Question about Whirlpool GU2400XTP Built-in Dishwasher
I have a white film left on the dishes i've had this dishwasher for about 4 years and this just started
  • 188 Answers
Place a cup of vinegar in top rack corner (upright) and run an empty cycle to clean any build up.
Stop using any rinse-aid (jet-dry etc.), if the detergent you're using already has it included. Too much rinse-aid can create a white film on your dishes. A good way to check for rinse-aid build up is to run your fingers on the inside of the cabinet and check for a white powdery residue on your fingers. You can also run the dishwasher for a couple of minutes and check for excess suds in the water when you open it. Excess suds would indicate a rinse-aid build up.
Run the hot water at the tap before starting the cycle and make sure it's at the recommended temperature (120-140°F).
Posted on Mar 05, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
They are probably treating your water differently now and the water is hard. that is why the spots and film are on your dishes. there is a great product called the dishwasher filtration system that actually filters the water going into your dishwasher. it is amaing the difference it makes after the first load. it is easy to install and very affordable. you can get it at www.dishwasherfilter.com
Posted on Mar 18, 2009
  • 65 Answers
SOURCE: Whirlpool gold dishwasher leaves film on dishes
are you in a hard water area such as florida ? do you have a water softener? if so take a can of frozen concentrate orange juice and put the frozen hunk in the bottom of dishwasher and run for one cycle. the citric acid will dissolve undisolved soap . this works much better. than vinegar which will only remain through the first cycle and then drain out as for the already grey glasses wash them in a solution of equal amounts red wine vinegar and water with just a touch of dish soap using a sponge.
Posted on Feb 16, 2008
  • 677 Answers
the problem is hard water i bet. there is a new product out that actually filters the water going into your dishwasher. this i think is awesome becasue who knows whats in the water cleaning the dishes you eat and drink with. my dishes use to be white and spotty and after the first load with the filter they came out spotless. you can get it at www.dishwasherfilter.com. you will be glad you did. oh it goes under the sink and is small and affordable.
Posted on Jun 01, 2008
SOURCE: white film on all the dishes and inside the dishwasher
I had that too but seem to have gotten it 'mostly' under control. I checked my water hardness and it was high but in the normal range. I think they recommend doing this and you can order a test strip from the manual.
But what I think has helped the most is making sure the water is hot. It takes a solid minute for hot water to reach my kitchen, so when the dishwasher is filling its often not hot enough. If I run my water to hot in the sink, then turn on the dishwasher then I know I'm getting hot water. I also measured my water temp and it was cooler than recommended. I kicked it up a bit on my water heater.
Between the two things seems better.
Posted on Jul 21, 2008
I found that my dishwasher was leaving a white film on my dishes. It was resolved very simply - I hadn't tightened the cap for the salt chamber and so salt was leaking into the machine.
Posted on Aug 07, 2008
jtate9
  • 68 Answers
SOURCE: gritty white film all over dishwasher and dishes
Another way to descale your dishwasher is to use vinegar. This is also very inexpensive. Put a cup of vinegar into the dishwasher and run it, allowing it to go through all cycles. I would turn the heated dry off.
Please rate this solution
Posted on Aug 19, 2008
Nasty white residue left on dishes at end of cycle, and dishes not cleaned
The ****, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and **** in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Aug 23, 2011 | Kenmore Dishwashers
Powdery white residue left on dishes, silverware, and glasses after cycle. Just started, and very annoying.
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
Jul 24, 2011 | Dishwashers
Glasses and dishes have a gritty residue...dishwasher is just a year old and this problem has been happening for as long as we've had it. What should i do...This is gross
heatman101
Jun 02, 2011 | Bosch SHU9915UC Dishwasher
There is a white film left on dishes after the dishwasher is done. I use cascade detergent and jet dry rinse aid
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Feb 23, 2011 | Dishwashers
Food residue and a thin film or coating is being left on dishes. Top and bottom shelf items are affected. Started happening 4 months ago after working perfectly fine for 4 years.
heatman101
Jan 15, 2011 | Kenmore 24 in. 17034 Built-in Dishwasher
My dishes have a white scaley residue left after the dishwashing cycle is completed.
heatman101
Dec 02, 2010 | Maytag 24 in. PDB1420 Built-in Dishwasher
My Jenn- Air dishwasher (2 years old) used to clean great but now it is leaving a white film on the dishes and there is often residue left in the glasses as if it is rinsing with the dirty water. I can't...
heatman101
Nov 20, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Model # GLDA690MBB is only 2 - 2 1/2 years old, and only recently I've noticed a white chalky residue left on everything after it's finished. I 've always used the cheapest detergent and never had a...
heatman101
l'';
Aug 17, 2010 | GE GLDA690MWW / GLDA690MBB Built-in...
Soap (?) residue on dishes; also not getting them clean--food on
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
My plastics have a heavy white residue left on them. I have run the dishwashers with nothing inside. I have only had them for a year and this problem just started 4 days ago. what can I...
heatman101
;'l'll;
Jun 28, 2010 | Fisher and Paykel 23 in. DD603H SS...
Whirlpool GU2400XTP Built-in Dishwasher Logo
313 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
