Question about Belkin 802.11b Wireless Notebook Network Card [ F5D6020 Wireless ] (109059)
Join an old Windows 95 machine to the net wirelessly
IMy wireless network works fine on all my machines except one old laptop running on Windows 95. I need a special adapter for that.
It is said that Belkin (F5D6020) 802.11b will do the trick but I cannot find one in the UK.
(eBy turns up one in Maryland. Theowner is unwilling to ship it.)
Are they still being made?
    Genius:
  • 1,605 Answers
ANY OF THE WIRELESS CARD FUNCTION IN 802.11B WILL DO THE JOB.
MAKE SURE THE CARD IS NOT A DUAL FUNCTION 802.11B/G TYPE.
Posted on Mar 05, 2009
Two toshiba laptops, one less than a year old running win7...the other 3 yrs old runnign xp. both worked fine connecting wireless to my router sat. sun the win7 machine said the dns server was not...
Did you press a button (or move a slider-switch) on the WIN7 laptop, to "disable" the wireless adapter?
Can you login to the web-server "inside" the wireless router, and look at the "log-files" that the router keeps of "recent" events (such as connection-attempts from wireless devices), to see if there is any useful information in those logs?
Does the WIN7 laptop connect to _any_ wireless network (Starbucks, university, shopping mall), or does it fail ONLY when connecting to your wireless router?
Have you tried a "factory-reset" on your router, just in case that it might be the problem?
Feb 21, 2011 | Toshiba (PA3212U) Wireless Adapter
Have a wireless network through netgear WGR614 v6 working fine with 2 old ibm/toshiba laptops with vista and an acer on ethernet recently bought a new hp laptop with windows 7. This laptop gets very...
check if the laptop has wireless utility other than the built in windows wireless. (example intel proset wireless). if yes, uninstall the wireless utility and Update the wireless driver of your laptop by downloading the latest driver from ho web site.
Jun 10, 2010 | NetGear WGR614 Router
Vista to Vista wireless, Can't share printer
So your third laptop which runs Vista cannot connect to the Printer and Dell machine?
There are some reasons for that. First check whether you have access to the Dell machine (whether you can reach it) Open a command prompt and do a ping to verify the connectivity. Example. ping 192.168.1.2 (The ip address should be the one of your dell machine. You can find it by running ipconfig in a command prompt on Dell machine.)
1. If you cannot reach it you have to check the network utility (wifi or any other method you use). Make sure that it function properly. 2. ping the router using router's ip address. If ping works you can reach up to their. So from there you can check the Lynksys management console to know why it blocks the machine entering the wlan. May be a addressing issue or authentication issue. If you cannot reach it however it might have problems with the connection as well. Make sure that you allow connections to the wlan on Toshiba Vista laptop if you use a antivirus solution with a firewall or any other firewall.
If you can reach the machine (or even if you cannot reach) you must check whether you have access to the workgroup (you have to join if you are not in the workgroup which you use) and you must enable file and print sharing. If you run the windows firewall that would block you in as well. Its better if you can check whether the print spooling service runs. Start -> Run Type in services.msc Hit enter. Check and enable the service.
If you can reach the Dell using a ping: Check whether the dell machine can access the laptop. Use my network places. It will ask you for the credentials. Provide them. If any error occurred try detecting the network. Add the machine properly to the workgroup. Enable access to the machines via file and print sharing in windows firewall. (go to the firewall go to Exceptions tab and select the File and Print sharing)
Check this Microsoft resource as well.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
May 30, 2010 | Linksys WRT160N Wireless Router
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
Can't get Acer Aspire One on my house wireless net to share files
Make sure the firewall software on the acer allows the wireless connections, try turning the firewall off for a moment and also disable the wired connection.
Make sure the network is safe or allowed most likely firewall blocking.
Mar 08, 2009 | Acer Aspire One Netbook 8.9" Notebook
Desktop recovery disc for laptop
Courtesy of Gateway here is your driver for the network card:
http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10022&model=11417&os=10406&type=10095
Now here is where it gets tricky. I'm not sure what wireless network card you have there but on that page is a section that says other available downloadsm click on where it says "click here to view these results". There will be drivers for different network cards. I believe it will be the first one in the list, the broadcom one, if not then try any of the other wireless card drivers. Hope this helps you and sorry for the delay.
Feb 20, 2009 | E-Machines (T2958) PC Desktop
Imac AirPort Extreme (0x14E4, 0x8C) to wifi
On the iMac choose Create Network... from the Airport menu. Then the Gateway laptop will be able to join the iMac's created network.
macs2u
Dec 29, 2008 | Apple AirPort Extreme Base Station...
How do i build a local area network in windows xp?
On the machine that the printer is connected to go to Start>Control Panel>Printer and Faxes>Right click the Printer that you want to Network and Left Click Sharing> Select the Option to Share the printer and Name it something that you wil remeber. On the Laptop go to printers and Faxes select add new printer and select Network Printer. And Choose the second option Put the Name of the Computer that the printer is connected to and then printer name. Example \\Desktop\HpPhotoSmart 8100. Also you will need to check to make sure that both machines are on the same Domain\Work Group. Go to Start>Control Panel >System>Computer Name Tab ( Here verify the Machines Name)> Join or Change Domain>Put the machines on the same Workgroup if they are not, Do the same on the laptop. To test this, on the laptop go to Start>run and type \\Desktop Name and you should see what is able to be shared. Walk thru the steps above to install the printer on the laptop and have the intall cd in the laptop to install the drivers and you should be good to go. I hope this is understandable. If not feel free to email me at smichael@phoenixschool.net and I will see if I can clarify this for you. Happy networking!
Dec 02, 2008 | Computers & Internet
WPA on a hp ze4805us laptop
The ZE4805US contains the Broadcom or the LAN express wifi cards so dont expect a driver - the chip doesnt support the feature.
Hope this helps
Mar 20, 2008 | HP Pavilion Ze4805us Notebook
Fatal Exceptions
Is this a new device? A lot of newer wireless adaptors come with drivers for NTFS based operating systems such as windows 2k or XP. Windows 98 runs on FAT32. I don't know if this will work. I suggest you upgrade your OS.
Aug 16, 2007 | Asante AL1611 802.11b Wireless Adapter
Belkin 802.11b Wireless Notebook Network Card [ F5D6020 Wireless ] (109059) Logo
70 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
