Question about Philips FWM575 Shelf System
Philips FW M575 CD player
The CD player is constantly READING CD but never finds it to start playing.
3 Suggested Answers
larry james
  • 286 Answers
SOURCE: My recently made music CD will NOT play in our
This is common with burned cd's they have trouble playing in different sets. Do prerecorder cd's play fine in your philips? If those are having trouble also you could improve it's playability possibly with a cleaning of the opu. Optical pick up.
Posted on Jul 17, 2009
  • 39 Answers
SOURCE: shelf system shuts after a few minutes philips FW-R7
In power supply check capacitors ,one of them is leake or dry.Best way of detecting this cap is to have freez it (coolant) to sprey on the sections in power supply and thanindividual capacitors this will definately solve your problem.
Posted on Dec 17, 2007
  • 14 Answers
SOURCE: Philips Mini Stereo Model No.
Check for dust on the optical pick-up in the CD player. If you can, blow CLEAN air across it to remove dust.
Posted on Aug 12, 2010
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
Jukebox Error 61 NSM
The complete laser and spindle assembly is a CDM12 Philips unit. Plenty for sale via flea bay.
Mar 19, 2014 | Wurlitzer Jukebox 1015 One More Time...
Can mp3,ipod connect to philips FW-R7 with cd
All you need to get them to play is a "dock" and a 3.5mm Jack to two RCA phono plugs lead.
The Jack goes into the headphone output and the RCA's go into any spare socket on the back of the unit IE tape/cd.
Infact you just need the lead, plug it into the headphone output of the Ipod or MP3 player. But the dock will keep the battery charged and you get a remote with the dock, so you don't need to get out of your chair, to operate the player.
Feb 08, 2010 | Philips FW-R7 CD Shelf System
My recently made music CD will NOT play in our Philips FW-R7. It will play on all our computers and DVD players. The message is "Wrong Disc." Other music CD we've made do play fine in the FW-R7.
Jul 17, 2009 | Philips FW-R7 CD Shelf System
CANCELLING the demo mode
Once the demo has started, press the STOP button on the front panel for 3 seconds. Demo will stop and the unit will enter standby.
You can download the user manual here:
https://www.p4c.philips.com/files/f/fw-r7_22/fw-r7_22_dfu_eng.pdf
May 07, 2009 | Philips FW-R7 CD Shelf System
Shelf system shuts after a few minutes philips FW-R7
Dec 16, 2007 | Philips FW-R7 CD Shelf System
Cant get it to start
To reset the system to "install" mode press & hold the "play/pause" button in the center of the unit until "AUTO INSTALL- PRESS PLAY" is displayed. If this doesn't work then the unit may be too hot! I see on the philips web site that this model has a temperature sensor & will shut itself off. I am in Spain too & the temperature inside right now is 30C!! You can download the manual at: http://www.p4c.philips.com/files/f/fw-m355_22/fw-m355_22_dfu_eng.pdf
Jul 14, 2007 | Philips FWM355 CD Shelf System
Philips FWM575 Shelf System Logo
82 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
