Question about Saeco Gran Crema Espresso Machine
Where can I get a replacement for a broken pannarello - the plastic part on the steam wand? Thank you!
  • 1,618 Answers
Check with, they carry parts.
Posted on Mar 09, 2009
Steam wand on Vienna plus detached from arm
Lets first make sure you have all the parnello wand parts. The nut, hard plastic gasket, soft rubber gasket, the inner wand then the sleeve and the center in the sleeve. When putting it back together find the notch on the metal steam wand and slide the nut onto the wand, then add the rest in the order above.
Jun 02, 2012 | Saeco Vienna Plus Espresso Machine
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
The steam spout (pannarello) will not stay on
there is a rubber sleeve inside, and also a hard plastic olive (like a wedding ring). When tightened, the hard olive compresses the rubber sleeve and it grips.
If you lose the plastic olive, the rubber remains uncompressed and the pannarello will blow off.
The olive is about the size of a wedding ring for a person with a 5mm finger (impossible I know - but the shape is like a tiny black wedding band all the same.).
Oct 31, 2009 | Saeco VIA Venezia
How do you take off the Pannarello steam attachment to install the Cappuccinatore? Does it screw off or does the entire unit pull off. I've tried some force but I don't want to break the Pannarello. Thanks
Most pannarello's have a screw cap on top. The outer shell pulls off with a twist. Hold the inner stem and twist the cap on top to unscrew. Leave the cap and seals on the wand, or just loosen the cap and pull the whole assembly off complete, or you could loose parts that are inside.
Oct 24, 2009 | Gaggia Titanium Espresso Machine
Lost a piece of the black plastic steaming wand
Check with WholeLatteLove, yes I know the only have gaggia parts, its the same thing.
May 07, 2009 | Saeco VIA Venezia
Need replacement steam wand sleeve has parts and help for the sirena machine
Jan 22, 2009 | Saeco Starbucks Sirena Espresso Machine
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Apr 09, 2007 | Gaggia Coffee In White, White MDF...
Saeco Gran Crema Espresso Machine Logo
97 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
