etc...
  • 11,896 Answers
The way a camcorder and vcr's work is all based of timing. The door gears and the wheel motors are all synced together and controlled by a circuit board. If the door was ever forced open or closed where it may have skipped a tooth on the timing gear may have messed up the timing.
Another possibility is that there is an internal error either by control board shorting out or a bad sensor on the door latch. There is a bad communication between the door latch and the control board.
Usually when a big repair is done on any electronic equipment, you can always guess it's going to cost at least 1/4-1/2 of what it would be to get replaced. If the camera is not very old and has treated you well, then it may be worth repairing. I always say if it's older than 5 years, than it's not worth fixing.
Many repair shops will charge $10 to look at it and make an assesment and ballpark repair cost.
  • 7 more comments
  • Nate Stansfield
    Nate Stansfield Mar 06, 2009
    the little silver drum with plastic gear is the motor. If the gear doesn't spin, than the motor is shot.
  • Nate Stansfield
    about $40 for replacement
  • Nate Stansfield
    Nate Stansfield Mar 12, 2009
    The silver drum has a seperate motor . There are 3-4 motors in a camcorder. I would think it's the motor or the circuits in the main board. Either way it would be hard to repair unless you are familiar with electronics.
    Try playing, reversing, forwarding, without tape.
  • Nate Stansfield
    Nate Stansfield Mar 16, 2009
    You will most likely have to have either motor replaced, or an electronical board. It should be taken in to electronics technician to have this repaired. Components will have to be tested to determine exact cause of malfunction.
  • Nate Stansfield
    Nate Stansfield Mar 31, 2009
    I think the problem is with the mechanism. When the tape goes in it pushes a pin and lets the mechanism drop down and reads the tape. It sounds like it works without the tape but not when a tape is inserted. If I am accurate then you could look for the pin and manually press it in and out with your finger. i would also do the same with the mechanism. Also look for any broken or missing pieces. I have seen this problem many times with tape players. You can either grease it and work it with your fingers or get it serviced or replaced.
  • Nate Stansfield
    I believe either the spring or bearings to the mechanism is shot. If the tape is forced in mechanism wont set properly, setting off a error code.
  • Nate Stansfield
    Nate Stansfield Apr 01, 2009
    Around here it's about $40
  • Nate Stansfield
    Nate Stansfield Apr 09, 2009
    What was the result? Did my suggestions work for you?
  • Nate Stansfield
    Nate Stansfield Apr 22, 2009
    The silver drum is the motor. If it is good is should spin. It will be about $80-120 to repair
    Scholar:
  • 162 Answers
Sounds like the device isnt recognising your cassette, it is going to be a sensor which is only going to be replaced via going direct to sony and although they are really thorough they are also very expensive and you should ask about pricing structure before agreeing to even send it to them. sorry i couldnt be more helpful.
  • 158 Answers
Hello, I see that you are having a problem with your camcorder. How does the lid close with no cartridge in it? If it closes correctly try another cartridge. It may have a defect in the one you are inserting. If that doesnt help hold the power sitch down while removing battery. Wait two minutes then reinsert battery .Then when it powers up it should reset . Thank you
  • 15,935 Answers
Error code C31.41 is a malfunction of the drum mechanism. Either corrosion or worn gearing can cause this.
Try to free it up by hand first - as it may be seized up past the torque of the motor.... then re-try.
If it doesnt spin freely - the drive motor & transmission will need further inspection/replacement.
  • 916 Answers
This is a traction wheel fault it may need to be replaced.
    Brigadier General:
  • 5,158 Answers
The general consensus around the net is... believe it or not shaking it vigerously.... seems that some mechenism is stuck inside... not sure if that works but many say it does.
    Sergeant:
    Champion:
  • 224 Answers
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
    President:
  • 987 Answers
  • Eject the cassette and insert it again, then operate your camcorder.
  • Disconnect the power cord of the AC Adapter or remove the battery pack. After reconnecting the power source, operate your camcorder.
