Question about Eclipse (XA1000) Car Audio Amplifier
Shuts off when the volume is turned up over 60
When the volume is turned up over 60 the stereo will stop playing and in order for it to work the car has to be turned off and then turned back on
  • 93 Answers
The amp is tripping out and by turning the car on and off it is resetting the amp
Posted on Mar 05, 2009
My stereo plays but no sound
check for a mute button ,and check if volume switch displays volume increase when turning volume level up
Jan 14, 2014 | 2007 Toyota Camry Hybrid Sedan
Jaguar 1991 XJ6 stereo stops playing when i turn on the headlights help please
Either...
bad stereo or bad installment if its after market. if so they might tapped into the headlight circuit and when you tunr on the lights it deprives the stereo power.
Aug 09, 2012 | 1991 Jaguar XJ6
My screen is blank except for the arrow. I've rebooted several times but nothing comes back up. The lights at the top, i.e. DVD, play, ff, stop, mute and volume, are on and won't toggle.
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Aug 28, 2010 | HP Pavilion dv7-1130us laptop
Repeated off and on
speaks are hooked up wrong or speakers are blowin.
Apr 01, 2010 | JVC KD-SX980 CD Player
My car stereo shuts off while driving and playing
if you have had the head unit for long, it might be over heating and going into safe mode so it doesn't get to hot. This happened to my amp and i never did anything until it stopped working all together. so my guess would be just to get another head unit or get some type of cooling system.
Sep 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
Radio Like Has No Output?
Check the speaker wires, and speakers. You didn't hit the "mute" button, did ya?
May 22, 2009 | 1992 Ford Explorer
Dodge radio starts then shuts off
Hi Davis,
I had the same problem with Dodge Grand Caravan as well. I have a 2001 GCV and these radios go out all the time, plus each speaker has separate amps which some speaker will stop working. You will need a new stereo, however the dealership will charge you over $350 for the same replacement. I chose to go to BestBuy and buy a new Stereo for around $100 which has iPod connections which is a plus.
Next problem!!! Since each speaker has its own amp, in order to get the new stereo to work, I had to install a relay by tapping into the passenger side kicker panel master amp power supply to bypass the chip. Best Buy guy will know what to do. I suggest install the stereo yourself with a kit and go back to install an amp bypass relay switch. Hope that helps.
Stock Stereos **** and Dodge make is difficult to go aftermarket.....Good Luck
Apr 05, 2009 | 2001 Dodge Grand Caravan
I have a removeable faceplate kenwood car stereo. it has an auxillary stereo jack in the front. it also has advertizement of this port on the demo screen. my problem is that it won't play through it or i...
it won't read it. It should be as simple as plugging the male end of the wire, 1 end into the psp, and the other male end into the aux input. select a song on the psp and press play. turn up volume to full volume on the psp (not on stereo) and the slowly turn up volume on stereo until its at your liking. if this works, let me know, if it doesnt, let me know.
Dec 27, 2008 | Car Audio & Video
JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Dec 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
I have bought a kenwood kdc-241 car stereo i have downloaded my mp3 s onto cd-r (about 60 of them)when i put it into car stereo they play but no sound comes from the system (the radio sound is working also...
Hi i have just looked up your stereo and that kenwood doesnt support mp3 playback.
Unlucky mate.
In order to play a cd like that the head unit must support mp3 playback
May 30, 2008 | Kenwood Car Audio & Video
Eclipse (XA1000) Car Audio Amplifier Logo
161 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
