Our TV screen is often blank and our recourse to this point is to give it a slap (or slaps) on the side of it. Sometimes it works and the picture appears, sometimes it doesn't. Seems like some kind of a short that should be able to be corrected inexpensively. Going to a repair shop would cost more than its worth. Might there be a tube or connection that needs tightening? Or should I just trash the entire set?
  • jimbennie Mar 05, 2009
    I'm sorry. I'm at work and don't remember either the brand or model. Once I get home and determine what they are, how, if it's possible, do I get the information to you?
  • 10,594 Answers
Please intimate model and brand of TV to help you out in this problem.
Posted on Mar 05, 2009
  • Shahid Electronics
    Shahid Electronics Mar 05, 2009
    I'm waiting model and brand info because it will help me to check its schematics and to point out possible area of problem.
    You can provide info as comments.
    Model and brand would be printed on label, pasted at rear of your TV.
  • 19,396 Answers
That means that there is a lose contact inside the TV.
  • Ginko
    Ginko Mar 05, 2009
    If you have blank screen and when you hit the TV and raster comes back, that means that there is a bad solder joint inside your TV.
    If this is a CRT tv (the traditional TVs with tube) then the problem is usually a cold solder joint on the flyback trasformer.
    Fixing bad soldering on flyback transformer is a job that must be done by a good technician, unless you have experience as a repairer I suggest not attempting the repair.
    The flyback transformer stores enough electricity to kill a man, and if badly repaired can cause the TV taking fire, endangering you and your family. This is definitively a delicate job.
    If you are using an external receiver , try also checking the video cable.
32" LCD tv w/built in DVD mounted on wall. screen will not hold picture - looks like vertical or horizontal hold needs adjusting, but cannot figure out how to adjust. happens when using DVD or VGA...
Vertical and horizontal adjust went out with black and white TV pretty much.I remember those days too...what would kids nowadays do???lol.Anyhow,the fact that it clears up sometimes when you slap it should mean that the screen is fine.Something on the circuit board may need repair.Unfortunately,I have searched for diagrams for TV's online many times and only authorized shops have the access required.I just checked westinghouse,not even a way to sign in if I were a reapir shop.So,needless to say, a shop will have to check it out.Sorry That's all I can suggest and good luck!
Aug 05, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Picture is really light in color screen is white
It sounds like you have bad solder joints in the tv. If you resolder the boards in the tv, it sounds like it will be fine. When you are slapping the tv, it is temproarly making contact again and fixing the picture..
Jan 02, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Bush LCD TV No picture but sound
replace 2 large caps on psu panel 1000uf caps lt feed to inverter panel caps are on right hand side of psu panel
Dec 15, 2008 | Televison & Video
Canon a60
This is due to iris problem ... the iris does not open .... so hence nothing is seen and nothing is recorded .... try lightly slapping the camera from the left side ...... if it works fine other wise show it to a repairman ...
Oct 20, 2008 | Canon PowerShot A60 Digital Camera
Scattered black lines appear then screen gos black, but still have good volume
Hello 4fiddy,
You have actually diagnosed your own problem, Let me explain; the line "I can slap the left side of the tv and picture will almost always come back on" This indicate some form of poor connection (cold solder joint). If you have a soldering iron, solder (circuit type not pipe type), and a multimeter. Use the soldering iron and solder to redo the cold solder joints , and then test it (the connection) with the multimeter.
I hope this helps
Thank you,
Shuttle83
Sep 25, 2008 | RCA HD52W59 HDTV Projection Television
Door will not open on dvd player
Is there a "lock mechanism" that will need to be undone?....accordianman
Jan 19, 2008 | TruTech TT320
Black screen
Well, this is a fatal error that happens with the CCD chip. According to this page, you can try one of two things: You can slap it firmly against your hand in an effort to fix the broken transmission, or you can call up Nikon. According to the link provided above, they are supposed to repair it free of charge and regardless of warranty.
- 2 Bunny
Dec 04, 2007 | Nikon Coolpix S1 Digital Camera
Set needs to be slapped to get a picture
TV's need a good slap once in a while to set them right! Just kidding. Sounds like you have a bad connection that once the set is warm it mends itself. Have a technician look at it.
Apr 18, 2007 | Toshiba CF27H50 TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
