Question about Nikon Coolpix 4800 Digital Camera
Nikon coolpix 4800 - built-in flash may need to be replaced
Lately when I do close-ups and use the flash - a dark area in the lower right hand corner shows up in the photo - I'm making sure my fingers are not in the way - when I don't use the flash I don't have this dark area show in the photo - I've had the camera for about 3 years and bought it new - any help would be much appreciated - thanks
I have the same camera and have had the lens cover get stuck and it will leave the dark shadow in the pictures like you describe. It doesn't always happen, but when it does I just gently push the lens cover all the way open with my finger.
Posted on Apr 06, 2009
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
Nikon Coolpix p80 blacked out, rounded corners
Have you attached some sort of lens shade to the front of the lens? The vibration might have something to do with the shake reduction system but I can't be sure. It certainly shouldn't vibrate heavily. You might get a better answer if you e-mail the tech guys at the support section of the Nikon website.
Feb 19, 2010 | Nikon COOLPIX P80 Digital Camera
What does the flashing red hand in the upper right
The flashing red light is warning you that the shutter speed will be too long for handholding the camera. Put the camera on a tripod or other stable surface, and/or use the flash.
Nov 08, 2009 | Nikon COOLPIX S9 Digital Camera
When trying to take pictures of my motorcycle with all the led lights on at night the pictures keep coming out al blurry or very bright I have tried the settings on night time/ museum/ without the flash/...
Most likely the problem is "Camera shake". This just means that being in the dark, the camera shutter speed is long enough that the natural shake of your hands make the picture blurry.
You've got a couple options. The easiest is to find a nearby object and use it to steady your hand as you take the picture. You can also get a tripod and use the time delay release on the camera. This will let you push the button (which shakes the camera) and then step back before it actually takes the picture.
If you're shooting fairly bright LED's on the bike, you also might go into manual mode on the camera and experiment with shorter shutter speeds. Most people can use a speed of 1/60 without too much blur, so start with that and move to shorter speeds (maybe 1/100 or less). With the manual speed, you may get enough light from the LED's to make a good picture.
If this doesn't work for you, post a comment and I'll check back every few days and give some more ideas. Your camera may have some other ways to work through this. Rear curtain flash would be the best, but I don't think it has it....
Sep 11, 2009 | Nikon Coolpix 4800 Digital Camera
Flash
flash tube is likely failed,
like a average light bulb is 1000 hours some fail immediately
most camera shops can do the repair, and its a common part
price depends on shop
Oct 19, 2008 | Nikon COOLPIX S200 Digital Camera
Flashing shadow area on olympus e500
While in playback mode, image is blinking, the word shadow appears in lower right hand corner, use the info button repeatedly until all disappears and image is pure.
Mar 25, 2008 | Olympus EVOLT E-500 Digital Camera
Shadow on image when using built-in Speedlight
The built-in Speedlight on many Nikon cameras is designed to be a convenient way to either light up a dark subject or to add fill light to a daytime scene. The built-in Speedlight cannot replace a full size, external speedlight which should be used when more power or coverage are needed. Because the built-in Speedlight is compact and close to the camera it cannot be used under all conditions. When using a lens that is physically very long, a subject that is very close, or a wide lens hood it is possible that a shadow may be cast upon the subject. Notice, in the sample below, the round shadow in the bottom center of the photo. When the lens is too long or the coverage is too wide with a close subject a shadow of the lens itself is cast. In figure "A" below the lens is casting a shadow. Switching (or zooming) to a shorter lens (figure "B") prevents the shadow and allows even illumination. If your lens, subject, or lens hood choice create a shadow, an external flash (either on the camera's hot-shoe or connected to the camera by a wire or wirelessly) should be used to fully light the subject.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon Coolpix 4800 Digital Camera Logo
99 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
