Question about Toshiba Satellite A75-S206 Notebook
Toshiba a75 s-206 cuts on than idk!!!!helpppppp!!!!!!!!!
I have a toshiba a75 s-206 that cut on to the toshiba screen and i can go into bios and everything but thats it after it leaves that screen the screen stays black and never does anything else. i am thinking that it has something to do with the os cause it doesnt even load that so i dont know please help!!!!!!!!!!!!!
  • bwm1222 Mar 06, 2009
    well i put in the cd it says boot from cd press any key so i do so and then is says config. system then that goes away and the screen is black so i have no idea i am stuck
  • 64 Answers
If you put in a Windows CD does it boot into the cd menu?, does the black screen have the blinking white line at the top left corner?
Posted on Mar 05, 2009
Toshiba satellite L850 bios password reset
Under the RAM there is a jumper "B500" Remove the battery. power source and RAM. Link B500 for one minute.
Feb 27, 2014 | Toshiba Satellite L850-ST2NX1 : Laptop...
Toshiba E studio 207 C97 error solution
sir i have Toshiba 207 copier sir now write on screen call for service C97 PROBLAM
Jun 22, 2012 | Toshiba E-Studio167 Copier
Heads are cut off on toshiba tv and reading at bottom
Depending on the model the set or a cable box may have an adjustment for this---simple thing to do also is hook to DVD player via rear inputs to see if same problem or not.
Apr 20, 2012 | Toshiba Televison & Video
I have a toshiba satellite p205d-s7438 and the screen cuts off while in use
I would boot the computer up and press F2 and check the power settings in the BIOS. It sounds like it is going to sleep on you. If that doesn't work, check your power settings in the control panel.
Jan 18, 2011 | Toshiba Satellite A135-S4527 Notebook
My Toshiba A505-s6975 laptop is having a speaker problem. The Left speaker will cut out sporadically, it will be working fine then it will start to crackle and cut out, and finally cut out completely. I...
Seems like a common issue with A505's. After a fruitless google search I basically went to speaker balance (which I had to google how to for win7!) and increased level to max for both left and rights and so far so good. Hope that helps.
Aug 15, 2010 | Toshiba Satellite A505-S6975 Notebook
Toshiba tv cutting off
are you going to attempt the repair yourself, do you have a shop manual, and test equipment ? let me know
Jan 30, 2010 | Televison & Video
It won't cut on. just charge light and the on light and fan does.
Check you memory Remove and put back(Make sure remove the power and battery first), Check your bios /CMOS time. try again. No solved
Try to access the F8 and scan your computer, no solved, See TechGuy.
JMC
Aug 13, 2009 | Toshiba Computers & Internet
Toshiba L25-1216 LCD Screen cuts out or has
Most likely you have a loose video connection. Reseat the ribbon cable that connects the LCD screen to the motherboard.
This connector is located under the plastic panel that holds the power and various switches near the bottom edge of the LCD screen.
Apr 04, 2009 | Toshiba 15.4-inch 1.6GHz 40GB Laptop PC...
Finding a screen / cutting down a screen
The outer one you can, but the inner one if you notice has a circular pattern, I have had customers try but they have complained of clarity issues after doing so. Try getting a used one.
Jun 20, 2008 | Toshiba TP50H50 50" Rear Projection...
Bios Update failure
You're in a trouble.
If you can get to the motherboard, you could try removing the CMOS battery. This probably won't help, because most laptop CMOS is backed-up.
So you should contact Toshiba with the problem. The chip, which contains the BIOS, on the motherboad needs to be replaced with one, containing a working BIOS for your motherboard. Or your motherboard is to be replaced.
May 21, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A75-S206 Notebook Logo
213 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
