Question about Panasonic PV-DV100 Mini DV Digital Camcorder
Quick release plate 4 solidex Tripod VT-86HQ
Need a quick release plate to fit bottom of Panasonic camcorder (pvdv100d) which then will fit into Solidex Tripod (VT-86HQ).
I have a SLIK Single Action Panhead Tripod. How do I mount the camera on the tripod?
it is a quick release plate. there is usually a button or lever to release the plate. you then screw the plate into the bottom of your camera or camcorder and mount the plate back onto the tripod. you can leave the plate on your camera when you store it to allow for faster setup.
Jun 03, 2010 | Slik AF-1100E Trigger Release Ball Head...
I am looking for quick release plate for a Radio Shack RST-84V tripod made in the 90s. I looked all over (local radio shack stores and corp. head quarters) but no one has any info. Finally I came across...
I found this tripod, new, on Ebay. It looks like it would serve your purpose. I'll keep checking for you, but take a look at it- it was posted on the 22nd of May, so you have plenty of time to check it out and buy it, if you choose. Good luck, hope this helped!
May 23, 2010 | Cameras
I need the quick release plate that holds the camera on the tripod for the Solidex tripod # VT-92XT model. Where can I find one? I live in the Seattle, WA area. Thanks.
As far as I know Solidex is out of business and since most of there parts are not standard to the other major manufacturers you sould either buy a new tripod or search for the same (exact same) model on ebay or craigs list to find the same model and use it for parts.
Dec 03, 2009 | Photography
I need a quick release plate for a Solidex tripod VT-88HQ
I do not know of anybody that sells or supports that brand of tripod.
Sep 30, 2009 | Cameras
Screwing camera onto tripod quick release
Usually the camcorder has a hole next to the mounting screwhole. The plastic nub fit into the unthreaded hole, the mounting screw screws into the threaded hole. The nub is to help prevent the camcorder from rotating while you are using it on the tripod.
Feb 08, 2009 | Sakar TR-60 Tripod
Solidex vt-92xt
Are you referring to a camera quick release? You could purchase a quick release mount to go on this tripod made by someone else. The only thing about that is you would have to buy that companies release plates that go on your cameras etc.
Hope this helps.
Jan 12, 2008 | Photography
Tripod
If you have not found the part for your tripod you are looking for, I have the whole assembly complete, still in the original box.$50 and it's yours.
Jan 01, 2008 | Photography
Solidex camcorder tripods
OKAY!! Thanks to the reply of "Baldwink", I was able to locate the product he suggested here in the U.S. from several dealers. This is the plate that mounts to the camera and allows easy removal/attachment to the tripod.
For the Solidex VT-90 tripod (the one I have and may fit others), order the Cullman CU-40470 Quick Release Plate. This is also described as the "Cullman Medium Quick Release 42mm" plate.
If you don't have the VT-90, measure the shoe plate area on top and remember that there will be at least one beveled (angled) area. Mine measured exactly 42mm square, so I am confident that the Cullman plate will fit. Also, the standard thread size for camera mounting is 1/4", but there are some cameras that use 3/8", so you might want to double check your camera for this spec.
I googled "cullman 40470 quick release" and found several U.S. dealers. The best price was from Adorama.com at $14 plus $5 ground shipping. Some dealers want as much as $33.
After nearly 20 years, I can use my Solidex VT-90 again!
Nov 15, 2007 | Photography
Panasonic PV-DV100 Mini DV Digital Camcorder Logo
955 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
