Question about Autoloc KL550 5 Function Keyless Entry W/ Birt
Can't lock or unlock with either romotes
Both locking and unlocking do not work. I can hear a "click" sound coming from somewhere in the dash around the steering wheel. The little light illuminates on the remotes.
Any ideas?
    New Friend:
How do you find out if they are positve wires instead of negative
Posted on Jan 06, 2013
  • 61 Answers
Hi there
did you install yourself or was it done professionally?
on some cars the wires from the unit say they can be hooked up to door locks they can be but sometimes when the car manufacturers make the electronic doors that your unit is attached to the wires are set with a positive charge as a ground if the solenoids in the unit are clicking the problem is you need to add relays to convert the original door wire signal to the new signal you are trying to send to have these relays installed on your car you will need to have it installed by a professional but if you are very good with electronics if you go to your cars brand dealer you can ask for a photocopy of the cars power lock and ignition wiring setup (this will show all factory wires and the type of setting they have IE. 12v grounds (+,-wires) from there you will need 4 4pin relays now each relay is going to adjust all the doors wiring on the vehicle to accept the new signal..........this procedure will take about 2 up to 6hrs to do if not experienced but a professional installer can fix this in 1-2hrs
if you want to attempt this on your own let me know and ill try to guide you threw it
hope i was able to help
Posted on Mar 06, 2009
My daughters wipers just stopped working on her 2008 Jetta Volkswagen. I noticed when I turn the key on and move the lever up or down I hear a slight clicking sound somewhere around the steering wheel. I'm...
Let's keep it simple check fuses and relays by swapping around the relays in the fuse box. IF THIS IS NOT THE PROBLEM . Most of the vehicle'll especially havea multifunction switch operating turn signals wipers headlights. If it goes bad you will hear clicking and grinding in the steering column it's just plastic junk made to go bad. Replacing will require removal of steering wheel and removing wire harness attached to switch which should run down your column if you are not comfortable with this take it to a dealer. Hope this helps
Feb 10, 2015 | 2008 Volkswagen Jetta
Key gets stuck in ignition of my 1997 GMC Jimmy can't remove until I hear a click. It does this once in awhile.It sounds like a timer has it locked,when I hear the click only then I can remove the the
The steering wheel lock pin is probably not falling into place. Try some lock lubricant and jiggle the wheel back and forth a little bit. If that does not do it, you will have to take out the lock tumbler and free-up / lubricate the steering column lock pin mechanism.
Jan 15, 2015 | 1997 GMC Jimmy
1989golf 1.8 gti 16 valve mk 2have had steering wheel off put it back steering lock wont work and horn goes off when tightenig nut
Hi. It sounds like the steering lock has not been put back into position properly. This would need reassembly.
Feb 11, 2014 | 1988 Volkswagen Golf
Replace rack pinion
He is probably telling you the truth as most cars have around 4 turns lock to lock. The clicking sound you are hearing is the turn indicator switch under the wheel clicking as you go past the fingers that activate the lever to off position. The only thing I would check first is that the steering shaft coupling onto the pinion shaft is tight and the clamp bolt is still there. Otherwise it will be a new/reconditioned rack and pinion box
Sep 28, 2013 | Acura Cars & Trucks
Dash sound in Chevy Tahoe
Hi Ashley. Stephen Wilkins here.
Do you hear it when you are turning the steering wheel, or not ?
Aug 28, 2012 | Chevrolet Tahoe Cars & Trucks
My 96 Taurus GL has an electrical short somewhere, The radio works on & off , the defrost is out,The speedometor works only every so often, when the lights are on it starts giving me a clicking sound...
sounds like you may need an alternator... theres not a short< your just losing battery power and the steering wheel being hard to turn is probably your engine cutting out... also it could be a seized up pully or a/c compressor...
Jan 22, 2011 | 1996 Ford Taurus
My 1991 Honda Civic Hatchback (automatic) was broken into last night. They got into the passenger door but nothing is taken or visible wrong, however my check engine light comes on and stays on when I try...
B******s! It could be that when they broke they tried to get your car going and they triggered the immobiliser and this may need to be reset. On the other hand with many automatics you can only remove the ignition key once the transmission is in 'park' and the steering lock has engaged. I wonder if they may damaged the parking interlock mechanism between the ignition point and the gear selector by messing with the locked steering wheel. Check that the steering lock unlocks OK and that the car is unable to start in any other gear position, try 'neutral'
Jun 24, 2010 | 1991 Honda Civic
Ignition key does not work
if your key is a transonder key wich has chip in it give it a couple of minutes to reset the code keep key in ignition and wait to see if it reads key or try another key and see if you have sameproblem make sure you unlock steering wheel disconnecting batteryfor posts might have reset car computer and cannot read ur key...
Mar 07, 2010 | 2000 Nissan Altima
I am pretty sure that the solenoid for my shifter is dying because I have alot of difficulty getting it out of park and when I press the button on the shifter to release it from park I am hearing a click...
I think that is normal for all cars or some of it, because if your steering wheel is lock, you can not release your shifter to D to R or to N because your car is design with the safety lock for anti-theif. Before you start and drive your car, you need to turn your key to the switch position and unlock the steering wheel by turning or wiggling left and right the steering wheel until you will hear the click then its also automatically unlock your shifter. The click sound is lock or unlock. Maybe you don't know also that every time you get out from you car and toke off your key and accidentally turn a little bit your steering wheel, and also you don't hear or feel the click specially if you are in a hurry, your car is in a safety lock. I hope you get what I mean, OK, Thnx
Jan 05, 2010 | Pontiac Grand Am Cars & Trucks
Key In Ignition Won't Move 2002 Chrysler Town & Country
The steering column sounds locked. Try turning the steering wheel all the way left or right till you hear it unlock or until the key can turn. Note; You must use force to unlock the steering column and don't be scared because it won't break anything.
Jan 27, 2009 | 1995 Honda Accord
Autoloc KL550 5 Function Keyless Entry W/ Birt Logo
273 people viewed this question
Top Hoffman Group Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Hoffman Group Vehicle Part and Accessory Expert? Answer questions, earn points and help others
