I have dried it out with gentle heat and recharged the battery, an orange and a blue light is shining but the camera is inoperable
SOURCE: olympus sp 350
Are you sure you finalized the firmware upgrade procedure according to the instructions? This sounds a little like you pulled the plug a little too soon... Have you done it according to these instructions: http://www.olympusamerica.com/cpg_section/OMfirm.asp And kept the camera connected until the update was 100 % complete? If you did everything right, try reseting the camera - take the batteries out for the day, and see if it helps. if you're back to step one(the reason you did the upgrade), try the firmware upgrade again. If still it doesn't work contact olympus, and I hope you have a valid warranty. Good luck
SOURCE: CANON POWERSHOT A300
If it's a short, not much that you can do other than try to track down the short location with a voltmeter. But I do have doubts that a short is causing this. The A300 is a notoriously power hungry camera. It's the first digital Canon to use two AA batteries. It takes great pictures, but unfortunately Canon didn't spend much time focusing on battery efficiency in getting the new two battery design out the door. As a work-around, try taking pictures by shutting off the display (press the DISP button) and using the optical viewfinder. Also the camera works best with high power rechargeable NiMH batteries rated 2500mah or better. Very inexpensive NiMH batteries are generally weak, and if no rating is shown on the package or battery, should be avoided.
SOURCE: camera that won't respond to button-pushing, yet lights up
Does this camera have a memory card? If it does, try removing it and than try turning the camera on. If this by chance does not work, it may need to be taken in for firmware repair.
SOURCE: Canon Powershot 870IS accidentally submerged in water.
when the camera falls in the water, only the power supply would have got bad, just take it to the manufacture, he will replace the power unit, it will work as good as the new one,, thank you,, plz rate me
SOURCE: canon camera sx10 IS battery dries out quickly
please use the batteries of the same spec. IE - 4 two 3000mA. please read the instructions carefully - they do mention that you have to use battiers of the same power rating.
