Question about HP L1730A (Carbonite, Silver) 17 in. Flat Panel LCD Monitor
I have an Hp L1730 (PE1238) (P9625A) color flat panel monitor. I turned the monitor on and the image popped up for one second , then blinked out. The power LED stays on and green. I checked all of the cables - ok. I disconnected the cable and the no video signal message comes up. I turn the monitor off, reinsert the cable, turn the monitor back on - same problem. I can't find a service manual for this product.
Mr BrokRench
  • 1623 Answers
SOURCE: I've been getting no power at all. Tried using a good known power cable and a different power outlet but still won't work. How can i open the panel to check the power button?
Hello emperez25...Sorry to hear that your LCD died on you. There are two things that normally cause this... #1..The power supply has gone out.... This would be the case if the lights on the front of the unit do not come on. You can check this with a multimeter. . #2...The inverter or the back lights are burned out. LCD displays use small tube florescent lights like the ones that are in stores and they either burn out or the inverter fails and they cease to work. This is the case if the front panel light comes on but no display can be seen unless you look VERY close. They can be repaired, but with parts and labor costs compared to the price drops of new LCD's most folks opt to upgrade....In short, get a written estimate for repair costs, if you choose to go that route. For less than 200 dollars you can get a NEW 23 inch LCD with DVI, HDMI and AGP interface with a full high definition display that supports the latest Blu-ray devices for FHD/HD true digital content.
Hope the information i have provided you is helpful...
Posted on May 15, 2009
budmrtn
  • 11361 Answers
SOURCE: lg flatron l1730 no power on screen
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 09, 2010
Ezrahite
  • 2632 Answers
SOURCE: Hi. I have an HP a6115uk
Welcome to Fixya. It seems that the issue is not caused by the monitor or the video cable. You can determine if this is caused by the motherboard by using the onboard display if the motherboard has any. If you want to use the onboard graphic just remove the video card and it will automatically use the onboard graphic. If this wont still be able to fix the issue the problem that you have is the motherboard itself.
If you have questions please let me know.Thanks
Posted on Jul 28, 2011
SOURCE: HP vs17 (PK657AA) problem: the image is displayed for 3 seconds
first try entering VGA mode in the startup menu. u can get the startup menu by pressing the F8 key immediately after the POST screen. if the screen stabilizes try changing the resolution to 1024 by 768 which should work in normal mode. if that doesnt work then the monitors internal bulbs may be burnt. an electrician may fix this problem for you.
Posted on Nov 18, 2011
SOURCE: Hp L1730 (P9625A) tiene manchas en el display
Just press your finger anywhere on the screen and it will turn darker around that spot.
You obviously warped the outside lid of your laptop. See if you can take the lid and the LCD apart and straighten the lid to relief the LCD-pressure from behind (literally...)
Posted on Jul 28, 2012
My HP L1730 Model PE1238 17 inch lcd monitor wont switch on. it makes a sound every couple seconds. it sounds like it does when its coming on but its cut short fix please ?
How to repair HP Pavilion f1703 lcd monitor - YouTube
? 5:48
https://www.youtube.com/watch?v=rFXyIMAq64o
Jul 11, 2010 - Uploaded by z28r2fast4u
How to repair HP Pavilion f1703 lcd monitor. ... 17:38. HP L1750LCD monitor repair - Also applies to ...
HP W2207h LCD MONITOR-HOW TO TURN OFF OSD ...
h30434.www3.hp.com > ... > Video/Touch
Solved: MY EXTERNAL, HP W2207h LCD FLAT SCREEN MONITOR OPERATES FINE WITH ... HP ENVY 17t Touch,i7-5500u,16GB, 256 GB SSD (on loan)Missing: l1730 ‎pe1238
Using and Adjusting Your Monitor - HP Customer Support
Dec 25, 2015 | HP Computers & Internet
Jul 27, 2012 | HP L1730A (Carbonite, Silver) 17 in. Flat...
Please help me, i got a hp 1730 lcd monitor. the problem is that the screen is turned white and no image is present like there si not sinc on the screen the menu is lose only a shadow on the screen and...
How many months or years of your monitor that you are using? Do you check the outlet, cables? It's seems that your monitor has a problem because i read your observation that your monitor seems to be replace a new one. That's the monitor's problem.
Sep 16, 2011 | HP L1730 (Carbonite, Silver) 17" LCD...
I have a (HP L1730) flat panel monitor that im trying to use with my HP Compaq 6910p Laptop. When I power on the monitor,there is a quick 1 second flash of my desktop on the screen,then it goes to a black...
Does it do the same when it is hooked up to desk top PC?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
Aug 24, 2010 | HP 1730 LCD Monitor
My laptop hp have problem monitor giving mesage ''monitor going to sleep''
hi you will need to reinstall the vga of the system to enable it not to write that again
May 19, 2010 | Computers & Internet
The image is blinking.I can only see what's on the screen for a fraction of a second and then it blinks. The image is also very dull
Looks like a bad CCFL lamp, not a user replaceable part. You could have it checked by a local repair shop. If it's the lamp, the while LCD panel needs to be replaced.
Time for a new monitor?
Mar 14, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Hp vs17 monitor is glitching
Look for bad caps with bulging tops in the power supply section. See some examples of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell E193FP Problem
Probably a failing power supply
Apr 17, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
Dell - 17" flat screen
This sounds like the back light is gone on the monitir... to check this look very close at the monitor whet the PC has booted, if you see a VERY dim image on screen then it suggests that the back light is gone.
Many monitors hace a 3 year warranty so I would try a warranty claim before throwing it away
Jul 12, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
HP L1730A (Carbonite, Silver) 17 in. Flat Panel LCD Monitor Logo
694 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
