Question about Radio Shack TRC-447 CB Radio
Galaxy 88hl wanted to know if i could install the amp from a 2970 into a galaxy 88hl. help with the wiring diagram and how i would hook it up. any help appreciated. thank you
    Problem Solver:
  • 8 Answers
This would be EXTREMELY difficult.Too many components would have to be changed to handle the extra required voltages. Then you would need to incorporate a way to install fans for cooling. The expense and pain in the **** factor would not make this a good move. I do like the idea of the old style EPT360014B DX88HML chassis having an on board amp. Hey are you listening Galaxy?!
Posted on Mar 29, 2009
  • 40 Answers
This type of modification is not recomended and will ultimitaly cost you a good radio.the amo in a 2970 requires a lot of modification to the galaxy 88 I have not seen or heard of anyone who has done this modification successifly usually they eng up with 2 radios that nolonger work.
Posted on Mar 05, 2009
Galaxy 88hl
always check your swr's.. it should be fine with those settings.
90% amps 1 to 5watts input is fine and then the modulation wattage of yours is good. most can take 50w RMS.
use short coax jumpers.. make sure the radio doesn't have the modulation limiter cut. and it is on frequency. and it should be good. maybe try putting little bit of wd40 on the microphone switch to see if thats the crunching sound..??
also make sure you have enough amperage.. and a good heavy gauge power wire to the amp..
if you have any more details let everyone know.. may help narrow down a problem.
May 03, 2013 | Radio Communications
HOW DO YOU SUPER TUNE A GALAXY DX 88HL
tryadding a 470k ohm resister from the junction of c154/r207 to the junction of C-187 / R-235 on the solder side of the board.
Jan 27, 2013 | Galaxy Radios DX- 88HL Base CB Radio
Got pop noise
Popping sounds are from the the ignition - spark plugs, wires and distributor. Most modern cars have "radio resistor plugs" & "spark plug wires" installed from the factory. If unsure on an older car, check under the hood and inspect the wires & plugs.
Make sure your radio AND antenna system are solidy grounded. Poor grounds can allow all kinds of strange sounds and erratic behavior from the radio.
Also, connect the + & - power leads DIRECTLY to the battery. You can pass the + lead through a dedicated relay that opens when the key is removed if you want, but avoid like the plague connecting the + lead to a terminal in the fuse box and the - lead to an arbitrary grounded point on the body. Direct connections to the battery helps to prevent a way for noise to enter the radio on the power leads.
You may also be hearing the electric fuel pump located in the fuel tank on many newer cars. Solving that sound is very difficult.
Jan 12, 2013 | Galaxy Radios DX- 88HL Base CB Radio
How to wire a rk56 microphone to a galaxy cb radio
Pin 1 - Shield/Red
Pin 2 - White
Pin 3 - Blue
Pin 4 - Black
If you want a copy of the Telex Turner RK56 Wiring Guide, shoot me an email.
Dean Pitts
Rollin CBs
dean@rollincb.com
Feb 05, 2012 | Galaxy Radios DX- 88HL Base CB Radio
Changing colors on a Galaxy 88 or DX-88HL or DX88
  • There are no white ones at this time. Only Red, Green and Blue on the frequency displays. If you have any other questions please feel free to ask.
Oct 20, 2011 | Galaxy Radios DX- 88HL Base CB Radio
Need more talkpower without a linear amp
Send it to a CB shop and ask em to peak it and tune it,shouldnt cost more than 75.00
Apr 01, 2010 | Galaxy Radios DX- 88HL Base CB Radio
Used galaxy 88hl
If you have a receipt for it and you had it less than 2 years it can go to Galaxy in Calif. if is defective. Just go the the Galaxy tech support webpage and follow the directions for an RA #. They do good work. If you want to send it to a top notch repair shop try Dons CB in PA. They are a real Galaxy warranty service center. The # is 814-898-1046
Mar 02, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Galaxy dx 77 hml
I'll be back in my shop on the 24th. I'll open a 959 and see if it has the same configuration and maybe it will help. My nuber is 307-266-4675. I hope it helps.
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Galaxy Dx-88 HL
anything over 10 amps should be sufficient i would assume. if it calls for a 10 amp fuse anything less than that would be under powering the unit
Nov 07, 2007 | Galaxy Radios DX- 88HL Base CB Radio
Radio Shack TRC-447 CB Radio Logo
151 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
