Question about Dayton Electric Heater
Just wondering can you cross the wires when installing the ignitor?
You can cross the wires without any problems. As long as the ignitor makes a complete circuit it does not matter.
Posted on Mar 06, 2009
How to install a spark ignitor in a gas furnace?
How to install a spark ignitor in a gas furnace? - Fixya
www.fixya.com/support/t15727344-install_spark_ignitor_in_gas_furnace
Jan 8, 2013 - How do I connect the high voltage wire to the Model 990-516 spark - Air ... SOURCE: Goodman furnace wont light, ignitor suspected. Notice.
carrier igniter
Jan 08, 2013 | Heating & Cooling
NPS40 blower and ignitor always on - did i cross wires
i would suggest you call the manufacturer and ask for tech help asap
ask for them to send you the wiring diagram, it also should be on one of the covers or lid for the back of the unit. OR
http://homeappliance.manualsonline.com/manuals/mfg/napoleon_fireplaces/nps40_1.html?p=30
Jun 07, 2017 | Napoleon Auburn Pellet Stove Heater
This is aCG4TDBN (elite with no back burner) aprox 6 years old. The ignitors are starting to go bad. How do I replace them?
First, you need to determine if it is the spark ignitors going bad or the Ignition Module.
If the spark ignitor tips are covered with grease or residue, this will give them the appearance that they're failing. Cotton balls and alcohol, work well to clean the spark ignitors. Also, check the wiring from the spark ignitors back to the ignition module. There may be some wear or even a burn on the wiring. Change the battery in the ignition module. Be sure the new battery is facing the same direction as the old battery, when you install it. Before installing the new battery, check the battery holder for corrosion on the contacts. If you see any, use a Q-Tip and WD40 to remove it.
As far as replacing the ignitors is concerned, you may only have to replace the spark ignitors and not all the wiring. It depends on how the wire is attached to the spark ignitor. If it can be carefully pulled of the bottom tip of the ignitor and then si back on, all you need is the spark ignitor. If not, you'll need the spark ignitor with the wiring attached. All of the wiring, will then have to be fished back to the ignitor module.
More more info on all the parts you may need contact BBQ's Galore 800-752-3085.
I hope this helped you to troubleshoot and determine if any parts do need replacing.
Jun 30, 2011 | Barbeques Galore Turbo Elite 4-Burner with...
Ignitor wire disconnected from the bottom of the grill. wondering where you connect the clip to? not seeing anywhere after inspecting it.
Kurt, you may have to remove the ignitor button to see the male lug that the wire's female end slides onto. It will either be a copper or stainless steel lug.
Hope this helped you.
Jun 26, 2011 | Char-Broil Quickset Traditional 463761006...
I have a firemagic 6 burner grill with 3 ignitors- 2 of my ignitor wires came loose somehow - wondering how do i reconnect them? Tried to push them into the back of the ignitor but wont just plug back in.
What you're trying to do is correct. It's the only way the ignition wires attach to the Ignitor Module. Are the push-on female connectors on the end of the wires still intact? If not, that's the problem.
Hope this helps you.
May 08, 2011 | Fire Magic Regal II Gourmet (NG)...
I installed a new 7509 ignitor on my 13 year old weber genesis gas grill and the gas does not ignite when pushing the ignitor button. I installed the ignitor with the box opening on the bottom and checked...
If the spark you see is in the ignitor box and not at the burner(s), then there's a wire loose somewhere or the ignitor is not grounded properly. Also check to see if the ignitor tips in the grill next to burner(s) are covered with grease. If so, clean them with a cotton ball dipped in alcohol. Check each ignitor wire at each ignitor , make sure they are secure,
Feb 20, 2011 | Weber Genesis Silver B Grill
Dayton Electric Heater Logo
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
