Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile TFT25 PR. Ice maker quit producing
GE Profile TFT25 PR. Ice maker quit producing ice. The dispenser continues to work normally. No water enters the ice maker. What can I check or replace? Is there a filter located in the water supply? At the water supply connection the solenoid operated valve appears to be a dual arrangement. If one controls the dispenser does the other control the ice maker water? Could this be the problem area?
  • shaconn2003 Mar 26, 2009
    it want make ice but water do work do have that sound
  • shapnup Apr 22, 2013
    I had the same problem with a different side by side model. The ice maker quit making ice, while the water flowed fine, and the ice maker mechanism seemed to turn just fine. Turned out I did 1 thing to fix it. I turned back down the freezer temperature setting from 5 degrees, to 0 degrees. Walllah.....in about 30-40 minutes it began spitting out ice again. It seems it won't work at a higher than normal setting. Also, I hapened to change water filter today and it not onl produces a stronger flow of clean water, it puts out a serving of high quality, clear ice about every 45 minutes. Before anyone goes to the trouble of paying for unnecessary parts and hassle, try what I did first.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 310 Answers
The solenoid valves on the back of the unit where the house water supply connects, have screens in them. They are similar to the aerator screens in your bathroom or kitchen faucets. The one supplying the icemaker may be plugged with debris. The solenoid valve itself may also be burned out if debris is not your problem.
Posted on Jan 31, 2015
Had the same problem. Replace the water filter and is should begin making ice again.
Posted on Mar 11, 2009
  • 3 Answers
Posted on Apr 22, 2013
Water dispenser is not working. Ice dispenser is working
If your model is the PSS25MGMWW and the water dispenser is not workingthe problem is most likely the=> WR57X10026 Water Inlet Valve Most times the ice dispenser and water to the ice maker will continue to work properly while the half of the water control valve will fail and stop water to the dispenser or ice maker. Follow the instructions in the video and I will be here if you have questions, Thanks Sea Breeze
Sep 12, 2013 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile side by side with water/ice dispenser. The water is working but the water to make ice is not working, hence no ice. I had ice, used it all and then nothing.
I would try putting water in ice maker if it freezes ice maker is ok if so feplace water valve. careful only 4oz. of water in ice maker
Oct 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
Me GE Profile PSC23M Side by side ice maker quit making ice and water was on floor behind refrig. Is a water line frozen or clogged or do I have to replace ice maker?
It sounds like you just have a leak at the back. Try swapping the wires on the dual water inlet valve. Then try the water dispenser and watch on the back for where the water may be leaking before it gets up to the ice maker.
Oct 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My ice maker make ice slow sometimes and also my water despensor has quit working. Does the tfx 25 pr have a water filter somewhere
i think so try looking in the top rear of the ref. or below the doors in/behind the grille this is wher they usually hide them
Jan 10, 2009 | GE Profile Performance 25.2 cu. ft....
GE PROFILE PSS26msrd Ice maker not working water dispensor ok new water valve new filter fill tube seems clear Does anybody have any sugestions before i replace the ice maker unit?
water does become ice inside the pipe in side the freezer it happens to my frige at list once a year, put a hard wire or pencil up to make sure that is not the problem, before you spend any more money
Dec 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
654 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
