Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
No power to Selections, Water Did Not Drain
By gcool on Mar 05, 2009
Our Whirlpool Quiet Partner II washed our load of dishes, but didn't drain out the water. When we noticed that the water didn't drain we closed the door and pressed the Drain Button. Nothing happened. Next, we tried to select other buttons but noting was functional. The door is latching properly, I checked the main breaker for the disherwasher and it did not trip. I removed the bottom panel cover of the dishwasher to manually drain.So now we now have a drained dishwasher with no power to it for any selection. I also turned off and then turned off the main breaker in an attempt to reset it. Did not work.Need help.Thanks.
Comments:
Mar 05, 2009
- I'll try this in a couple minutes.
Thanks!
Mar 05, 2009
- Sorry, not sure where to find the console with the thermal fuse?
Mar 05, 2009
- Model # DU943PWKB0
Mar 06, 2009
- Thanks again I found it and its toast. The part number on it is different though. It's 3376359, is the number you gave me the replacement #?
Mar 06, 2009
- Thank you so much! I picked up the new fuse tonight and have it running again!! $17 Canadian
Thank you again!!
Best Solution
posted on Mar 05, 2009
Helpful)
VersaStyle
Rank: Guru  Dishwashers  Expert
Rating: 96%, 295 votes
When you remove the bottom panel cover, check the wiring connection inside the junction box on the right for a loose or shorted wire.
If that's ok, open up the console and check the continuity of the thermal fuse that's clipped to the control board. Chances are it needs to be replaced.
Comments:
Mar 05, 2009
- The console is the front panel with the cycle selection buttons on it. Remove the top screws from inside the door and flip the console down toward you. The control board is to the right. The thermal fuse is a small white rectangular piece connected to the control board with 2 wires (black and black w/ white stripe).
Please post your model number if you can't find it. and I'll try to assist you further.
Mar 06, 2009
- Thank you for posting the model number!
Turn off the power to the dishwasher at the breaker. Remove the inner door panel by removing the screws around the inside of the door. Remove the control cover on the top right of the door. You should see the control board. On the side closer to you, you will see the thermal fuse which is a small rectangular plastic piece with a small fuse in it. In the case of your model, there should be a brown and brown/white wire connected to the thermal fuse. Remove the wires and test the thermal fuse for continuity. The part number is 675813, replace it if required.
Mar 06, 2009
- It's a new substitute part number.
You can get it at Sears.
Mar 06, 2009
- No problem, glad to FixYa! ;)
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
I hear good and bad about the Samsung DMR57LFS
Answer
Which is the best value tall tub quiet partner III whirlpool dishwasher to buy?
Answer
8700 series dishwasher. soap dispenser does not always open
Answer
how do I clean the filter?
Answer
It appears that the heating element is not heating the water...and the dishes are not clean..how... (More)
Describe your Dishwashers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
