Question about Acer Aspire 5050-3242 Notebook
Opening acer aspire 5050
I am unable to seperate the upper cover and lower cover of my acer aspire 5050 model laptop inspite of removing all the 18 screws shown in the service manual. Something is holding it together. Any help would be greatly appreciated
  • Acer Master
  • 32,281 Answers
The top and bottom covers are also held together with plactic catches.
After you remove the battery, CD/DVD drive and hard drive etc.
start near an openning and gently pull apart the top and bottom cases, you should hear a click as a catch releases, then continue to work around the edge fron this point.
Posted on Mar 06, 2009
My acer aspire 5050 shuts down after using it for 20-30mins
CLICK HERE to know the causes of your laptop heating and how to solve it....
Good Luck.. :)
Jul 18, 2010 | Acer Aspire 5050-3242 Notebook
The machine (Aspire 5050) starts and works normally, but there is a sound (noise) coming out. It seems that it is a problem in the fans. It begins when the machine turn on and continues until shut down.
you cud remove the fan, and replace it or u cud try dusting it first without opening it up...and if that doesnt work dust it after opening it up and try fixing it...use replacement as the last option... and most fans make noises! trust me...
Jun 15, 2010 | Acer Aspire 5050 Notebook
Can i use the lcd of aspire 4315 to my aspire 5050
dear lcd desplay are same in every model just you need the same size of both. means if you have 15' then you fit only 15'.and if you buy your model lcd there is no any problem because right now problem with cericuit of lcd
Jan 19, 2010 | Acer Aspire 5050-3242 Notebook
ACER 5050 NOTEBOOK CAMERA NOT FOUND WHAT DRIVER
You can get the drivers from here:
http://www.acerdriver.org/?gclid=CJiUzdTt5ZwCFVhB5godijRJHA
Might cost you a few dollars but will save you the agpravation.
Sep 10, 2009 | Acer Aspire 5050-3242 Notebook
Black screen.
A few questions up ahead please:
a. Is the power button lighting up when you press it or power on your laptop?
b. Is the battery fully charged?
c. is the power cable/charger still good when you connect to mains supply?
**If you answered YES to all the above...
Your laptop screen may be bad and as such must be replaced.
Otherwise, The windows operating system may have CRASHED.
If this is so, then you can try out this system recovery tips as the last resource:
1. try remove the hard drive which you can access by opening the back cover as shown in the owner's manual.
2. next, connect this through an external usb casing to another system and backup all files on the hard drive.
3. if you don't have an acer recovery cd(s) for your laptop, try get someone who has and can help you burn the software for your model and make.
4. next, format the hard drive before you reinstall it back into your laptop.
5. power on your laptop and continously press F8 to enter the bios setup.
6. Select bootup sequence and select boot from cd drive.
7. first reinstall a lower version windows os by inserting a bootable system software.
8. after installation, keep the cd rom drive open and shut down your laptop.
9. insert the acer system recovery cd into the cd rom drive and close shut.
10. Restart your laptop then, Follow the instructions and prompts.
Your laptop will be restored to the way it was originally from the manufacturer.
Jul 08, 2009 | Acer Aspire 5050-3242 Notebook
Web cam acer aspire 5050
find here
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/OTHER-SCANNERS/Acer-Aspire-5050-Webcam-Driver.shtml
u can go with these links
Jun 12, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5050 drivers
Windows does not come with pc specific drivers, you need to download them from the Acer web site, but never heard of a Aspire 5050, so choose your model on the page link
Sep 11, 2008 | Acer Aspire 5100 Notebook
Acer aspire 4315 connect to TV problem
you should be able to right click on an empty space on your desktop and choose graphics properties and then the output option should be able to be set and the resolution changed if needed, set your tv for AV3 or s video and connect a seperate audio cable as s video is video only
Sep 10, 2008 | Acer Aspire 5050-3242 Notebook
Acer aspire 5050 is havin problm
google "acer aspire 5050 webcam drivers"
click a site, download ,then install
Aug 24, 2008 | Acer Aspire 5050-3242 Notebook
Removal of cooling fan
You need to disable your laptop.
follow this step:
Remove harddrive.
1. on the back of laptop, there are 2 doors. open it all. 1 of them is harddrive.
2. remove harddrive.
Remove wireless cable.
1. open 2nd door on the back, you can see rams and wireless card. unplug wireless cable from wireless card.
Remove chassis
1. Remove 2 screws on the hinge cover, so you can remove the power cover (power cover is cover that have power button).
2. after you removed power cover, removed keyboard.
3. remove 4 screws that hold lcd from chasiss. you can remove lcd now.
4. remove 3 screws under keyboard.
5. remove all screw on the back of your laptop.
6. remove upperchassis.
7. remove 2 screw that hold motherboard from lowerchasis.
8. take motherboard out from lowerchasiss.
9. now you can see the thermal fan.
Jun 19, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5050-3242 Notebook Logo
697 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
