Question about Sylvania 6313CB 13 in. TV/VCR Combo
How do you manually crank the load motor assembly and where is the crank located?
  • 1 more comment
  • fh875 Mar 05, 2009
    A diagram would help and I can't get anywhere from the Sylvania website. My VHS tape is broken and the tape cassette is hinged open and up against the two back pins. I'm suppose to be looking for the cassette tray release pins and "hand cycle the carriage". I need to see a diagram of all the aforementioned parts.
    O.K. --- I'll try that --- never heard of "Funai"!! Cheers, Val.
    So much for Funai --- manuals only from 2002 and mine is 2000!!
    I have a basic diagram but doesn't explain which way the roller moves. I'll have to study my info later so I can remove the cassette and put my TV/VCR back together and hope it still works. If you needed to know how to apply a watercolour wash in painting, then you'd know what it's like to be out of your field!! Cheers.
  • 463 Answers
The load motor usually actuated gears that are oriented vertically and on one side of the tape intake cage. If the unit is apart, it should be obvious where they are.
Posted on Mar 05, 2009
  • Rob
    Rob Mar 05, 2009
    I don't have a diagram, but did you try the funai site? That is who "made" your television.
Blown fuse
There is a thermal fuse in the circuit between the dryer drive motor, and the dryer timer motor (control). It's physically located near the blower assembly. Whirlpool 33001762 Thermal Fuse AppliancePartsPros com There is a picture of it at this link. That's the only "fuse" I could find in the parts manual I have for the MLG2000AWW.
Feb 10, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
Sunroof stuck
VW sunroof come with a manual crank tool located inside the sunroof motor assembly behind the cover. Use that to manually crank it back to the stowed position and have it checked for cause of malfunction.
Nov 19, 2013 | 2003 Volkswagen Eurovan
Sunroof stuck open, think the switch maybe bad
I have same problem. Below are a couple of suggestions from on how to close the sunroof manually. The first relates to a '93 and I'm not sure about the second. Use this info at your own risk. If you get a better answer, PLEASE POST IT HERE FOR ME. Thanks. Mort
Here is the text from my 93 Manual. There is an access panel in the rear centre of the headliner if it is the same as my 93.
Manual Operation
To close the sliding panel manually, remove the roof access hole trim panel located at the rear of the moon roof assembly. Remove the motor and bracket assembly as outlined to expose the splined shaft of the moon roof drive gear box. Using a typical corporate door window regulator crank handle properly set on the splined shaft, crank the moon roof panel closed.
It is recommended that the battery ground cable be disconnected when removing or installing the moon roof motor assembly.
Removal and Installation
1. Operate glass panel until rear of glass panel is flush with sheet metal surface.
2. Remove motor access cover.
3. Remove two motor retaining screws.
4. Lower motor away from splined motor gear and disconnect electrical connector.
5. To install, reverse Removal procedure and synchronize motor as outlined under Adjustments.
Good Luck! __________________
Current:<P>1995 Town Car Executive 80K Miles<BR>1990 Mustang LX 2.3 Auto 62K<BR>1985 Chevrolet Caprice Estate Wagon X 2 (160K & 100K)<BR>1983 Chevrolet Caprice Sedan<BR>1984 Renault Turbo Fuego 60K<P>Past<BR> <BR>1980 Oldsmobile Cutlass<BR>1980 Chevrolet Citation<BR>1974 Triumph Spitfire<BR>1968 Triumph Spitfire<BR>1957 MGA<BR>1966 Renault R8<BR>1966 Renault R10<BR>1974 Chevrolet Malibu<BR>1968 Pontiac Firebird<BR>1966 Honda S600 Converible w Hardtop<BR>1978 Bobcat<BR>1969 Buick Last edited by Thanet; January 8th, 2007 at 07:07 PM. #3 post_old.gif January 8th, 2007, 07:26 PM Bill M. user_offline.gif Registered User Join Date: January 8th, 2007 Location: Boston, MA Posts: 3 reputation_pos.gif Moonroof Woes Thanks for the moonroof help. I might be getting a switch in the a.m. If not that remedy doesn't sound too bad. Bill M. #4 post_old.gif January 8th, 2007, 09:49 PM image.php?u=18244&dateline=1141618175 Tman70 user_offline.gif Moderator Join Date: July 26th, 2004 Location: New York Posts: 2,757 reputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gif 1. Remove the roof headlining access hole cover located at the rear of the roof headlining.
2. Remove the sliding roof panel motor as outlined to expose the splined shaft of the sliding roof rail and guide.
3. Crank theroof sliding outer glass panel closed using a typical corporate door window regulator crank handle properly set on the splined shaft.
4. After performing these operations, remove crank handle and retime as outlined. Refer to «Adjustments, Motor Synchronization (Timing)» .
5. Install the sliding roof panel motor.
6. Tighten to 4-6 N-m (36-53 lb-in) and install roof headlining access hole cover. __________________
Aug 15, 2011 | 1997 Lincoln Town Car
Were is the crank position sensor located on a 98 accord lx 2.2 motor?
There is no 2.2L motor in a 1998 Honda Accord.
The Crankshaft Position Sensor for the 2.3L 4-Cyl. engine is located behind the crankshaft pulley on the oil pump assembly.
