Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Just bought a poulan pro 295 which was a new 2002 model, it ran 5 minutes and now it has no spark, whats up?
  • Anonymous Apr 03, 2009
    where is the fuel filter located
  • John McKinney May 11, 2010
    my guess is a screw rattled loose that holds your magneto on place. check this out and let me know. both point on the magneto should have about a .005 gap between them and the flywheel. let me know if you need any help in doing this, i am glad to help and maybe give you a visual to help. thanks.
  • 666 Answers
SOURCE: POULAN PRO 295: RUNNING VERY STRONG, FOR OVER AN
Remove the air filter, squirt a little fuel into the carb. Start and let run if it will for a few minutes. Could be you had some water in old fuel. and it is still in the intake of saw. If it still will not run after squirting some fuel into carb. You have a firing problem.
Posted on Apr 07, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan 295 Pro won't start. Changed gas and
I suspect the carburetor is full of remnants of the same fluids you found in the tank. If it was my saw I'd take it to the local Stihl dealer for an estimate to repair. I'd expect to pay $40 - 80 for a tune up and repair depending on how many fuel hoses must be replaced. HTH
Lou
Posted on Oct 28, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a poulan pro 295.I cannot remove muffler to
Hello Tom;
Look at the link "Engine Assembly" print. If your saw has multiple pieces like shown there is an additional internal screw. If not the only thing that comes to mind is remove the engine cover.
http://www.ordertree.com/modelinfo/PWE/PP295-Gas-Saw-Type-1/75.PP295-Gas-Saw-Type-1.1.59.1.html
There are other "PP295" saws listed here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 01, 2010
  • 6 Answers
SOURCE: Poulan Pro 295 won't keep running.
pull the black dust cap on top there are three screws going down, the idle screw is on the left side (if you were holding the saw) near the top of the carb it has a spring around it. the 2 weird screws under that are the mixture screws hi and low rpm you really shouldn't mess with those unless your sure of what your doing. if that doesn't work there is a really small hole ( and I mean small) in the bottom of the carb for a diaphragm if that gets clogged it runs bad, also vibration can loosen the cylinder bolt turn the saw upside down and there are (or should be 4 bolts) make sure they are tight if one already rattled out take the one kitty corner to Lowe's or a hardware store and get a replacement.
Posted on Mar 06, 2010
  • 4088 Answers
SOURCE: Poulan Pro 295 46cc chainsaw that won't start
Does the spark plug get wet with fuel when pulled through? If dry, try spraying a little starting fluid in the plug hole and reinstall the plug. If it pops at least once, you have fuel delivery problems--look for hardened/ cracked fuel lines. Clean the muffler arrestor screen. When the muffler is off, check the condition of the piston skirt and cylinder wall for deep scoring or obvious wear. Make sure the primer button (if equipped) is filling with fuel when pumped a few times. If it doesn't, make sure the bulb is not hard or cracked and check the lines going to and from it. Check the carburetor bolts and nuts for tightness. The fuel filter in the tank could be plugged, fish it out and check. If you have checked all these items, it may be time to clean and rekit the carburetor. Hope this helps!
Posted on Mar 08, 2010
Need diagram how to reinstall carburator on poulan 295 pro chainsaw
partstree.com or jacksmallengines.com I dont know if there ever was a service manual. I havent seen one
Mar 25, 2014 | Garden
Poulan pro 295
Not sure if this will work for you but I had a lawnmower with too much compression and my mechanic said i had put the wrong spark plug in which was too long and that caused too much pressure when trying to start I almost ruined the engine. I put the proper plug in and seems to work ok now.
Jan 06, 2018 | Garden
What is the file size (to sharpen chain) for a Poulan Pro 295 46cc?
I am pretty sure this machine ran a .325 pitch chain, so the file size is 3/16, if it is running 3/8 low profile chain ( 91 ) it will be a 5/32 file, the pitch should be marked on the bar .
Sep 16, 2011 | Poulan Pro Chain Saw 46cc 20"
My Poulan Pro 295 chain saw starts fine, runs for a few minutes, then stops and will not start until completely cool. What could be my problem?
It sounds very much loke the ignition is playing up when hot, just as a little test when it starts to die slacken off the fuel filler cap does it pick up/re start? if yes it is a fuel tank breather issue, replace the breather.
Apr 25, 2011 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan Pro 295 20 " chain saw that wont start.No spark from plug.Think the magneto is bad. Model no.952-051310 . Need opinion and part no. Thanks.
Do a basic test first, remove the top cover, pull the earth cut out wire from the terminal on the ignition unit ( this will iliminate any problems with the switch, or wires ) now try for a spark, remember that they work off speed of rotation so give it a good pull, make sure you use a good clean plug, well earthed against the cylinder. If there is still no spark, you will need to replace the unit, part no. 530039143
Feb 17, 2011 | Poulan Pro Chain Saw 46cc 20"
Apr 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Gots spark but won't start
If the engine is getting spark and you have tried starting fluid sprayed into carburator then it is not the switch as all the switch does is ground out the primary to kill the spark. It is now either the compression(lack their of) or the timing (Sheared flywheel key, for example)
Feb 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
137 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
