Question about Avaya Lands Phones
How do I change the time on clock
Can't figure out how to change time on telephone
  • Anonymous May 11, 2010
    What kind of phone? hat kind of phone system?
  • 4 Answers
Login to the web page for the system and choose Maintenance. There is an option to set the date and time.
It is also possible to set the system up to get the time from an NTP source.
If you have a dual server solution e.g. S87xx it is recommended the standby server is done first.
Posted on Apr 03, 2009
How to change clock hands
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 15, 2010 | Casio Fishing Gear Watch
AI can't figure out how to set the atomic clock
This clock will set it's self in a 24 hour time frame. You need only set the time zone your in.
If it does not correct it;s self change walls and location in your house.
The transmitter is located in Fort Collins, Colorado. this station transmits the time codes and is best received at night.
Hope this tip helps.
R/
David
Feb 13, 2010 | SkyScan 86709 Atomic Wall Clock
After a power outage, my clock no longer has right time
You need to reset the microprocessor in the Clock/Radio. to do this you must unplug the Clock/ Radio and remove the battery. Let the Clock/Radio set for at least 1 hour to discharge the microprocessor. You can then reinsert the battery and plug in the Clock/Radio. The functions should return to normal. If you are still having a problem, try changing the battery (CR2430) and letting the Clock/Radio set unplugged for a longer period of time. If all this fails, you can call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT and ask them for assistance. I hope this information help you with your problem.
Apr 01, 2009 | Emerson Smartset Clock Radio
Daylight savings problem
I just figured out how to change mine. remove the battery from the bottom of the clock, keep plugged in, hold down the time zone button and press the set button either up or down which ever time zone you need, it is very simple hope this helps
Mar 08, 2009 | Emerson Smartset Clock Radio
Emerson clock radio cks 3516 military time
You will need to try some combination of the set button and time button to change the time back to normal time. Try hold both the time and set button for a period of 5-10 seconds and see if this will cycle the time to normal. If not try hold the set button alone for 5-10 seconds and see if this works. If not try holding the time time button for 5-10 seconds and see if that works. If none of the fixes work. Call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 9am-5pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance with your problem of resetting the time back to normal from military time. They will be able to help you. I hope this information helps you solve your problem.
Feb 01, 2009 | Emerson Smartset Clock Radio
Setting the clock on a Comdial DX-80 Digital phone
To change Comdial phone read out time
feature
######## (8 pounds)
show
0814
save (System time)
show (Year)
next (Month)
next (Day)
next (Weekday)
change enter what you want to change
Mar 25, 2008 | Lands Phones
Panasonic KX-T7633 Corded
Your system clock is displayed on all phones - so your system's time is off. If you have Caller ID, you can have the system set to adjust the clock daily according to Caller ID, but that often gets worse, depending on the telephone company. I've even seen some systems off by four hours or more, so we don't recommend that either.
If you have programming access to the system, the system clock is setting 000.
Our servers adjust the clocks automatically every weekend to the accuracy of the Naval Observatory's Atomic Clock.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Jan 03, 2008 | Panasonic KX-T7633 Corded Phone
Clock
Your clock on your telephone is displaying the "system time" which can be changed at the attendant console the receptionist uses. Go to the console and push the FUNCTION KEY, then press ATT FUNCTION, then press SET TIME, enter the current time using four digits, ie. 09:30, then press PM if applicable, then press SET. SET will only appear as an option if the time has been enteed correctly, you can use the back arrow button to make corrections. Then push EXIT.
Nov 06, 2007 | Mitel Superset 420 Corded Phone
Lands Phones Logo
118 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
