Question about Acer Aspire 6920 Notebook PC
Acer boots from xp
When i turn on computer sometimes it boots up from windows xp and goes into acer arcade deluxe allthough my laptop has vista this gets rather annoying after a while any ideas how to stop it booting to xp instead of vista what it should do have seen several forums with same problem
  • bearnc146 Mar 06, 2009
    mine does the same even after I removed the Acer Arcade Delux program.
  • John Miller Jr May 11, 2010
    Which OS came with the laptop: XP or Vista? Has the laptop been set up to dual boot (two or more OSs installed on the same machine)? Is this a downgraded machine? Post back replies please...
I have the same laptop, there is 2 EISA on the hard drive an 10GB partion and an 3.5 GB partion, one of theses is the XP partition and the other in the D2D recovery parition, hard drive progames on the hiren's boot cd would work for deleteing both the parititions.
TVista will work without the EISA partitions, but make back up disks before you attepmt this.
Posted on Mar 13, 2009
Take it back to store. basically a hidden, but unremovable partition is causing the xp bootup. It happened to me aswell. They will probably give you a replacement as it is an unfixable problem. Even with new hard drive didnt fix it. Sorry about that.
Posted on Mar 10, 2009
Im using Acer Aspire 4935. The problem is, there's a virus in my Acer Arcade Deluxe system. I've repaired once my laptop (can't go inside Window-start up) caused by this software, Arcade Deluxe. Can i...
Download and run a program called hitman pro, here is a link to download:
http://download.cnet.com/Hitman-Pro-3-32-bit/3000-2239_4-10895604.html
During boot-up keep pressing F8 this should give you safe mode options, choose "SAFE MODE WITH NETWORKING" once your have got into windows install hitman pro and use the free trial by registering the product online. Rin the software and remove any found viruses.  Re-boot the computer and go into Windows as normal all viruses should be removed.
Mar 19, 2011 | Computers & Internet
When I startup my laptop it goes straight to Arcade Deluxe how do I get back to windows
Per these pages:
http://www.theacerguy.com/forum/topic/quit-acer-arcade-deluxe
http://www.theacerguy.com/forum/topic/acer-arcade-deluxe-loading-on-startup-cant-get-to-windows
This one even tells you how to disable it in windows start up.
http://www.cybertechhelp.com/forums/showthread.php?t=182345
it says to make sure "HOLD" button is not turned on when shuting laptop down otherwise it will do what yours is doing. They are also talking about going in to safe mode and taking it out of start up. Just read the posts and you might be able to get rid of it. The one i found was towards the bottom.
Good luck.
Nov 07, 2010 | Acer Aspire 6920 Notebook PC
CAN YOU INSTALL ARCADE DELUXE ON WINDOWS 7
if you can install it on vista then you can install it on 7
Oct 04, 2009 | Acer Aspire 5920-6727 Notebook
Start up stuck on Acer Arcade Deluxe screen
if you can boot into safe mode by pressing f8 at startup, check the startup folder for acer arcade and remove it if present.From your start button go to (start-programs-startup).
another option is to check the run key in the registry: one caveat though - please don't mess with things in the registry you don't understand. Deleting or changing unknown registry keys can result in a non-booting pc.
please stick strictly to my instructions and you will be fine. We're going to look and see if windows is calling the acer arcade to run at boot time:
click your start button and type 'regedit' (no quotes in the start search field. A window titled 'registry editor' will appear. Now, to expand a field in the registry, we left-click on the triangle on the left side of the field.
so, click the triangle beside HKEY_LOCAL_MACHINE
go down to 'software' and click the triangle beside it. go down to Microsoft and click the triangle, go to windows and click the triangle, go to current version and click the triangle, go to run and click on the run folder, not the triangle beside it.
Now look in the list of items in the run folder. these are all items that run when your pc boots. If you see an item with 'acer arcade' or just 'arcade' in the name, then delete it. DO NOT DELETE ANY OTHER REGISTRY KEYS....PLEASE!
if you found acer arcade and removed it then reboot and all should be better. if not, boot to safe mode again, click start button and type in 'msconfig' - no quotes. go to the startup tab, and again only uncheck anything with acer arcade in the name.
Hope this helps!!
Aug 09, 2009 | Acer Aspire 6920 Notebook PC
Tried to update drivers for acer arcde deluxe, system crashed and now the arcade won't start at all. Unable to update again.
Do a windows system restore to a day before you installed the new software, and if this fixes it, leave the acer arcade alone. If you must upgrade acer arcade, check the acer website and be sure you get the correct version for your version of windows: ie xp/vista and 32bit/64bit.
you can check your windows version this way: right-click 'my computer' in xp 'computer' in vista and left click properties. this will tell you your windows version, and whether it is 32 or 64 bit. If this fails again, do another system restore, and contact acer for support. My best advice is to leave it alone if you get the pc functioning properly though. please contact me if you need any further help.
Jul 19, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer Aspire 5920 - Acer Arcade Deluxe Problem
have you checked your bios settings are you booting from the right drive have you tried recovery?
Jun 02, 2009 | Acer Aspire 5920-6727 Notebook
Acer 6920g has gone onto acer arcade deluxe cinema .
I have had the same problem ... that happend to me when I press the arcade deluxe button on the blue gem controler on the left. when I tryed to run vista again it keeps going to the arcade deluxe system ...
the only solution for that case that works with me when I run the system recovery and installed fresh copy from the windows vista that came with my laptop ...
I hope that helps you in your case.
Feb 10, 2009 | Acer Aspire 5100 Notebook
in bios, locate windows vista and set it up to start automaticly , (default operating system)
Jan 13, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 6920 Notebook PC Logo
201 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
