Question about Panasonic (JU257A607P) (JU257A607P) Internal Floppy Drive
I need a JU-253-403P floppy drive or equivalent
Re: Panasonic JU-253-403P
As far as I'm aware, this drive is a 720k DD floppy drive. As 720k drives are few and far in between, what are my options? I found the exact model on ebay, but for a premium. I know there are some 1.44MB drives that are 720k compatible. Can these be directly plug-and-play? Or is there some adapter or modification that can allow my machine to run 1.44MB drives? The interesting part is that the drive goes inside an EDM machine, not a PC, so I'm not sure if conventional workarounds will work.
  • rhouse86 Apr 07, 2009
    Same issue, Agie EDM that needs a replacement floppy, except mine original was a Panasonic JU-253-011P and was replaced with a Sony MPF420-2 which has now died. I believe it is 720k. Any help appreciated!
We recently had the same issue and have found a very nice solution on our Agie 100D. Contact me at tjones@indtools.net and I will give you the details.
Posted on Jan 11, 2010
[International Portal Floppy Drive , www.ruanqu.net] is "TEAC low-density jumper floppy drive, SONY low-density jumper floppy drive, YE-DATA low-density jumper floppy drive, EPSON low-density jumper floppy drive, MITSUMI low-density jumper floppy drive, Panasonic low-density jumper floppy drive, Mitsubishi low-density jumper floppy drive, CITIZEN low-density jumper floppy drive, NEC low-density Jumper floppy drive "global distributor. ]
Posted on Sep 28, 2009
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 68 Answers
I am using an external floppy drive instead of internal its Teac external
Posted on Nov 11, 2012
We ended up using a 1.44 drive that was 720k capable. Had to find a drive that had jumpers to change cable positions and set it to the correct drive (1 or 2). After I got that figured out, the Agie picked it right up. $5!
Posted on Jan 12, 2010
PANASONIC JU-257A907P
That drive has "died". Replace it with any compatible floppy-disk drive.
Mar 14, 2012 | Panasonic Computers & Internet
That drive has "died". Replace it, with any "standard" floppy-drive.
BIOS SEES DD FLOPPY SYS (DOS ALSO) NOT
Most floppy disks that you will still be able to find are 1.44MB DSDD disks, which a 720k drive will not be able to read. Check the capacity rating of the disks. Also the 720k drive has got to be at least 20+ years old, and the read/write heads may simply not work anymore. 1.44MB flopyy drives are literally a dime a dozen, you can probably pick one up at your local thrift store or electronics recycler for less than the bus fare it took to get there.
Aug 19, 2009 | Computers & Internet
Download
ok ive not seen one of these in a long time most floppy drives do not need drivers i gus with this one there are jumper set up at the back
try setting it to slave mode
settings should be described underneth
Dec 29, 2008 | Panasonic JU 257 (JU257A827P) Internal...
Need FDD for a Panasonic JU-257
you shouldnt need to download a driver, just make sure its enabled in the bios and windows will do the rest!!
I have a panasonic ju-256a216p floppy drive and i need drivers for it
Windodws 3.1/95/98/ME/NT/2000/XP all have "native" support for floppy-drives -- *NO* driver is needed.
Dec 27, 2008 | Panasonic 1.44MB 3.5 FDD W/White Bezel...
Panasonic ju-257a688pc
Just connect the two leads u want to be jumpered by a copper wire.
Feb 19, 2008 | Panasonic JU 257 (JU257A827P) Internal...
Epson smd349 floppy
Hi Elia, Could be a couple of things: -Your drive may only be a 720K drive. They will format 1.44 MB disks but only with a 720K format. The test is inserting a HD disk and try formatting it as HD. -The disk could be mislabeled, HD disks have two holes on end opposite the slide, one to write protect the disk and the other to signal to 720/1.44 capable drives this is a HD disk. -The HD disk could be formatted as a 720K disk even though it is an HD disk, reformat as HD. -The new, used drive could be damaged. -The drive could be configured as a 720K by the computers BIOS. You?ll have to enter the BIOS setup find the config for the A drive and set to 1.44MB. Let us know what happens and please don?t forget to rate the posting.
Jan 19, 2007 | Epson 1.44MB 3.5 Floppy Drive Floppy Drive
Panasonic (JU257A607P) (JU257A607P) Internal Floppy Drive Logo
1,546 people viewed this question
Top Panasonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
