Question about Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet "walking"
Sister has this washer and it likes to "walk". Checked leveling and footing, both appear to be OK. Any suggestions?
  • 4 more comments
  • helcha17 Mar 05, 2009
    localwonder, will have to give advice to sister and get back to you. Thanks.
    localwonder, just contacted sister and gave your advice. She says it happens whether it's a couple of items or a dozen. Any other thoughts?
  • helcha17 Mar 06, 2009
    localwonder, once again, I'll have to get back to you. I'm recovering from 3 broken ribs in my lower back, so I'm not sure when I can do this. Thank you for the suggestion.
  • helcha17 Dec 08, 2009
    localwonder, it's been a while so I just want to let you know that this "walking" problem has seemed to clear, according to my sister. Go figure.
  • helcha17 Dec 09, 2009
    localwonder, was wondering if you were still looking here. Cannot say, or even think, of what it may have been. It was not just a single incident, but quite a few over time.
    Healing up slowly, partially because they did damage to my shoulder in the hospital. Thank you for remembering.
  • helcha17 Dec 10, 2009
    localwonder, thank you for that advice. If the problem returns and I'm able, I will give that a looking at.
  • 6,784 Answers
Hi, most of the time this can be a simple as a overload that will dramatically shake this type of washer. due to its front load design, it is recommeded to load accordingly to specs. overloading this type of washer will induce walking/excessive vibration during the spin cycle.
Posted on Mar 05, 2009
  • 2 more comments
  • Michael Masters
    Michael Masters Mar 05, 2009
    ok, i would check the drum and see if it has become lose. this will require some disassembling but, this could be the problem.check the screws that attach the drum to the axle assembly. the screws may be lose, causing vibration during the spinning motion.
  • Michael Masters
    Michael Masters Mar 06, 2009
    ok, no problem. take your time and get well. god bless.
  • Michael Masters
    Michael Masters Dec 09, 2009
    Ok, that is great. It was probably caused by a single load that was overloaded, or unbalanced. I trust that you are healing well.
    Thanks for the feedback, and have a great evening:)
  • Michael Masters
    There are other issues that will cause this type of movement, during a washing cycle. This unit has counter weights that work with the shock absorber assembly. These weights balance the wobble, during the spin cycle. If the weights are loose on the rear of the drum, this will cause the unit to shake, due to abnormal wobble of the drum. A failed shock absorber assembly can cause this, as well.
    To access these parts, you will need to remove the rear panel. Once removed, the absorbers and drum counter weights will be exposed. The weights are mounted on the rear of the actual drum. The absorbers are mounted on the lower section of the drum housing(lower left, and right hand corners).
Why does my estate whirlpool corporation heavy duty super capacity washer sounds like it is off balance in spin cycle and walks across the floor and loud noise
because it is off balance , the feet needs to be adjusted as your floor may not be perfectly level,,, take a level and see what direction it appears to be off .. do this on all four sides . example , if the back right is low then you need to turn the foot to raise that corner and so on. use an adjustable wrench .
Aug 08, 2014 | Washing Machines
Balance, washer shakes and walks across floor
Have you checked to make sure the supports are OK? Is your washer making loud noises during spinning? If so, the basket drive may be broke.
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Maytag 3000 washer and I have adjusted the feet numerous times to keep it from walking. Do you have any suggestions? The floor is good but likes to walk during spin cycle.
did you level the unit first as per owners manual, then after its level did you turn the "jamb huts" on the legs with a 9/16" open ended wrench above the feet up against the cabinet bottom?,if you dont do this step the vibration in spin will turn the legs again and un-level the unit
Feb 21, 2010 | Maytag EPIC MFW9700S Front Load Washer
Washer in high spin cycle "walks" slightly away from the wall although when I put a level on it it appears to be level. The floor vibrates when it is in this high spin cycle. Feet are not raised very much...
make sure all the pegs are touching the ground. You may have the vibration dampner going out or the weight on the wheel is loose. You can find all that by unscrewing the back of the machine
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Walking Washer on pedestral
Not me!......My problem was a working washer machine on pedestral.
May 18, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool Duet washer is off balance.
My wife and I just purchased the Whirlpool 9400 series washer and dryer. We loved the pair, the installers came in and set them up ran them rather quickly and showed us the features and left. We put our first load into the washer, I will add, it was a rather large load, but nothing bigger than what the washing machine would handle. Started the washer up and walked away. About 30 minutes later we walk back into the laundry room to see and hear the washer rocking the pedastle door right out of the pedastle and then started to walk itself about 12 inches from the wall. This was very dangerous to us as we have a 14mth old. We immediatly called the store who sent another installer over. He again checked it for levelness and said that this is a known issue and that we should consider buying the cabrio or taking the washer and dryer off the pedastles.
So, to solve this issue, I'm sure you are all waiting. Infact, the washer was level, however, and this is what I found to be key, Lift the washing machine off the front legs, raise them up about a 1/4" higher than the back legs, this will make the washer uneven from front to back, but the other key is to make sure that the nut on the washer leg is all the way up and tight against the washer. In my user manual it said use a 17mm open end wrench to lock the nut against the washer, but my nut was a 14mm.
Again, make the front of the washer a little higher than the back and make sure all the nuts that are on the washer legs are tight against the washer or pedastle.
My washer went from the house ********, to the thing that doesn't make any noise at all.
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer vibrates and walks across the floor
Theres a few things you can do to stop it from walking.
but the best way i know is to use washer anchors.
Whirlpool part# 155P3 $22.95
Im going to assume that you have eaither the wfw8300 or wfw8400
the main differences is the suspention system in them. the 8300 uses a 5 point system that work but really you should only use the washer on solid flooring like concrete. the 8400 uses a 6 point with better shocks.
if you have this washer on a main floor with basment underneith it you might want to check the floor. grab a glass of water when it starts to shake and walk and put it on the floor, if the water is jumping then the floor is the problem.
eaither way the anchor kit i have listed above will stop your issues with it moving and walking.
Feb 07, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirpool Duet Washer leaks from the door
Make sure the transit brackets and screws have been removed.
Other than that,I would say it needs a new door, as it is possibly twisted, and not closing tightly enough against the door seal.
Plz rate my suggestions.
Thanks.
Jan 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer appears to be out of balance
Double check the screws holding the washer to the pedestal to make sure they are tight and make sure all the jam nuts on the leveling legs are tight. Loose jam nuts are the most common cause of this.
If they are tight, loosen the right front leg and screw it up until the weight is off the floor. Then run it back down until it contacts the floor. Put the washer in high spin and tighten it down to the floor until you get the spot where there is the least vibration. Tighten jam nut, and check it again in spin with a load of clothes.
Post back and let me know how this works.
Oct 18, 2007 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
434 people viewed this question
Dan Webster
Dan Webster
Sal De
