Question about Royal VF1012mx Shredder
Royal VF12mx shredder
Overload light comes on everytime i try to shred
    Genius:
  • 1,218 Answers
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Posted on Oct 06, 2010
SHREDDER CONTINUALLY SAYS OVERLOAD EVEN THOUGH 2 SHEETS OF PAPER ARE INSERTED
It might need cleaning; mine had the shredded paper jammed in by cutters and some shreds got between the gears. First, try using a "cleaning sheet": a piece of paper lightly sprayed or smeared with vegetable oil or spray cooking oil. If that doesn't do fix it, the shredding mechanism, which has many parts, some of which are sharp as razors, might need to be disassembled and cleaned. Though I did that disassembly and cleaning, I would not recommend it to the casual DIY-er.
Sep 08, 2014 | Royal HG140MX Shredder
How do you remove the top to see the gears in a Royal 16CDX cross cut paper shredder. The overload message is displayed, and I don't know how to get it unjammed.
a possible solution is to UNPLUG the unit, reach in from underneath and start pulling stuck paper out. On mine (different model) I can remover the paper receptacle bin and reach up to remove stuck paper. this usually is caused by overloaded bin pushing shredded paper back up to cutters because it is overfull......BE SURE TO UNPLUG FIRST !!!!!
Nov 17, 2012 | Royal 160MX Also called 16CDX Cross-Cut...
I purchased a Royal Shredder, Mod. VF1700MX, Ser. No. 080245302 on Feb. 25, 2009. It was sent back for repair, under warranty about a year ago. I never shred more than 5 sheets at a time.It now cuts out on...
Have you ever "oiled " the machine...99% of cross cut shredders have to be oiled... get some shredder oil and squirt it onto the cutting blades where you put the paper in...this should be done with a certain frequency dependant on the amount of shredding that you do.
Nov 02, 2010 | Royal Office Equipment & Supplies
My shredder overload light comes on immediately with only one sheet of paper inserted and it won't go.
Try running the machine in reverse and putting some shredder oil onto the cutting blades to loosen things up. Then try running the machine in the forward direction but hold the paper in the eyes but dont let it go into the shredding blades...see if it runs forward.!
If it will do this then slowly try paper 1 sheet at a time..but put some shredder oil onto the sheets of paper you are shredding.
If the overload light still comes on without even letting you shred 1 sheet of paper then you likely have another problem...maybe the motor or pcb..you can contact Royal at 1-800-524-0799 for parts assistance.
Oct 28, 2010 | Royal RS9512C Shredder
I have a Royal VF1000MF shredder. While shredding
Try running the shredder in reverse and oiling the blades. More assistance with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder back to good condition it looks like you might have to get a new paper shredder. Great place to learn about new paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF1000MX Shredder
Royal VF700 won't barely shred one sheet of paper. It givexs the overload red light when 1 sheet of paper has just barely started to be shredded.
Royal. Haven't heard of that brand. Could get in contact with tech service, but it's probably easier to grab a new paper shredder.
Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF700 Cross-Cut Shredder
While attempting to feed paper overload light comes on and shredder stops
Over load light comes on only when you have either put too thick a bundle of paper or too hard. So reduce the thickness according to the hardness of the paper. Start with a few sheets of paper only. then increase the number of sheets till you find the shredder is struggling hard to do the job. That is your limit. If you exceed this limit then it would stop shredding and may even burn the motor ultimately.
Nov 29, 2009 | Royal VF1012mx Shredder
Royal VF 1000, overloads with one sheet of paper
Try pouring some shredder oil into the cutting blades where you insert the paper then run the unit in reverse for a while. Then put some of the shredder oil onto a sheet of paper and try shredding the sheet of paper. Some lubrication on a x-cut shredder does not hurt.
Jul 21, 2009 | Royal Office Equipment & Supplies
Have a royal vf1012mx shredder that overloads everytime i try to shred.
Put in less thicknesses. Also, put them in in the center. If they are near the edge and they are at an angle, they will flip over themselves and double the thickness.
It is designed for 12 sheets of paper. They probably figure on 18 pound paper, not 20. Adjust what you put in to allow for this.
Mar 05, 2009 | Royal VF1012mx Shredder
Red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Jan 08, 2009 | Royal VF1012mx Shredder
Royal VF1012mx Shredder Logo
398 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