    Master:
  • 404 Answers
That error doesnt exist in sony's profile
can you makesure how it shows exactly
  • lotfi bouakaz
    lotfi bouakaz Mar 05, 2009
    to fix it
    tap it on the side whilst its on, bang is as much as you can in all sides and it should fix it
    it sounds crazy but there's a very tiny pin that needs to go back to its place inside.
    and hitting it seems the only fix.
    Scholar:
  • 165 Answers
The mechanism got stuck.
Open the cassette compartment screws and apply external DC to the Power input and eject the tape.
If this is not possible refer to a skilled technician.
for reparing estimates cost  of camera
http://www.advancecamera.com/repair
                     the link will help you toget the device repaired and serviced
·                                Free estimates.
·                                Reasonable rates.
·                                Fast, friendly, and personal service.
·                                Top quality repairs.
·                                Advance Camera 1 Year Warranty
    Genius:
  • 1,550 Answers
Solution for your problem :
Open tape deck, make sure there is not a tape in it.
About midway back there is a black rubber roller in the middle of 2 metal guides.
In the center of this black roller you should see a white plastic tube, this is a bushing to allow the roller to move with out wobbling.
If you do not see this white tube yours has fallen out, so the search for a new one begins. Don't freak out a straw for a can of compressed air will work, or from a can of WD-40 will aswell. Simply push the new straw firmly into the center of the black roller.
If you see the straw take a small flat head screwdriver and press down on the top of the bushing firmly, You can hear a click and problem is fixed .
Note if this does not fix the problem your bushing may be cracked find a pair of needle nose pliers and pull out the old bushing and replace it using the straw from a can of compressed air.
Hope this helps .
Source:forums.cnet,com
  • 10,594 Answers
It is mechanical problem in CCD-TRV67 camcorder.
I can help you out if you are conferable to apart camera and have knowledge of camcorder mechanism.
  • 4 more comments
  • Shahid Electronics
    Shahid Electronics Mar 05, 2009
    Good that you are comfortable in mechanism work.
    Let me know does mechanism load properly without tape?
    If yes, then there is some thing obstructing during loading while tape is in.
    I can provide you exploded view of tape mechanism, can give you guide lines about setting mechanism timing etc.
    Important info is about error code C31:41
    It is related to video head motor (drum) that is not rotating in your camera and reason can be some thing is stopping it or any circuit problem.
    Please put your hand in open tape compartment and try to turn head with finger and check does it spin freely.
    Below is an image of service manual of your camcorder. Let me know if you see my message to provide you technical help.
    If you stay with me then I can provide you continues help. When you reject my comments, that put me at last of long Que and I have to wait long to see your comments.
    I would request you to Do Not rate my solution as accept or reject until we solve camcorder issue. Just reply as comments.
    Thanks.
    Thanks, Please confirm when you put tape in camcorder, does its drum rotates or not? Error you mentioned is C:31:41 shows that drum (head motor) is not rotating, may be it is stuck or some thing (flap of tape) stopping it.
    let me know to move further.
    Alright, I give up!
    Can not assist you in crowd of 18 experts.
    Good luck.
  • Sony Master
  • 19,396 Answers
I think C31:41 is a mechanical error, I will check on service documentation.
  • Ginko
    Ginko Mar 05, 2009
    C31:41is tape jammed, try extracting the tape and putting it back in place, if this keeps happening that means that the traction mechanism has a problem, in that case the camera must be taken apart to fix the problem.
  • Ginko
    Ginko Mar 05, 2009
    C31:41 seem to be a traction problem, try gently playing with traction wheels inside the camera.
    Eventually follow the hints of the guy called welcomejee, he is a qualified sony repairer, and if he can help in fixing your problem remember to reward his solution .....unless you really have a problem with the door latch...
    Sergeant:
    Novelist:
  • 277 Answers
Check the door latch that is causing the error.
