Question about Philips 50PFP5332D 50 in. Plasma Television
Menu Screen keeps popping up
I have a 42" Plasma TV. The "menu" screen keeps popping up when on. Does th circuit board need to be replaced?
  • victoriago2 Mar 05, 2009
    I still have to confirm model # 42 PF7320A/37 42" Philips Plasma HDTV. I went online philips.com & they said to reinstall software which I downloaded from the site. So we'll see.
WHAT BRAND AND MODEL NUMBER?
Posted on Mar 05, 2009
  • Sean Anthony
    Sean Anthony Mar 05, 2009
    THE SOFTWARE UPDATE FROM PHILIPS MAGNAVOX WEBSITE SHOULD SOLVE YOUR PROBLEM. GOOD LUCK!
My 42" Vierra 1080 plasma
The pixels in the screen are commanded by a buffer board . This board connects to the screen with the help of a wide flat connector - in your case this command circuit appears to be faulty: either the buffer circuit is failing and the entire buffer board will have to be replaced ($250 part and labor from a pro) or the connection itself appears to be slightly out of line so when heated the contact is lost and the pixels get stuck (in that case the tv will have to be completely dismantled and all the contacts to the plasma panel reseated - $200 in labor).
Ask a quote around and select the cheapest repair shop you can find.
Apr 17, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Following a audible pop TH 50PZ85U will not power on.
Most common thing to happen is a capacitor went bad on one of the circuit boards making the loud POP sound. Odds are it's on the Power Supply Board if the TV isn't showing power at all. The picture below what a bad capacitor looks like.
They range from different sizes and color. Swollen, deformed, and raised top is the thing to look for.
Solder in a new capacitor on the board or replace the whole circuit board.
Jan 30, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
Th-42px25 red picture, no blue or green
If using component cables check connections at TV or from source. If all rae ok the try source on another tv before getting video input circuit board replaced on tv
Dec 14, 2009 | Panasonic TH-42PX25U/P 42 in. Plasma HDTV
THE MENU KEEPS POPPING UP ON THE SCREEN CONTINOUSLY ON MY 42 INCH
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
Nov 29, 2009 | HP PL4260N 42 in. Plasma HDTV
TH-42PD50U 42" plasma from Panasonic. The TV tipped over and won't turn back on. The red power light just keeps flashing on and off.
Try to unplug and replug the power cord. If TV remains unchanged you need to call for service. The power supply board was defective. In worse case, the Y and buffers are defective, too. There are many steps needed to figure out the exact defective board. You need help from TV repairer unless you want DIY.
Aug 13, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Menu pop up
there may be an issue with the push button on the side flaking out check and see if it is sticking on the cover if not I would replace that board
May 27, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Dec 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Sep 16, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic 42 " TH-42PWD8BK
Sounds like a main board or a sustain board problem. This is most definantly not a repair job for the consumer to attempt. Please call in someone who is experienced with Plasma TV sets, as these boards can be very very expensive. Too expensive for you to guess and buy and then have to order the other one. Oh this model also has some power supply issues as well. Good Luck Please do not forget to rate this thread.
Nov 27, 2006 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
Philips 50PFP5332D 50 in. Plasma Television Logo
574 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
