Question about Dell Dimension 8400 PC Desktop
When installing a new hard drive the system bios recognize the drive. However, when I start to install Windows XP, the program does not see the drive as being present. How can I get the computer started again?
  • 4 more comments
  • gregathomas Mar 06, 2009
    I downloaded the following:
    document.write("Intel(R) Matrix Storage Manager")Intel(R) Matrix Storage Manager
    (6930KB)
    8.7.0.1007
    1/9/2009
    document.write("Supports SATA RAID 5/10 on specific desktop platforms, SATA RAID 0/1, AHCI, and matrix RAID on specific desktop and mobile platforms")Supports
    Read Me
    (txt)
    Release Notes
    (htm)
    OS:Windows
    Server* 2003, Windows Server* 2003 Enterprise x64 Edition, Windows
    Server* 2003 Standard Edition, Windows Server* 2003 Standard x64
    Edition, Windows Server* 2008, Windows Vista*, Windows Vista* 32,
    Windows Vista* 64, Windows* XP Home Edition, Windows* XP Media Center Edition, Windows* XP Professional, Windows* XP Professional x64 Edition
    Copied it to a disk. The file just say iata87enu Setup.exe. When I got to select S. I press S and the computer looked for the disk, but nothing happened. I had to Esc out.
    I am not sure I copied the correct file.
    By the way it is a Maxtor SATA drive.
    Leecom72,
    The major problem that I have with your solution is that the Dell Dimension 8400 doesn't have a floppy drive. I have another computer that has a floppy drive to create the files but no way to get it to the Dell. Any possible other solution?
    Leecom72,
    Yes I have a 2G USB stick.
  • mrninja
    mrninja May 11, 2010
    dont forget after you partition hard drive you need to format it
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Before we get to deep into it, take the hard drive out and check the jumper settings. If it is the only hard disk then it should be set to Master and should be the only disk on the SATA cable..if you have a CDROM or Floppy then it still should be set to master and other set to slave Let me know what you find out..and we'll take it from there.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
What type of hard drive is it. Sound like you put in a SATA hard drive. You need to load the drivers for that hard drive. During the Windows XP setup it gives you an option to load 3rd party drivers that what is sounds like you need to to.
Posted on Mar 05, 2009
  • 741 Answers
All of the above and you can also go to control panel/adm tools/disk management/click on the hard drive and click format..follow the wizard see if that does it..
Posted on Mar 06, 2009
  • Dell Master
  • 4,806 Answers
Hi there.
What you need is the "intel matrix storage manager". This is because your are trying to install XP on a SATA drive with intel chipsets.
Download the drivers for the correct operating system you want to install, which in your case will be XP , read the instructions carefully as you will have to create a floppy disk or USB pen that holds the drivers on them.
You will be told to press F6 to install 3rd party drivers during XP setup.
Get matrix storage manager here >>>>>>>
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2101
Good luck and thanks for using FixYa!!
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Mar 06, 2009
    Hi again.
    You should have these files downloaded>>>> txtsetup.oem, iastor.sys, iastor.inf, iastor.cat, iaahci.inf, iaahci.cat. Have you got these files? these are what you need to copy to a floppy disk that has been formatted in FAT.
    Let me know if you have them or not.
  • Lee Hodgson
    in that case you will need a USB drive, something around 64 meg.
    have you got a flash drive?
  • Lee Hodgson
    2GB might be too big but you can give it a try, format the flash drive in FAT and copy the files, txtsetup.oem, iastor.sys, iastor.inf, iastor.cat, iaahci.inf, iaahci.cat. onto it and plug it into the back of the PC.
    restart the PC and boot from the install disk, during initial setup look out for "press F6 to install 3rd party drivers" at the bottom of the screen, if you hit F6 in time it should load the extra drivers, if that doesn't work then you will need a USB floppy drive.
When i install the xp cd in my hcl b23 C2D laptop, the problem shown like this. setup did not find any hard disk installed in your computer\r\nhow to slove?
verify that the hard drive is seen in the system bios. If it is not, disconnect and reconnect the hard drive then try again...the drive must be recognized by the computer for windows to see it. If the hard drive is definitely seen by the system, check to see if the manufacturer of your system offers serial ATA drivers for the system. Load the driver on a floppy disk, boot to windows CD, press f6, load driver, continue with installation.
Apr 12, 2011 | Microsoft Windows XP Professional
Installed 500 gig drive with Windows XP. Computer only recognizes it as 127 gig.
You need to go to your computer manufacturers support-driver site and look your model up, then put in your operating system and search for drivers. In the drivers column, you need to find the download for an updated BIOS. Download this file and run its self-executable program and flash your systems BIOS. The new BIOS will allow your system to see large hard drives...right now your system has a limit of 132 GB.
Jan 15, 2010 | Western Digital Caviar SE16 (WD5000AAKS)...
I loaded a new, Windows XP formatted IDE in a 570e-then nothing
Well the formatting must have been different! try dropping the partition and format using the pc you are installing it on
Sep 07, 2009 | IBM ThinkPad 570E Notebook
Hard Drive Not Recognized
make sure all wire connections are completely pushed in. try going in to the BIOS and see if it reconized it
Mar 11, 2009 | ASUS P5RD1-VM Motherboard
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Got a new hdd 250gb sata the pc can't find it
I have the exact same system you have and have the same problem. Dell quit supporting that system as far as updates to drivers and BIOS updates before SATA drives became readily available.
The short answer is there is no way to boot to a SATA drive on that system that I have been able to discover. The BIOS does not recognize it as a bootable device.
What you can do is boot to a regular IDE (PATA) drive, install the driver for the SATA drive and Windows will recognize it. Place your Page file on the new drive and all your applications and data on the new drive.
It is not ideal, but I have managed to move the majority of files to the new drive and it runs quite well. You have to be diligent about installing new software to the new drive instead of the IDE drive.
There is a program you can buy for about $15 that will help you move applications that insist on installing to the boot drive called App Mover. I tried the free trial and it works quite well.
If you ever get a better answer, let me know.
Dec 28, 2008 | Dell XPS™ 600 PC Desktop
Gateway 450ROG only recognizing 7805 MB of 60GB hard drive
you may have to wipe that harddrive clean and start over new
Dec 12, 2008 | Gateway 450ROG Notebook
Reboot with new hd
Try Checking if your motherboards bios will recognize the hard drive. If not, Then the hard drive is probably damaged.
To access The bios, Most Motherboards open the bios when you press the delete key
If you have two or more hard drives then the settings of the jumpers eg. Slave,Master,Cable Select.
Because they might be conflicting with each other.
I had the same problem, But I tried installing XP Home edition on my secondary hard drive and it works.
But i need to insert my xp home install disc to get it the bios to recognize that windows is installed otherwise it goes " insert system disk and press enter"
Oct 11, 2008 | E-Machines (308714) Motherboard
Dell Latitude will not boot
Reseat the hard drive and then get into bios and check if the hdd is detected ,if not you need to replace the hdd ,if detected reinstall the OS.
Apr 03, 2008 | Dell Latitude C600 Notebook
Hard disk not recognized when reinstalling xp
try formating the drive using fdisk in fat32, you can find this program in windows 98/98se and Me them try instaling windows xp
Nov 10, 2007 | Compaq Pentium 4 , 1.5 GHz (244318-B21)...
Dell Dimension 8400 PC Desktop Logo
406 people viewed this question
Alun Cox
