Question about JVC AV-32D502 32" TV
Is this TV HD capable?
JVCTV #AV-32D502 a 2002 model- might buy but it needs to be HD capable because we have direct TV HD pack- will this work?
  • sheri_mclend Mar 05, 2009
    In less then 15 minutes I got my answer. Clear,concise and not just to the point but with added info about what I should look for. I already turned 4 people onto this site. Thankyou
  • 463 Answers
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Posted on Mar 05, 2009
Dx-L321-10A: M-B315AA on direct tv. Can't get HD. Says restricted. Tried comp. No good, haven't used HDMI. Do I need Digital? Thanks for your time.
These are directly from your users manual:
  • Built-in HDTV tuner: Add HD-capable antenna to receive over-the-air high-definition broadcasts, where available. Optional set-top box required for high-definition cable or satellite programming
  • 2 HDMI inputs: Provide an uncompressed all-digital audio/video link for the highest quality connection and support copy-protected HD broadcast content.
  • you need to do one of 2 things to get HDTV on your device. Either attach an HD- capable antenna or attach an HDMI cable from your satellite tv providers box. Good luck.
Aug 03, 2015 | Televison & Video
I have a Model D12-100 flat-screen TV, hooked up to DirecTV. I have lost my TV remote and have lost the signal for DirecTV. How do I get the signal to the HDM1 or HDM2 category without the TV remote?
First off, D12-100 is your direct TV Box, Not your TV. A D-12 -100 direct tv box is not an HD box and will only connect to your tv via a coaxial cable or av jacks (red, white, yellow).
If you have lost your remote for your tv and your direct tv remote does not operate it, then you should be able to find the manual buttons on your television somewhere along the edge of the screen.
Toggle inputs till your on "TV" then use the channel selection to toggle it up or down till it's on channel 3 or 4 for Direct tv, If that doesn't work toggle inputs again and try the AV inputs. And of course if you want to use another device toggle inputs to HDMI 1 or 2.
Jan 05, 2015 | Televison & Video
JVC av-32360 HD compatible?
It should be. I have the same TV as you, and we have used Dish and Direct TV for years.
Dec 03, 2011 | JVC AV-32360 TV
I have a 27" JVCtv
If your picture is good but there is not sound, change the Eeprom. To get another one recorded.
Mar 24, 2011 | JVC AV-27720 27" TV
I have recently gotten a Sharp AQUOS Quattron (LC52LE810UN). I have a rogers cable box with a RCA input, but the tv doesnt not have an direct RCA input. It has a input for an audio cable with a component...
Your TV is a High-Def TV (HDTV) therefore you need a Rogers cable box and service capable of High-Definition in order to get the HD resolution you paid for with the HDTV. HD video requires HDMI or component video cable connections. Standard RCA AV (yellow, white, red) will not show HD video.
Having said that, you may want to hookup a game or VCR to the TV and therefore you will need to get a cable known as an AV miniplug. It has RCA (3) on one end for the VCR for example and on the other end is a Mini-plug to connect to the HDTV (Sharp). This cable is like the ones used on camcorders such as Sony. Make sure you get a cable with the right ends as depicted in your manual on page 14.
You'll have to Google online for a supplier. Sparco.com had these cables but are out of stock currently.
Jan 17, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
We switched from cox Cable to Direct TV. The BD390 works normally through an Apple Airport Express with an Ethernet connection to a Motorola SB 6120 modem. The system does everything it is supposed to...
So practically you want to use the BR390 as an access point, to route the data from the Apple to the DVR. No, this isn't possible since the player doesn't have routing capabilities.
But you can do something else: instead of the Apple (which is just a very simple router with some minor extra capabilities sold ad an outrageous price) you could get a way better normal router for a lot less than $100 and connect all devices thru LAN cables in an local network.
Aug 17, 2010 | LG BD390 Blu-Ray Player
Can you connect the handycam directly to a tv to watch.
Analog Audio/Video Output(s) : Yes (Multi A/V) S-Video Output(s) : Yes (optional accessory)
you might have to buy the proper cables. Also the TV will have to have AV input capability or your stereo receiver.
Aug 08, 2010 | Sony Handycam DCR-SR40 Camcorder
HD screen split into 3 small screens!
The source display is set wrong. You'll need to disable 1080p on the source and/or limit it to the display capabilities of the set.
Apr 22, 2010 | RCA HD52W56 52" Rear Projection HDTV
Can I set the default input?
some tv model has a setting that every time you switch on the tv the set will back on the last customer setting, other tv does not support this setting. But if your tv works as i mentioned earlier during the first time you buy it. Meaning the IC memory is malfuntion.
Jun 14, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
JVC AV-32D502 32" TV Logo
235 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
