Question about Inter-Tel Encore Phone
Admin changes on encore cx
How do i connect my laptop to encore cx for programming ?
  • 3 Answers
You can actually do the system programing thru the phone itself, press the prog button above the display on the phone & go to system programing, you'll need the system admin code (try 1111).
Alternatively you can install a programing applicatrion on your pc & connect to the async port on the main control unit. The program applicaion would have been delivered with the system docs.
Posted on Apr 17, 2009
After trying to connect my mac laptop to ethernet suddenlink had a failure at the same time. NOWI CAN NOT OPEN THE ROUTER OOR ANYTHING. jim FOUTTY
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Linksys WRT160N Wireless Router
New password wifi
Sep 07, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
HELLO My problem is that I cannot enter to the configuration of router, that is to say which is the direcion of ip and to come in the explorer up to where he asks for the login me of which the defaul is...
Hi - I suspect that you may possibly be attempting to log on to a different router than you Encore ENHWIN3. This can happen if you're trying to access it wirelessy or if this router is connected to a LAN port of another router "upstream".
1) Power off the cable modem or DSL modem, Encore ENHWIN3 and the computer(s).
2) Connect the first network cable to the LAN or output of the cable modem or DSL modem.
3) Connect the other end of the first network cable to the WAN jack of the Encore ENHWIN3.
4) Connect the antenna to the Encore ENHWIN3.
5) Connect a second network cable to any one of the numbered LAN jacks on the Encore ENHWIN3.
6) Connect the other end of the second network cable to the computer's network jack.
7) Power up the cable modem or DSL modem, and wait 30 seconds.
8) Power the Encore ENHWIN3 and wait 30 seconds. The red power LED indicator should be on. The WLAN (Wireless LAN) should also be on or flickering. If the DSL or cable modem is passing data, the WAN light should be on or flickering.
9) Reset by PRESSING AND HOLDING THE RESET BUTTON IN FOR 10 FULL SECONDS.
9) Power up the computer that is connected via network cable to the Encore ENHWIN3. Wait for the boot process of the computer to complete.
10) After login to the computer, the LAN port number associated with the connected computer should be lit up or blink green on the front of Encore ENHWIN3. If the LAN piort number is NOT lit or flickering, remove the cable from that numbered LAN port and reconnect to a different LAN port. The new LAN port number should light as described above.
11) Open your browser (IE, Firefox, Opera, etc.) and type 192.168.0.1 into the address bar. Supply the default username "admin" and password "admin" to access and change the defaults of the router.
You can view the manual for the router here. I hope this helps and good luck. Please rate my reply. Thanks!
Jun 27, 2011 | Encore ENHWIN3 Wireless Router
Can't open setup page from Encore ENHWI-N3
The best way to open the setup page is to have a wired connection to the router. Once you plugin the router to both the modem and the computer, you want to reboot everything. After you've established a connection, open a browser window and go to 192.168.0.1. To login to the setup page, enter admin for user and admin for password. From there you can change your password and setup the secured wireless networking.
You should also be able to try this wirelessly, but you must be sure that you have selected the Encore network on your computer's wireless control panel.
Jun 20, 2011 | Encore ENHWIN3 Wireless Router
What is the device password for encore wireless-N router ENHWI-2AN3? I cannot connect because of this device security password. It says that i should see it on the device or any printed information but i...
normally the password is in BACKSIDE of the device, or in the users manual. But, sice i have the same router, the username password combo is; username : admin password: admin
Apr 06, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
What is the 8-digit default pin of my encore ENHWI-N3 router
I'm assuming you mean the IP address to access your router to change some settings
the default addresses for routers are usually depending on the brand
192.168.0.1
192.168.1.1
192.168.2.1
try each IP individually, you will be prompted with a username and password, unless you have changed it, they are usually
admin
admin
admin
password
Mar 20, 2011 | Encore ENHWIN3 Wireless Router
Renew password
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.1.1
or
http://192.168.0.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then WPA Security then not down code .It is your password to connect wi fi..
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 22, 2010 | Encore ENHWI-N2 802.11n Wireless Router...
Problem with Encore 802.11n Wireless Router ENHWI-N2
Well a router that supports 802.11n will also support g.
In any case I am under the impression that your DNS settings might be wrong.
A good router to look at are D-Links, I have been using the DIR-655 for my house see: http://www.dlink.com.sg/products/?idproduct=21&idCategory=175
Enjoy
Nov 30, 2009 | Encore ENHWI-N Router
Speaker phone indicator will not go off
Liooks like you have the phone programmed to "Handsfree answerback" this will cause the handsfree light to flash continiously.
In this mode the phone will auto answer any internal call from another extension.... so watch out.
To switch this mode off press the program button above the displey & you be given th option to switch "Auto Answer off " I think it's the first option, try it.
Jan 07, 2009 | Inter-Tel Encore Phone
Inter-Tel Encore Phone Logo
213 people viewed this question
Top Inter-Tel Lands Phones Experts
george  peters
george peters
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