May 10, 2011 | 1998 Honda Accord
I'm looking for instructions on how to replace the window wiper motor and switch
Windshield Wiper Motor Removal & Installation To Remove:
Using the J 39232, remove the wiper transmission from the wiper motor crank arm. gmpc_wa_1.gif
  1. Remove the wiper arms
  2. Remove the air inlet grille panel.
  3. Disconnect the connectors from the wiper motor assembly.
  4. Remove the three screws and the wiper drive system module.
  5. Using GM special tool J 39232 or equivalent, separate the wiper motor crank arm from the wiper drive ball joint.
  6. Remove the wiper motor crank arm from the wiper motor.
    • Remove the rubber boot.
    • Loosen the mounting screw.
    • Tap on the screw with a plastic or leather faced hammer while supporting the wiper motor crank arm.
    • Tap the screw until the crank arm is loose.
    • Remove the screw and crank arm from the motor.
  7. Remove the three screws and separate the wiper motor from the module assembly.
To Install:
  1. Position the wiper motor on the wiper drive system module assembly. Install the three mounting screws. Tighten the screws to 62 in lb (7 Nm).
  2. Install the wiper motor crank arm on the wiper motor.
    • Connect the wiper motor electrical connector.
    • Turn the wiper switch to the accessory position.
    • Turn the wiper switch to the pulse position.
    • Turn the wiper switch off when the wiper motor is in the middle of the wipe cycle.
    • Disconnect the connector from the motor.
    • Maintain a gap of 0.157-0.314 in (4-8 mm) between the wiper motor crank arm and the bracket tab. If the gap is not 0.157-0.314 in (4-8 mm), remove the wiper motor crank arm and repeat installation.
    • Install the mounting screw. Tighten to 142 in lb (16 Nm).
    • Install the rubber boot.
  3. Position the wiper drive system module on the vehicle. Install the three mounting screws. Tighten the screws to 68 in lb (10 Nm).
  4. Using GM special tool J 39232 or equivalent, connect the wiper motor crank arm to the wiper drive ball joint.
  5. Connect the wiper motor assembly electrical connector.
  6. Install the air inlet grille panel.
  7. Install the wiper arms.
  8. Check the windshield wiper operation.
Oct 28, 2010 | 1999 Buick Regal
The starter has been tested as good, but the car wont start, any ideas?
load test battery
check for tight, clean connections at battery
check neutral safety or clutch safety switch
check starter relay
check ignition switch
check engine and chassis grounds,
below is from the site. click on red X's to view files
Four types of starter motor are utilized depending upon the vehicle transaxle and assembly plant location. Manual transaxle equipped vehicles utilize a conventional starter motor which consists of a yoke, an armature assembly, an overrunning clutch assembly, a solenoid, a commutator end cover, a brush holder and a pinion drive lever. Automatic transaxle equipped vehicles utilize a reduction type starter motor which has, in addition to the components found on conventional starter motors, a reduction gear and shock absorber assembly.
In the basic circuit, the solenoid windings are energized when the ignition switch is turn to the START position and the clutch start/neutral safety switch is closed. The resulting plunger and shift lever movement causes the pinion to engage the engine flywheel ring gear. This movement also causes the starter solenoid contacts to close.
With the contacts closed, the starter solenoid provides a closed circuit between the battery positive terminal and the starter motor. Because the starter motor is permanently grounded to the engine block, the circuit is complete and cranking occurs as soon as the starter solenoid contacts are closed.
When the engine starts, the pinion is designed to overrun and protect the armature from excessive speed until the ignition switch is released from the START position. With the ignition switch released, a return spring in the solenoid assembly forces the starter solenoid contacts open, breaks the circuit between the battery and the starter motor, and disengages the pinion. To prevent prolonged overrun, the ignition switch should be immediately released upon engine start-up.
See Figures 1 and 2
Fig. Fig. 1: Electrical system diagnosis - No cranking condition
Fig. Fig. 2: Electrical system diagnosis - Slow cranking condition
Oct 15, 2010 | 1994 Geo Metro
Replace wiper motor
Wiper Motor
  1. Remove the wiper blade and arm assemblies, as outlined earlier in this section.
  2. Turn the ignition ON and the wiper switch OFF so the wiper motor returns to the park position.
  3. Disconnect the negative battery cable.
  4. Unfasten any necessary retainers and remove the air inlet screen assembly. Disconnect the washer hoses.
Remove the air inlet screen retaining bolts/screws ...
... then remove the air inlet screen
Disconnect the windshield washer fluid hose(s)
  1. Disconnect the wiper arm transmission drive link from the crank arm using a suitable wiper transmission separator tool.
There is a special tool available to separate the transmission drive link from the crank arm
View of the transmission drive link separated from the crank arm
On some vehicles, it may be necessary to remove the nut from the ball crank and remove the crank arm.
Location of the wiper arm ball crank
If necessary, unfasten the ball crank retaining nut, then remove the crank arm
Detach the electrical connectors from the wiper motor. Remove the wiper motor mounting bolts/screws.
Feb 06, 2010 | 1997 Buick LeSabre
Can't eject my dvd from the LG dvd system
open the top cover and then the back panel. you will be able to locate the drive assembly easily. try to remove the disk manually or try it with the power on. assist the drive assembly in its movements for 5-6 times. it will work therafter fine. if you still have problem the clean the belt that is connected from the tray load motor,
Jul 04, 2009 | LG LFD790 System
My 4 year old high efficiency front load washer set code "LE" (Overload in Motor). I unplugged and plugged back in and set to quick rinse and spin. Washer started adding water and trying to balance itself....
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY. • The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable. • The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited). • The hall sensor is out of order/defective.
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Sylvania 6313CB 13 in. TV/VCR Combo Logo
87 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
