Question about Pyle Red Label 12" Square Subwoofer Car Speaker
Can you tell me the correct specifications for a speaker box for a pyle PLSQ12D want the best sound possible!!!!
  • blueextc3221
    blueextc3221 May 11, 2010
    best sound? or LOUDEST sound?
Hey found the answer to your question while looking for mine own, heres is the link to the pdf. it has all the specs from the company(pyle) dealing with the 10,12 square sub.
the info you are looking is under the category/ Vas (cuft.) which if i am reading correct to get the best sound you would need to build your box with 4.14 cubic feet. but look for yourself
http://www.pyleaudio.com/manuals/PLSQ10D-12D-PLW12DREN.pdf
Lance
Posted on Mar 25, 2009
How do I select speaker a or b on the Pyle PT26-A
Pyle products are aimed at the value end of the market. So features get omitted that are deemed "not important" in order to k=get to very low prices. One of these features is the Speaker A/B A+B button.
To implement that feature properly means doing some decent design in the power amp section to handle the switches in load. It also requires a stronger power supply and amplifier section with real guts. These are not Pyle strengths. They're built to a minimum specification.
So the answer is that there is no Speaker A/B A+B switching. Both sets of speaker terminals run all the time.
Sep 10, 2014 | Pyle Audio Players & Recorders
Pyle troubleshooting
probably something wrong with speaker
Sep 08, 2014 | Pyle Pro PPHP106A Powered Two-Way PA...
Pyle pcau44 amp
A fuse is blown, check main supply fuse.
Dec 22, 2013 | Pyle Audio Players & Recorders
How do i connect my av30 speakers to my Toshiba tv? I have tried everything and am unable to get sound from the speakers. I have 2 sets of these speakers and would love to listen to my tv with them. I also...
Connect left and right audio outputs on rear of TV to corresponding inputs on rear of your Pyle receiver. You may have to go to the initial set up procedure on your Toshiba TV to disable internal speakers and direct audio output to the Pyle receiver.
Dec 04, 2017 | Audio Players & Recorders
How to install, since it doesn't come with instructions.
Unless your speakers / boxes are specific for your car, there will not be any installation instructions beyond generalized that may include a wiring diagram, a chart to show how much volume your speaker box needs (minimum and optimum), power handling, etc.
Search for your model / part numbers at Pyle Car Audio and see what information is available there.
Sep 18, 2010 | Pyle Car Audio & Video
What is the volume required for a ported box?
If you take the height times the width times depth divided by 1728 will give you box volumes.
you can get a speaker book at radio shack that gives you charts as to a box with a certain amount of cubic volume it will tell you for a 2" port or a 3" port to cut to a certain length for a certain frequency.
the book is called building speaker systems
speakers for your listening pleasure.
the number of the book radio shacks number is
62-1087a.
H x W x D=
answer / 1728= cubic volume.
Jun 21, 2010 | Pyle PL1590BL Car Subwoofer
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
Speaker produces sound even when the zone is off
Since the Pyle speaker is a 4 ohm device, it's likely that when you have other zones on, the change in the impedance will affect the volume. Check to see what impedance your other speakers are (standard is usually 8 ohm), and if your tuner has impedance matching for your zones. If it does not, that's most likely your issue. You could get an impedance matching transformer at Radio Shack to resolve this issue. Please rate my solution, thanks.
Apr 17, 2009 | Pyle PWRC82 Main / Stereo Speaker
HOW TO INSTALL
I would say look for a custom box off ebay or build one behind rear seat. Im not shure if you can fit a small truck box behind there but you may be able to. It would sound pretty good behind rear seat. Hope this helps
Jan 13, 2009 | Pyle 12" 600 Watt Amplified Subwoofer Tube...
I have a Pyle PLD3MU head unit and a sony XM-ZR1252 amp (2 channel) and the car has 2 door speakers, 2 rear deck speakers, and 2 12" subs. What is the best configuration to hook this up?
Run your 12" subs off the amp make sure to Xover for bass only.
Try running the 4 speakers direct to the stereo may not be enough power, Might have to invest in another amp and speaker upgrade to get it sounding just right.
But its a place to start.
Jan 07, 2009 | Pyle PLDVIN7 Car DVD Player
Car Audio & Video Logo
207 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
