Question about Frigidaire Dishwashers
My Frigidaire Dishwasher is not draining
Concerned that water from the sink may be draining into the dishwasher.
    President:
  • 2,976 Answers
Check the direction of the drain from the dishwasher. It should go into a slightly pointed downward "TEE".
Posted on Mar 05, 2009
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Electrolux professional series not pumping water
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
My Frigidaire dishwasher has dirty water.standing in bottom. Dishes are not clean
Aug 08, 2012 | Dishwashers
Standing water in dishwasher
Jul 30, 2012 | Frigidaire Dishwashers
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Jul 20, 2012 | Frigidaire Dishwashers
MY FRIGIDAIRE DISHWASHER WILL NOT DRAIN. MOTOR ONLY HUMS DURING DRAIN CYCLE. OTHER THAN DRAINING IT SEEMS TO WORK FINE. DAY IT QUITE WORKING SINK BACKED UP AND WOULD NOT DRAIN
if there is still water in the dishwasher take the drain hose off from under the sink and use a large pot or mop bucket and but the unit into a drain mode usually by cancelling the wash cycle if the unit still does not drain.Then use a wet dry shop vac and attach it to the end of the drain hose to remove the water
after the water is gone check the drain pump for any kind of obstructions you may need to replace the drain pump
Jun 06, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher will not advance through cycles - Frigidaire GLD2250RD
Thanks for writing to Fixya.com.
Is your drain hose stopped up with debris - have a double sink next to the dishwasher. You can plug both drains, one at a time with the water running in the sink while holding the other drain closed. Try it first and if it works, its free, otherwise you may find it's another issue like maybe a bad pump motor on the dishwasher.
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 27, 2010 | Frigidaire 24 in. GLD2250RD Built-in...
The dishwasher collects water at the bottom and is not draining. Water backs up in the sink.
your sink drain trap is clogged, may have a build up of food from dishwasher pour some baking soda in sink drain and fluxh with a pot of really hot water
Jul 08, 2009 | Frigidaire Dishwashers
Water Stayed in dishwasher
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 28, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
A common problem with dishwashers is the non-draining machine. If you are having trouble, check to see if the drainpipe and sink trap are clogged. If you still have drainage problems after doing this, check your drain hose to make sure there are no kinks or bends. if the hose looks worn out you can replace the hose pretty inexpensivley. if your have thoughly checked from dishwasher to trap under the sink where your dishwasher should drain to and it seems clear you may have to call in the repair man.
Jun 18, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Open Questions:
Dishwashers Logo
99 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
