Question about Linksys Wireless-G WRT54GS Router (e125894)
Linksys LELA software screws up connections to all previous cons
I bought a nice new Linksys wireless router, and just went ahead and installed it
on my WinXP pro Dell Vostro 1700. It wanted to install LELA, and I let it, after
it assured me this was a marvelous improvement.
I went home and tried to use my other router and it didn't work, wouldn't go, wanted
me to plug into it and reconnect. This is a pain, and is irresponsible design.
The alternative it offered was to run services.msc, then start the Wireless Zero Configuration
service, THEN go to the advanced settings on wireless network connections AND click
the wireless tab, AND tell it to use Windows to configure the laptop.
But you have to do this EVERY TIME you comeback from hibernate, or restart or whatever.
This is irresponsible design and I'm one pissed0off customer.
  • 679 Answers
I had the same problem with the same router and a new HP pavillion. I had to go through all of the services one by one and turn on anything that was remotlly connected to the wireless dependancies. Sometimes a reg cleaner or one of the many utilities we use to speed up our machines, stops essential services. The only way to make sure you did everything you could, is to go line by line in the services menu, or just turn them all on, to see if that clears it up.I tried everything from bios to drivers, and that did nothing, it ended up being one of the services I restarted. To be honest I really think that once we start using hardware and software from so many different companies, the "bugs" come out. I like linksys, but about a year ago, with a brand new wrt54g, it stopped working after a MSFT update. Also the tcip settings may have been altered. I found this on a forum last time I had the problem, it may help you so I'll post itIn the command prompt window that opens, type type the following commands:
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset IPv4 TCP/IP stack to installation defaults. netsh int ipv4 reset reset.log
Reset IPv6 TCP/IP stack to installation defaults. netsh int ipv6 reset reset.log
Reboot the machine.
Posted on Mar 05, 2009
Linksys wireless doesnt work
Hi there im tech guy from Linksys Well here is your answer For Win xp Operating System
First of all Insert the Adaptor's Cd in the computer where you want to install the w/l adaptor and plugin the adaptor.
Click on Start - Control Panel - Add/Remove Progs. and Search for software which shows some thing related to W/l moter or Compact W/l - or Network Magic / lela - Uninstall the software from list.
Now after that dont restart the computer - It will show u found new hardware Wizard.
The settings you need to go - No not at this time.Click next - Select Recomended - Click Next - Finish Installation.
Able to see the pop up down ryt side click on that link will show you yur network name - High Light and connect. Hope it will resolve your problem ley me know if facing any more problems.
Tech Guy
Cisco by Linksys
Mar 31, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Wireless router is not working
Go to Here for Linksys EasyLink Advisor (LELA). With this software you can monitor the routers status and troubleshoot.
Most trouble shooting involves disconnecting the power to the cable modem and the wrt54 router for about 10-20 seconds. Then plug in the modem until it lights, then plug in the router. The Advisor will then get a new address.
It also shows a graphic picture of your whole system.
I have a wrt54 and use this whenever I have a problem. I fix it then turn it off.
Hope this helps.
Good Luck
Feb 19, 2010 | Linksys Wireless-G WRT54GS Router...
Internet connection
I think you have the software LELA (linksys easylink advisor) installed in your computer. Sometimes if it's not updated you it will prompt that you're not connected to the internet though you have internet access.
1) update your LELA - go to
there's a field there that says enter model/serial number - just type in LELA - then click enter
- on the next page - click on get downloads then select version 3.1
- below there's an option that says download and drivers and you can see there LELA 3.1 just click on the download link and save it in your desktop folder
note: it's quite a big file - more than 200Mb
- before you install it make sure you uninstall the old LELA in your computer
- to uninstall it - just go to add/remove programs then remove linksys easylink advisor
hope this helps... Tech what you want
Dec 28, 2009 | Linksys Wireless-N WRT150N Router
I have a linksys router model #wrt1601 I'm trying
LELA is a software to help you set up router. But that software has lot of issues. It will be better if you uninstall that software and change the settings of your router manually.
it is very easy to change the settings manually.
Click Here for More information
Oct 07, 2009 | Linksys WRT160N Wireless Router
Will a linksys wrt 100 router work with a macbook?
Should work with any os from 98+.
Latest software found here
Apr 01, 2009 | Linksys Wireless-G Broadband Router
Exception from HRESULT: 0x88980406
There are known issues with the Linksys EasyLink Advisor (LELA). It is a very buggy piece of software that ends up causing a conflict with windows manager as indicated by your specific 0x error code. It is supposed to take the hassle out of setting up your wireless network using Linksys devices, but as you can see this isn't always the case.
The best thing to do, if you are technically inclined, is to uninstall LELA and manually configure your wireless network or hire a teenaged geek to do it for you. If you cannot do this, then try the following (no guarantees):
1. Download the latest version of LELA at and save it to your desktop.
2. If you're using XP then go to Start >> Control Panel, click on "Add/Remove Programs", find "Liknsys EasyLink Advisor" and uninstall it. If using Vista, go to Start >> Control Panel, click on "Programs", click on "Programs and Features", find "Linksys EasyLink Advisor" and uninstall it.
3. Reboot your computer.
4. Reinstall LELA by clicking on the LELA file you downloaded in step 1.
Mar 16, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless Adapter can't access internet
I have same problem with WRT54GS router and WPC54G Notebook Adapter. These worked fine until recently...I suspect something to do with installing XP updates and needing new drivers. I tried everything suggested...even updated LELA to newest version, but no success. After hours of frustration, I was ready to chuck it and head to Best Buy to get something different. But I tried one last solution suggested somewhere and it worked for me. Here it is in a nutshell: Uninstall LELA on all computers...sure it's got nice graphics and features, but who cares if it doesn't work!!! Then plug adapter into notebook and let it find the new hardware on it's own. (Linksys is very adamant about running their CD first, but don't do it! You can run the hardware with Windows just fine without LELA.) When the hardware install wizard asks, then put in the Linksys CD so it can download the drivers only. Then set up the wireless network in your network connections and change any necessary router settings directly by accessing it via Yes, I would love to have LELA up and functioning and feel like I have somewhat given up, but when software creates more problems than solutions, I've gotta cut bait. My network now works great. I put a Network Connections shortcut on my desktop to monitor things myself. It's simple and life is good. From these forums, it is obvious that LELA has some real issues. Too bad Linksys hasn't provided a better software product, considering the huge amount of time and money their customers have invested in trying to get it to work!!
Jan 31, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Intermittent Enabling
First you can try to uninstall and reinstall the driver of the wireless adapter on that desktop. Unplug and re-plug the wireless card. If it is a wireless PCI card, make sure the antenna is tightly screwed on. Install just the driver of the wireless card and not the utility/software that came with it. You can also try to change the channel on the wireless router by going to the router's user interface. If you're on channel 6, choose channel 11 and save the settings. Then power cycle the router, unplug the power for 30 seconds then plug it back in. Check now if you can connect wireless.
Oct 29, 2008 | Linksys WRT160N Wireless Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
95 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
