Question about AT&T Blackberry Curve 8300 Smartphone
My cell phone won't charge.
I've changed my blackberry 3 times since Jan 08, seems to have the same problems, keys will freeze, phone will not charge, mouse doesn't work. Last week the keys won't work again then I was about to call the warranty department of at & t to get yet another phone, it started working. Today when I got it out of the charger, the battery life was on red and I played with the charger and it will only charge as soon as you plug it in and that's it, I don't know if it's the phone or the charger but I had the same problem about 2 curves ago when I got it changed. I'm just tired of this phone. Good thing I have one of the free ones when I first signed up with AT & T, it's an old samsung but at least it's reliable.
  • 4 Answers
Well... do you have a computer/laptop? if so then you should have received a connector to the computer. i lost my charger a few months ago and am not willing to pay 40 for a new one. so i just charge my phone on my computer.
the only problem is atleast on my computer you have to be on it while its charging or else it wont charge
hope this helped
Posted on Jun 28, 2009
Nokia n96 not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 17, 2012 | Nokia N96 Smartphone
Blackberry pod will not charge my style
First Option:
Second Option:
Jul 30, 2012 | Computers & Internet
My blackberry 8800 will not charge even when i put in a new battery !!
First Option:Please change The Phone Bettery and charger and check The check The Phone charging
IF Charging Problem will Not Solved So
Secend Option:Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved
thanks.
Jun 21, 2010 | RIM BlackBerry 7250
Cant seem to get internet stting right! I've tried everything
have an idea but make sure phone gets a backup as this will remove your all phone memory go in option then security setting then general setting then press blackberry key(menu key) there is wipe handheld you will be asked password which is "blackberry"which is written on then screen it self.
MAKE SURE SIM CARD IS PRESENT FOR WHICH YOU NEED SETTINGS as i had same problem but now it is solved by this every time you use another sim your settings will get lost so don't enter any other sim if don't want to do this process it do take some time if have any more problem contact on aniruddh11@gmail.com
regards
aniruddh
May 24, 2010 | RIM BlackBerry Curve 8310 Smartphone
My blackberry wont turn on
try a new battery? maybe your battery is dead maybe the phone wont charge your old battery do some elimination to figure out the problem
Feb 16, 2010 | RIM BlackBerry 8800
My blackberry isn`t charging, i`ve plugged it in and nothings happening, when i plug it into my computer it has a lightning symbol by it but im not sure what it means?
does the phone charge when connected to the computer? The lightning icon means it is connected to power and is charging. Try another charger, it seems like your charger is the problem, not the phone.
Dec 15, 2009 | RIM BlackBerry 7290
Blackberry freezes and doesnt recieve all messages
Try this steps to perform soft reset
1)Press and hold down the ALT key on the smartphone.
2) While holding down the ALT key, press and hold down the right-hand CAP key.
3) With both of those buttons still pressed, press the DELETE key. The display on the BlackBerry smartphone will turn off to indicate that the reset has started, and the keys can now be released
Still if you face same issue Download and install the latest BlackBerry Device Software, which is available from the BlackBerry.com
Hope this is helpfull for you
Nov 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blacberry 8100 turns off when i press any key
Looking at what you’ve posted, this is more like a battery problem let’s try some troubleshooting;
1.) Try charging the battery again: Keep the battery out for some time & then reload & check.
2.) If it's less than a month old see if you can return it, otherwise you can try reloading the OS.
So if you're willing to try that, do the following.
First download and install the Desktop Manager from here (4.6 without Media Manager is recommended): https://www.blackberry.com/Downloads/entry.do?code=A8BAA56554F96369AB93E4F3BB068C22
Next you can use the Backup and Restore feature present in the software to make a backup of all the data on your phone.
Next download and install the handheld software from here: http://na.blackberry.com/eng/support/downloads/download_sites.jsp
Afterwards try reloading the OS by connecting the device to your computer, open the Desktop Manager, then go into the Application Loader. This will open a wizard that steps you through reloading the OS onto your device. More detailed steps can be found here:
http://www.blackberry.com/btsc/KB03485
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 17, 2009 | RIM BlackBerry Pearl 8100
Blackberry will not turn on, I just get a red light
this happened with my first blackberry and it never turned back on guess what softwar glitch it was never goig to work again so i got a new one the second one started having issues within a month and eventually got to the point where i couldnt wifi it would turn off on me for no reason tell me i had no service when i should have hang up on people freeze and simply sucked took it in to get it fixed guess what another software glitch that one went to blackberry heaven and i got another one this one is only 1 month old has all updated software and hey guess what no issues at all i suppose every phone has bugs in it to begin with look the aple iphone blew up when it first came out until they fixed the issues with it.
if your on a plan ur under warranty with blackberry take it back and there policy basically replaces the phone.
good luck
Jul 30, 2008 | RIM BlackBerry Pearl 8100
Blackberry charging problem
Sure sounds like a problem with your charging outlet. I recommend taking it to your service provider and having a technician run some tests only they can do.
Please let me know if this helps. Take care!
-Chimpster
May 02, 2008 | RIM BlackBerry Pearl 8100
AT&T Blackberry Curve 8300 Smartphone Logo
517 people viewed this question
Top AT&T Computers & Internet Experts
Prashant M
Prashant M
Nataly Roberts
Nataly Roberts
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
