Question about Toshiba Satellite A215-S7422 Notebook
Toshiba satellite a215s7422 screen blackout problem. computer powers up in safe mode and on an external monitor only. tried downloading display drivers and flashing bios-both failed (failed to find installed components etc and Error 1084 w/bios-cannot load in safe mode).any suggestions?
  • 4 more comments
  • peldredge Mar 06, 2009
    Hi Geekman,
    In response to your questions--If I am sitting in a dark room and I shine a flashlight on the laptop screen, I can all of the icons etc. I can even find the cursor and use it. Second question--I can not start the external monitor in normal mode. Strange occurance happened this morning, I had the external monitor connected and for the first time in a few days and instead of external monitor starting, the laptop monitor started working momentarily.Unfortunately, it froze. Then I connected the external monitor and it completed the boot up on that screen without any additional prompting on my part. What do you think?
    Hu again Geekman,
    In response to your second question--Using a flahlight as mentioned before, I was able to shutdown my laptop correctly and consequently was able to start external monitor in normal mode. Also, again I was able to see brief imges on my laptop screen before the blackscreen reappeared. Good luck with this one.
    Hi Geekman,
    Now, when I conect the external moniter images are on both screens. When I disconnect the external screen my laptop screengoes into blackout mode. What's next?
    Hi again Geekman,
    The situation keeps changing. Now, the only way that I can get an image on the external monitor is in safe mo In normal mode, I get a blck screen. If I use a flashlight, I can see icons. Does this mean that it may be the video card? Or is does the lcd monitor need to be replaced? I'm so confused and tired of trying to locate a faint cursor with a flashlight. I must say, however, it's been an interesting experience.
  • peldredge Mar 22, 2009
    i have replaced lcd and inverter--no improvement--same problem any suggestions.it first started with a black screen. using an external monitor, it will work in safe mode only. occasionally,the external monitor green light blinks and both screens are black. using a flashlight, i can barely see icons through my dirty screen--very fustrating and difficult!!! i'm already into it deeper than i want financially. how much will it cost for tech support and what is probabilty of fixing this one
    let's talk first
  • Chris Hingee
    Chris Hingee May 11, 2010
    When you boot up the laptop normally and the screen is black, can you see a very dim image on the screen?
    Also
    Can you boot up with an external monitor in the normal windows mode and get a normal image?
  • Toshiba Master
  • 32,281 Answers
As you can see an image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 06, 2009
  • Chris Hingee
    Chris Hingee Mar 07, 2009
    If you get a clear image on the external monitor, it means that the Video card is OK and the fault is with the backlight. This fault is caused by a faulty inverter or a burnt out CCFL lamp.
    To fix your problem, see my solution to your problem.
  • Chris Hingee
    Chris Hingee Mar 22, 2009
    Normally when you connect an external monitor or a data projector to the laptop and boot up, the video information automatically switches to the external monitor/data projector. You can then switch between the LCD and external video or a combination of both by pressing the Fn + F5 keys.
    It appears your video card is OK and if you can switch between the LCD (even though the screen is black) and the external video output (monitor) and get a clear image on the monitor, it means the video switching circuit is OK.
    This means you still have a backlighting problem.
    It still could be an inverter problem or a dead CCFL lamp, most likely a dead/faulty CCFL lamp.
    You replaced the LCD screen, was it new or 2nd hand and was the inverter new?
Baterry went off. i have charged it but the screen wont come on though i hear the fan. i have to remove the battrey to put it off. have tried an external monitor and it says computer on sleep mode. press...
Perhaps a result of the auto display off. press any key to activate the screen again.
If using the LCD screen, make sure the priority is not set on an external monitor. To do this, press the Fn function key combination to set the display priority.
if you use an external monitor:
1. Check whether the monitor is switched on
2. Check if the power cable is properly connected
3. Check if the cable menguhungkan external monitor and the notebook is connected correctly.
4. Try to set the constrast and brightness on the external monitor
Nov 01, 2009 | Toshiba Satellite A355D-S6921 Laptops
MY toshiba satellite 2430 CAN NOT POWER UP. BUT IT ALL THE LIGHT IS ON WHEN I SWITCH ON THE DC POWER SUPPLY SWITCH. WHAT IS THE PROBLEM? HELP.
remove the battery and remove the power adaptor ... press and hold the power button in the ON position and count to 20.
attach the AC adaptor only and press the power button ...this should fix the issue ... then re connect the battery.
if this does not work then add a external monitor .. if it lights up then hit the
Fn + F5 keys
Display modes
Fn + This hot key cycles through the power-on
display mode options.
The display mode options are:
Built-in display panel only, Built-in display panel and
external monitor simultaneously, External monitor only.
Fn + This hot key cycles through the power-on display options.
The display modes are:
❖ Built-in display panel only
❖ Built-in display panel and external
❖ External monitor only
video device simultaneously
❖ External video device only
Oct 07, 2009 | Toshiba Satellite 2430 Notebook
Hi there, I have a toshiba satellite M60-BK3 Laptop. Is only four years old and from couple of days my LCD display is going on standby mode very fast. I try pressing and releasing that little switch which...
A couple things to try, 1 is boot the system in the safe mode (F8 menu at boot) and see if the LCD turns off there. You can also attach an external monitor and see if the external looses video too.
If the system looses video in the Safe mode and doesn't loose video with an external monitor, then the LCD backlight is likely failing
LCDs run about $100 to $150 on ebay
Jun 23, 2009 | Computers & Internet
Toshiba satellite a215s7422 screen blackout problem, however, computer powers up and fan is running. external monitor will start in safe mode. sometimes i see the word signal on external monitor. help
Sounds like your refresh rate is incorrect
Boot into safe mode. Go to Start > Control Panel > Under Appearance and Personalization , select Adjust screen resolution ,
Selct your laptops display , set the resolution to 1024x768 , click on advanced settings then click the monitor tab at the top.
In the box below , select Use hardware default setting .
Hit ok.
If that doesnt fix it something is wrong with the drivers.
Start in safe mode with networking and get the drivers from here and install them.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1852724&rpn=PSAFGU&modelFilter=A215-S7422&selCategory=3&selFamily=1073768663&selModel=1852724%7CPSAFGU
Mar 04, 2009 | Toshiba Satellite A215-S7422 Notebook
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
My laptop not working Toshiba Satellite A135.
ok i got it as u said that u can hear the fan and it powers up but u cannot see anything on the screen iin that case what u can do is that disconnect the ac adaptor and then take the battery out of the computer and then without the power cord and the battery press and hold down the power buttoon for one minute and then connect the adaptor and the battery and the try and turn on the computer and then still if u do nnot see anything on the screen then turn on the computer and then connect the external monitor and if u see the display on external monitor then the lcd screen has gone bad and if u do not see the display oon the external monitor also then the video card of ur laptop has gone bad replace it ....good luck
or what u can try is that try lkgc (last known good configuration) and then try and boot the computer or try in safe mode....good luck
Jan 29, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite M30 Montior Blackout
have you tried changing the resolution, if not try this power on your laptop press F8 run in safe mode go to device manager an disable your display adapter after disabling reboot windows after rebooting go back to device manager enable display adapter and go display properties an change resolution.
Mar 15, 2008 | Toshiba Satellite M30 Notebook
Toshiba Satellite P25-S5263 monitor problem
It could be a driver problem perhaps. Does the post screen show at all or is there absolutely nothing?
Dec 29, 2007 | Toshiba Satellite P25-S5263 Notebook
Toshiba Satellite A215-S7422 Notebook Logo
387 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
