Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
I am getting the error: 07,010.43:54794 I have to restart the copier every morning to reset it. When I came in today, the reset did not work. Red light flashing and can't make copies or print.
  • 2,072 Answers
More than likely , with the fact you said it has reset several times, I really believe the print head block is filled up with ink.
You have to remove the scanner, document feeder assembly. Then remove the left side cover, ( looking from the front that is). Most likely you will have to wind up removing both covers.
Anyhow. On the left side, on the lower portion of the frame, about 2/3rd way back, you will see a stainless steel block. about 1 inch square. It has a spring over it.
What normally happens with a 2424 and other solid ink printers is this, they are not sitting level, either front to back and or side to side. The ink spills over from the catch tray and gums up the print head block.You just pull back on the spring and latch it to the left. Then take some channel lock pliers and remove the print head block. It may take some effort. It will most likely be filled with yellow ink. Soak it in hot water and clean that and the shaft well, also remove as much of the excess ink spilled into the machine as possible. With the fact that you have been able to reset it and now it stopped, I suspect the print block is really dirty.
Once you get the machine back together, take a level,and place it on the platen glass and level the machine front to back and side to side to eliminate spillage as much as possible.
Let me know, But I am very sure this is your problem.
Posted on Mar 06, 2009
Y - CRUM Error / Error 093-950 Restart Printer
093-950 Y - CRUM Error
Error 093-950
Restart Printer
The yellow toner Smart Chip error is detected
Error with detecting or defective yellow toner cartridge. Replacing cartridge should correct it.
Nov 25, 2013 | Lexmark X560n Laser Printer
Y CRUM Error Error 093-950 restart printer
If new, did you remove the safety paper?
Nov 25, 2013 | Office Equipment & Supplies
Error sp305
Reset the job and reset the device.
An error has occurred in printing.
  1. Make a note of the error message (for reference later).
  2. If the error re-appears, please contact your local authorized sales/service representative or original point of purchase.
For the time being, try restarting the device:
  1. Press the Clear button to clear any pending jobs from the Printer.
  2. Switch off the device at the Red Power Switch, wait for 5 seconds then switch on again.
May 07, 2013 | Ricoh Aficio SP C410DN Laser Printer
Alarm/error and paper jam when not jammed
Power up printer,then press & hold (STOP/RESET)button for 5 sec. Then restart printer.I think it fix your problem.
May 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Minolta biz hub 250 ...problem error code c3451
Hi there.
Please try .
Try this.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will requir
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 14, 2009 | Konica Minolta bizhub C250 All-In-One...
Steady red light feed paper button
your printer needs to be reset put this in google scc download it and that should work
Nov 23, 2008 | Epson Stylus Photo 1290 InkJet Printer
How to clear error code SC571 on Ricoh 1232c copier
See thread I left you this morning on this. I hope it helps.
Press the yellow button. Press the 107 keys. Press and hold the red clear button for a few seconds until the service mode screen appears on the LCD display.
Oct 30, 2008 | Office Equipment & Supplies
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
70 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
