Question about PSC QuickScan QS6500BT (QS65B3040100401) Barcode Scanner
Need to expand EAN8 to 12 digit (UPCA?)
There are options in the programming guide to expand EAN8 to EAN13 but I need it to expand to 12 digits, as every upc in our db goes by 12 digits.
Honeywell
Scan "do not expand ean-8 to ean-13" in your programming guide.
Jan 18, 2013 | Honeywell Voyager 1200g Barcode Scanner...
How to set up a hobart quantum scale to print EAN13 label
you need to add a ean13 label type to your scale. this is something only a service tech. or hobart rep can do.
Mar 26, 2012 | Office Equipment & Supplies
My scanner reads only12 numbers not 13 numbers from barcode what h do?
Perhaps you should ask for replacements and ask for a bar code scanner who reads 13 numbers because even how many times you try it over and over again if the function of the scanner is limited in reading 12 number the results will be the same..Hope it can Help you.
Jul 02, 2011 | Metrologic Instruments 9520 Voyager
Can't program digital channels only has analog option
If your TV does not have a digital tuner, you'll need a digital converter box.
After the digital switch in June, did you have channels then? If so just do a rescan.
Jan 11, 2010 | Broksonic CCVG1935 19 in. LCD TV
We need to convert UPC-A barcode number to EAN-13
Most scanners will convert UPCA to EAN13 as you scan if you have that setting checked. A 0 will be added in front of the UPCA to make it an EAN13. Nothing else changes. You can read about this stuff on Wikipedia.
Mar 24, 2009 | Symbol LS2208 Handheld
I am not sure how to put videos on my mp3
The cd which comes with the player contains a program called "Arcsoft media coverter". You need to run your videos through that program to get them into a format accepted by the Insignia.
Another option is to use a different converter program (basically, the primary answer is that you need to convert your videos to a format the Pilot recognizes), but the options are too numerous to expand on. I'll refer you to anythingbutipod.com which has an excellent Insignia section.
Jan 25, 2009 | Insignia Sport MP3 Player
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Configuring eclipse 5145
Turning off check digit sending and adding 4 suffixes: 2 cursors left and 2 deletes, solved the problem.
Apr 19, 2008 | Metrologic Instruments MS5145 Handheld
PSC QuickScan  QS6500BT (QS65B3040100401) Barcode Scanner Logo
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
