Question about HP Officejet 5610 All-In-One InkJet Printer
Cartridge error says cartridge error and won't let me print/. I put a new black cartridge in last week and it worked fine but is now giving me this error message. I have tried holdinmg down #6 key ok and cancel key and turning power off but still get error message
  • bu_salman_ Mar 05, 2009
    ارجو افادتي بكيفيت تحميل طابعة اتش بي 7313 اول ان ون
    Problem Solver:
  • 12 Answers
I have had similar problems with my "Older" R-series R60 and the jam was usually accompanied by a "grinding" sound from the printer mechanism. I found to be the problem was the cartridge drive belt/home positioning have been misaligned by usually inadvertive moving of the cartridge either when changing cartridges or whatever may prevoke movement. My resolution by accident, was repositioning the cartridge a little bit in either direction. And power cycling the printer until I found the position "Sweet spot" when no grinding is heard as the printer finds its home position. Maybe this will work for your unit as well if you encounter it again. It beats dismantling and still having the problem, right?
Posted on Mar 07, 2009
I keep getting " fit printer head " message when it is fitted and I have 2 new cartridges of colour and black and it worked fine last week
Hi Pete,
Ideally it should not give this error however there are few steps that can fix the issue.
I would like to direct you to a link that will be helpful for you in many ways to resolve most of your printer issues.
Click on this link -> Link
Regards,
Sean
Sep 16, 2012 | Canon PIXMA iP2000 InkJet Printer
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
When I turn my printer on it says that the type of print head is incorrect and to install a new one. I have never changed my print head and was working fine last week. I took the ink cartridges out and...
Hello.
Sometimes this is caused by the chip on the black cartridge. I know it sounds unusual but this chip is called the "master" and it identifies the series of cartridges and head to a table built into the printer. if a error is detected it can cause the message you are receiving.
If you have already removed the head, checked the contacts and replaced the cartridges, then try this link below. it may help re-set the printer. http://www.fixya.com/support/r9017204-resetting_ink_waste_absorber_error I hope this helps
Regards GM
May 26, 2011 | Canon PIXMA MP620 All-In-One InkJet...
I'm getting an error code 59.60 on our HP 3015 printer. Last week I had to change the toner cartridge because we were getting a smudge on one side of the print. Could this be related? A bad printer...
Error 59.60 is an issue with the black cartridge motor starting up.
Check that connectors J5006 on the black print-cartridge drive motor and J208 on the driver PCA are seated correctly. Replace the black print-cartridge drive motor. Replace the driver PCA.
Feb 28, 2011 | Office Equipment & Supplies
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Lexmark Z705 printer. I put in new ink cartridges
The BEST slution is GENUINE original cartridges. There is an eclectronic communicator on the cartridges and that "TELLS" the printer thet the current cartridges are not GENUINE ones. Untill you have replaced these cartridges with the GENUINE ones you will always get these error messages
Jul 08, 2009 | Office Equipment & Supplies
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Ink cartridge problem
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Mar 18, 2008 | Lexmark X6150 All-In-One InkJet Printer
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
90 people viewed this question
Ben Johnson