    Top Expert:
  • Sony Master
  • 63,661 Answers
Yes, I found a solution it is moisture. I found that by blowing a hair dryer into the cassette chamber for 10 - 20 seconds on "hot" followed by a further short period on "cool". The problem went away. There is, of course, a danger thet the heat could damage the circiut board components and ruin the camera for good. I had already decided to throw it away
My ccd-trv67 camcorder only comes on and works when i put it on charge otherwise it doesn't work how can i fix this?
Make sure that the battery is connected right and if it still has a problem try getting a new battery. After a while batteries stop holding their charge and need replacing. batteries can be found online or around 20$.
Aug 23, 2011 | Sony Handycam CCD-TRV67 Camcorder
Error code E:61:00
Yes it's a sony repair job, but theres a lot of people who have resorted to the following methods before they will part with $200 or so, the camera models are different but the method is the same :- http://www.fixya.com/support/t129748-sony_cybershot_dsc_s50_not_focusing http://www.fewin.com/sony/sony.htm
Oct 03, 2007 | Sony Handycam CCD-TRV67 Camcorder
I have sony ccd-trv76e handycam ,i want to transfer all movies i have recorded to my pc how can i do this.
Dear Freind ,
I am also using a good & nice product of Sony TRV 76E analog camcorder .I had converted all my hi8 videos to MPEG 4 format .
I am using a PC with Murcury TV capture card .In camera one AV out jack is available which is connected to murcury TV capture card .First it will recored in AVI format then you have to use one good video editing tool to edit & desird video format . I think your problem has resolved.
Thanks
Srinivas Nowduri
Hyderabad India
E Mail Id : snowduri@yahoo.com
Nov 11, 2010 | Sony Handycam CCD-TRV67 Camcorder
I cant seem to be able to transfer my recordings to a DVD recorder on my computer The video recorder is a Sony DCR-TRV22E.My computer is PRYON. PRY-i922vp
If the Computer is having Windows Vista installed on it then it's required to use a compatible i.LINK or Firewire cable to connect the Camcorder to the Computer.
Once the connection is established, you can use Windows Movie Maker to transfer videos from the Camcorder to the computer. Make sure that the Camcorder is set to the "VCR/VTR" or "Play/Edit" mode and the tape is playing in the camcorder before importing the videos to the Computer.
If you're having Windows XP on the Computer and using USB cable to connect the Camcorder to the Computer then it's required to install the USB streaming driver and the USB driver for connection on the Computer before you can establish a successful connection between the Computer and the camcorder for transferring videos.
You can install the USB streaming driver using the supplied Software installation disc.
Nov 07, 2009 | Sony Handycam CCD-TRV67 Camcorder
How do i record from the camera to a recordable dvd player?
I have a Sony DCR-TRV33E and i am having trouble recording the film onto a DVD on my computer. The computer is a Pryon. Pry -i922vp.Can you help?
Camera wont play or record has message c:31:23
Basically, the error message indiactes the reels are not turning, either because of a defective tape or a fault in the mechanism. Try a new tape. If the problem persists, you will have to have the camcorder serviced. please be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony Handycam CCD-TRV11 8mm Analog...
Transfer of video.
If model number is correct i.e CCD-TRV67, means its analog camera and can't not be connected directly ( USB ) with PC. Suggestion is to record movie on DVD by any DVD-Recorder to get analog signal in digital format. Now you can transfer it in PC.
Hope this info will help you and if you find it helpful, give vote as fixya.
Aug 18, 2008 | Sony Handycam CCD-TRV67 Camcorder
Wont record or playback tapes
There you go. Thats a good way to get the problem solved.
Aug 08, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Code 32:11 will not eject tape sony tvr67
The mechanism got stuck. Open the cassette compartment screws and apply external DC to the Power input and eject the tape. If this is not possible refer to a skilled technician. If you need the service manuals and mechanism for replacement write to us.
Dec 07, 2006 | Sony Handycam CCD-TRV67 Camcorder
Sony Handycam CCD-TRV67 Camcorder Logo
146 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
